    GetClone without hierarchy
    SDK Help
    0
    1.0k
    • H
      On 01/11/2002 at 08:24, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      I´m trying to get a clone of an Object without getting any children of this object. Using obj->GetClone(0) doesn´t work. (1,2,3 doesn´t work either. Why aren´t the flags documented anyway? )
      How does it work then?
      • H
        On 01/11/2002 at 12:54, xxxxxxxx wrote:
        the flags are documented, just not at the place where you would expect it. You can find the available flags on the doc page for the CopyTo method.
        I just tried it with the following code and it seems to work with the same tags, that are listed there: <[URL-REMOVED]>
        \>     >   // Aktuelles Objekt bestimmen
        \>     >   var currentObject = GetActiveObject(doc);
        \>       var clone;
        \>     >   clone = currentObject->GetClone(CL_NO_HIERARCHY);
        \>     >   GetActiveDocument()->InsertObject(clone, NULL, NULL);
        \>       // C4D mitteilen, dass sich das aktuelle Dokument geändert hat
        \>     >   GeEventAdd(DOCUMENT_CHANGED);
        CIAO
        Daniel
        • H
          On 01/11/2002 at 13:00, xxxxxxxx wrote:
          Ahhh! Thanks very much. Wouldn´t have expected it there. Thanks! 🙂
