    DATETIME_GUI
    5 Posts 0 Posters 466 Views
      On 31/01/2014 at 08:20, xxxxxxxx wrote:
      Cinema 4D Version:   R15
      (Also) in C++ I do not get the little arrow in front of the date and time to show (expand) the calendar and the clock?
      	BaseContainer dtcont;
      	dtcont.SetBool(DATETIME_TIME_CONTROL, true);
      	dtcont.SetBool(DATETIME_DATE_CONTROL, true);
      	dtcont.SetBool(DATETIME_NOW_BUTTON, true);
          dt = (DateTimeControl* )AddCustomGui(1002, DATETIME_GUI,"Date/Time",BFH_SCALEFIT|BFV_SCALEFIT,0,0,dtcont);
        On 31/01/2014 at 11:25, xxxxxxxx wrote:
        This is one of those odd gizmos that have to be expanded in the Init() function. Not in the CreateLayout() function.
        That tripped me up too.
        Bool MyDialog::InitValues(void)
          dt->SetLayoutMode(LAYOUTMODE_MAXIMIZED);  //Works like "OPEN" does in the .res file
        Also.
        Be aware that most of the DT base container options are now depreciated.
          On 01/02/2014 at 02:46, xxxxxxxx wrote:
          Great, thank you.
          Does it also means that we have to program the little collapse/expand arrow in front, ourselfs?
          At the moment there is no such little arrow, so I assume you have to do it yourself.
          Regards, Pim
            On 01/02/2014 at 07:44, xxxxxxxx wrote:
            Yeah. I think you'll have to create that effect yourself. Using a button that swaps an image when pressed. Or some other sort of trickery.
            That little arrow only seems to get created when you use these custom gizmos in a Node based plugin. But not in a GeDialog plugin.
            This is an example of creating the DT gizmo dynamically for a node (tag) plugin.
            Just like when using the .res file to create the gizmo for these kinds of plugins. That little arrow automatically get created for us.
            It's a built-in thing for the Node plugins that we get for free.
            Bool SimpleTag::GetDDescription(GeListNode *node, Description *description,DESCFLAGS_DESC &flags)
            //We will load the DateTime GUI into the first description level(much like loading UD entries into levels)
              DescID did = DescLevel(1, DTYPE_NONE, 0);
              BaseContainer settings;
              settings.SetLong(DESC_CUSTOMGUI, DATETIME_GUI);
              settings.SetString(DESC_NAME,"DateTime");
              settings.SetString(DESC_SHORT_NAME,"DateTime");
              settings.SetBool(DATETIME_NOW_BUTTON, TRUE);
              if (!description->SetParameter(did,settings,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
              On 01/02/2014 at 14:46, xxxxxxxx wrote:
              Thanks, indeed when using User Data and a Date/Time field you get the little arrow.
              But doing that yourself in c++ is not a big issue. We discussed it in one of my previous posts.
              Thanks for the example.
              Pim
