    Visual Studio 2010 --> 2012 strange things happen
    3 Posts 0 Posters 356 Views
      On 09/02/2014 at 15:34, xxxxxxxx wrote:
      Cinema 4D Version:   13,14,15
      Ok, I am going from VS 2010 to VS 2012. As far as I understand, this is ok with regard to the binaries created, it is first when I want to go to VS 2013 things happen, right?
      Well, forget about 2013 at this moment.
      I had expected a few hassles and snags, I can live with that. But this, which I will describe below, is more than I can understand, even if I try very hard:
      BaseObject* bar FooBar::GetBarFromFoo(BaseTag* foo)
          return foo->GetObject();
      This code works just fine all over my plugin, but not in this very class. All classes I have stem from TagData. If I put the cursor over GetObject(), and press F12, it hops to the definition all right. And Code Completion suggests GetObject() as it should, but Intellisense complains.
      I really wonder why this happens!!
      What I did, was to create a helper class, with just the purpose to solve this stupid error. With the same code in this helper class. And in this helper class, it works fine, I can build the project. But hey - I want to find out about this, what on earth is going on?!?
      Edited:
      The problem is gone..
      I have no idea why this hapoened, apart from one fact: I tried  the Visual Leak detector http://vld.codeplex.com/
      And a lot of things suddenly doesn't work anymore.
        On 10/02/2014 at 03:18, xxxxxxxx wrote:
        GetObjectA is something from windows.h as far as I can remember.
        If you include it make sure that you also uses something like this:
        #define WIN32_LEAN_AND_MEAN
        #define VC_EXTRALEAN
        #define NOMINMAX
        //other NO... defines...
            #include "windows.h"
        http://support.microsoft.com/kb/166474
        If you use R14 SDK then there will be problem with LONG also.
        regards,
        Remo
          On 10/02/2014 at 09:43, xxxxxxxx wrote:
          Yes, I saw that too.
          In general, while I have been programming in C++ now for 8 months, I feel I am still a beginner. What confuses me is all those paths, compiler options, linker properties etc. It is like a jungle to me, whenever I build, I fear an error message popping up that I have no clue about.
          The Property Manager in Visual Studio is especially confusing, combined with the property settings for each project. I have a wrong path somewhere, correct this path all over in a dialog boxes I can find, compile, get an error, inspect the properties again - only to find that the incorrect path I thought I had weeded out has crept back into the system again.
          Well, I am exaggerating a bit, but you get the picture.
          Thanks for the reply, great tip!
