    AttributeError: Parameter value not accessible
    26 Posts 0 Posters 16.0k Views
      On 05/02/2014 at 09:33, xxxxxxxx wrote:
      Could you post your description resource file? The .res file in res/description/
        On 05/02/2014 at 09:41, xxxxxxxx wrote:
        CONTAINER arbor
             NAME arbor;
             INCLUDE Obase;
        GROUP ID_OBJECTPROPERTIES
                  GROUP
                       BITMAPBUTTON AB_PIC_HEADER1 { ICONID1 1029369; ALIGN_LEFT; }
                  SEPARATOR { LINE; }
        LINK AB_TRUNK { ACCEPT {Obase;} }
                  GROUP
                       LONG AB_SEGMENTS { MIN 1; MAX 20; }
        SEPARATOR { LINE; }
        LONG AB_SPLINE_TYPE
                            CYCLE
                                 AB_TP_LINEAR;
                                 AB_TP_CUBIC;
                                 AB_TP_AKIMA;
                                 AB_TP_BSPLINE;
        LONG AB_SUBDIVISIONS { MIN 0; MAX 20; }
        SEPARATOR { LINE; }
        LONG AB_SEED1 { MIN 1; MAX 999999; }
        GROUP AB_B1
                  GROUP
                       BITMAPBUTTON AB_PIC_HEADER2 { ICONID1 1029369; ALIGN_LEFT; }
        SEPARATOR { LINE; }
        BOOL AB_ON1 {}
        SEPARATOR { LINE; }
        LONG AB_NUM_B1 { MIN 1; MAX 20;}
                  REAL AB_START_B1 { MIN 0.0; MAX 99.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
                  REAL AB_END_B1 { MIN 1.0; MAX 100.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
                  REAL AB_DENS_B1 { MIN 10.0; MAX 200.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
        SEPARATOR { LINE; }
        LONG AB_SEED_B1 { MIN 1; MAX 999999; }
        GROUP AB_B2
                  GROUP
                       BITMAPBUTTON AB_PIC_HEADER3 { ICONID1 1029369; ALIGN_LEFT; }
        SEPARATOR { LINE; }
        BOOL AB_ON2 {}
        SEPARATOR { LINE; }
        LONG AB_NUM_B2 { MIN 0; MAX 20;}
                  REAL AB_START_B2 { MIN 0.0; MAX 99.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
                  REAL AB_END_B2 { MIN 1.0; MAX 100.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
                  REAL AB_DENS_B2 { MIN 10.0; MAX 200.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
        SEPARATOR { LINE; }
        LONG AB_SEED_B2 { MIN 1; MAX 999999; }
        GROUP AB_B3
                  GROUP
                       BITMAPBUTTON AB_PIC_HEADER4 { ICONID1 1029369; ALIGN_LEFT; }
        SEPARATOR { LINE; }
        BOOL AB_ON3 {}
        SEPARATOR { LINE; }
        LONG AB_NUM_B3 { MIN 0; MAX 20;}
                  REAL AB_START_B3 { MIN 0.0; MAX 99.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
                  REAL AB_END_B3 { MIN 1.0; MAX 100.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
                  REAL AB_DENS_B3 { MIN 10.0; MAX 200.0; UNIT PERCENT; CUSTOMGUI REALSLIDER; }
        SEPARATOR { LINE; }
        LONG AB_SEED_B3 { MIN 1; MAX 999999; }
        GROUP ABOUT
                  GROUP
                       BITMAPBUTTON AB_PIC_HEADER5 { ICONID1 1029369; ALIGN_LEFT; }
        SEPARATOR { LINE; }
        STATICTEXT ABOUT_ME1 { ANIM OFF; }
                  SEPARATOR {LINE;}
                  STATICTEXT ABOUT_ME2 { ANIM OFF; }
          On 05/02/2014 at 16:52, xxxxxxxx wrote:
          Thanks, Rui, I was able to reproduce the problem. I'll take a deep look into it. I've reconstructed your
          problem in this project:
          https://dl.dropboxusercontent.com/u/99829745/stuff/2014-02-06-getdenabling-parentcall-issue.zip
          Best,
          -Niklas
            On 05/02/2014 at 17:02, xxxxxxxx wrote:
            I started removing sections of the description with each restart of Cinema until I found what caused the
            issue. It is the BITMAPBUTTON GUIs that cause the exception in the parent call of GetDEnabling().
