    Downloading a file from the Internet
    9 Posts 0 Posters 803 Views
      On 20/01/2014 at 06:54, xxxxxxxx wrote:
      Cinema 4D Version:   R15
      I think I need to use HyperLinkCustomGui and HyperlinkData to download a file from the Internet.
      Not to display it (that is done with HTMLViewerCustomGui), but to read and process it.
      The manuals tells me "Hyper link data type (CUSTOMDATATYPE_HYPER_LINK_STATIC[URL-REMOVED]) for use with the HyperLinkCustomGui[URL-REMOVED] GUI. Has to be created with Alloc()[URL-REMOVED] and destroyed with Free()[URL-REMOVED]. You can useAutoAlloc[URL-REMOVED] to automate the allocation and destruction based on scope."
      However, I do not know how to use them and I cannot find an example.
      	BaseContainer hyperlinkc;
      	hlcgsibl = (HyperLinkCustomGui* )AddCustomGui(1002, CUSTOMGUI_HYPER_LINK_STATIC, "Hyperlink", BFH_SCALEFIT|BFV_SCALEFIT, 900, 200, hyperlinkc);
      	String linkTextsIBL = "http://www.hdrlabs.com/sibl/index.html";
      	String labelTextsIBL = "Smart IBL overview";
      	hlcgsibl->SetLinkString(&linkTextsIBL, &labelTextsIBL);
      Pim
        On 20/01/2014 at 08:01, xxxxxxxx wrote:
        Hi Pim,
        You just need to set HYPERLINK_IS_LINK to true in the HyperLinkCustomGui container.
          On 21/01/2014 at 04:01, xxxxxxxx wrote:
          Ok, then how do I tell cinema 4d where to store the downloaded data.
          Do I need to Alloc the HyperlinkData and put that somewhere in the container?
            On 21/01/2014 at 05:52, xxxxxxxx wrote:
            Pim, do you want to download a file or display a link in a dialog where the user can download a file?
              On 21/01/2014 at 11:53, xxxxxxxx wrote:
              I want to download a file.
              After downloading I will display the contents of the file using the treeview as we discussed in another post.
              By the way, in Python it is very easy to do.
              In our lon-lat plugin we connect to OSM, query the site and use the result (the contents) in our plugin.
                On 23/01/2014 at 05:53, xxxxxxxx wrote:
                Hi Pim,
                Setting a link now works.
                	//set labelText as link.
                	hyperlinkc.SetBool(HYPERLINK_IS_LINK, true);
                	String linkTextsIBL = "http://www.link.com/index.html";
                	String labelTextsIBL = "Link text";
                However still the question how to download data in a for C++ accessible form?
                E.g. I want to download http://www.grooff.eu/countries.txt and put the input of this file in a treeview.
                Use HyperlinkData, but how?
                  On 26/01/2014 at 06:52, xxxxxxxx wrote:
                  Still very unclear, how to download a file from the internet.
                  I can use HyperLinkCustomGui to define a link, but when clicked the file is openen in a browser and the file is not downloaded.
                  The manual tells to use HyperLinkData, but how?
                  In the example below, I do not use it.
                  	String linkTextsIBL = "http://www.grooff.eu/pictures/download.txt";
                  	String labelTextsIBL = "Download test file.";
                  	String pStrLink, pStrText;
                  	hlcgsibl->GetLinkString(&pStrLink, &pStrText);
                    HyperLinkData is only useful if a HYPERLINK parameter is defined in a description resource.
                    It allows to get/set the hyperlink text and link strings.
                    HyperLinkCustomGui only displays a link. If you need to download a file from an internet URL take a look at these pages on Stackoverflow:
                    http://stackoverflow.com/questions/1129194/download-a-url-in-c
                    http://stackoverflow.com/questions/1636333/download-file-using-libcurl-in-c-c
                      On 01/02/2014 at 02:56, xxxxxxxx wrote:
                      Thanks, I can now run curl using a command file and thus download a file.
                      I can get curllib to work in win32 mode, but not in x64 mode.
                      Getting it to work in x64 is a lot of work (too much).
                      Note: I use visual studio c++ 2010 express.
                      Yannick also showed me how to run python scripts, so I will proceed in that direction.
                      Python and Internet is straightforward.