            Unfortunately, even if you remove your bitmap buttons, it sometimes fails with a TypeError:
              File "'test.pyp'", line 8, in GetDEnabling
            TypeError: argument 5
            Which is also a known issue of R14 and was fixed in R15. See https://developers.maxon.net/forum/topic/6533/7047_getdenabling-typeerror-on-parentcall
            As a workaround for this issue (and the original if you want to keep your BITMAPBUTTONs) , you can
            use a try-catch block.
                def GetDEnabling(self, *args, **kwargs) :
                    try:
                        return c4d.plugins.ObjectData.GetDEnabling(self, *args, **kwargs)
                    except TypeError:
            Best,
            -Niklas
              On 06/02/2014 at 01:52, xxxxxxxx wrote:
              Thank you for the information, Niklas.
              I tried the following:
              def GetDEnabling(self, node, id, t_data, flags, itemdesc) :
              try:
                             return c4d.plugins.NodeData.GetDEnabling(self, node, id, t_data, flags, itemdesc)
              except AttributeError:
              isoff1=node[AB_ON1]
                        isoff2=node[AB_ON2]
                        isoff3=node[AB_ON3]
              if (id[0].id == AB_NUM_B1) : return isoff1==1
                        if (id[0].id == AB_DENS_B1) : return isoff1==1
                        if (id[0].id == AB_START_B1) : return isoff1==1
                        if (id[0].id == AB_END_B1) : return isoff1==1
                        if (id[0].id == AB_SEED_B1) : return isoff1==1
              if (id[0].id == AB_ON2) : return isoff1==1
                        if (id[0].id == AB_NUM_B2) : return (isoff1*isoff2)==1
                        if (id[0].id == AB_DENS_B2) : return (isoff1*isoff2)==1
                        if (id[0].id == AB_START_B2) : return (isoff1*isoff2)==1
                        if (id[0].id == AB_END_B2) : return (isoff1*isoff2)==1
                        if (id[0].id == AB_SEED_B2) : return (isoff1*isoff2)==1
              if (id[0].id == AB_ON3) : return (isoff1*isoff2)==1
                        if (id[0].id == AB_NUM_B3) : return (isoff1*isoff2*isoff3)==1
                        if (id[0].id == AB_DENS_B3) : return (isoff1*isoff2*isoff3)==1
                        if (id[0].id == AB_START_B3) : return (isoff1*isoff2*isoff3)==1
                        if (id[0].id == AB_END_B3) : return (isoff1*isoff2*isoff3)==1
                        if (id[0].id == AB_SEED_B3) : return (isoff1*isoff2*isoff3)==1
              But I still get the same error 😞
                On 06/02/2014 at 17:51, xxxxxxxx wrote:
                I tried it out in R15 and the error also occurs there.
                  On 10/02/2014 at 03:13, xxxxxxxx wrote:
                  I guess, my only solution is to ditch the bitmaps 😞
                    On 11/02/2014 at 06:51, xxxxxxxx wrote:
                    What you've tried would exit the GetDEnabling() function immediately.
                        isoff1=node[AB_ON1]
                        isoff2=node[AB_ON2]
                        isoff3=node[AB_ON3]
                        try:
                        except (AttributeError, TypeError) :
                            # Bug up to R14, AttributeError seems to be raised randomly for
                            # BitmapButton items and TypeError sometimes for other things.
                    -Niklas
                      On 12/02/2014 at 04:54, xxxxxxxx wrote:
                      It still returns the same errors 😞
                      I believe I will really have to ditch the bitmaps.
                      It is a shame, since I made some nice graphics 😞
                      Rui Bastista
                        On 10/01/2015 at 01:34, xxxxxxxx wrote:
                        is now a solution for r15 ?
                          On 10/01/2015 at 07:37, xxxxxxxx wrote:
                          The problem (at least with bitmaps) seems to be fixed in r15 and up.
                            On 10/01/2015 at 17:15, xxxxxxxx wrote:
                            after update to the latest r15 - it`s fixed - thanks
