    Treeview with custom tree
    25 Posts 0 Posters 19.9k Views
      On 19/01/2014 at 06:18, xxxxxxxx wrote:
      It is quite possible (and easy) to use your own class structures in a tree view.  InterPoser Pro uses a folder/file system to display items as a tree view.  You need to have a root and items and associate levels with them (parents/children).  If you would like to see my code, PM me.
        On 19/01/2014 at 06:24, xxxxxxxx wrote:
        Hi Niklas, sorry still very confusing.
        I can now create a data structure and defined the TreeViewFunctions.
        Not all of them, GetFirst and GetName, GetDown, GetNext and SetName.
        I now get a window with a starting treeview and one little arrow.
        No names however.
        Is *root in my case always root (so I have to define it globally) or is it somewhere else defined?
        Also, I seem to be mixing up class Node and class MyNode.
        When to use which class?
        #include "c4d.h"
        #define ID_SHADER_BROWSER 11229405 // plugin id test
        class Node {
            Node* next;
            Node* pred;
            Node* up;
            Node* down;
        	String	name;
        	Node() : next(nullptr), pred(nullptr), up(nullptr), down(nullptr), name("") { }
            Node(const String& name) : next(nullptr), pred(nullptr), up(nullptr), down(nullptr), name(name) {
            virtual ~Node() {
                next = pred = up = down = nullptr;
            void InsertAfter(Node* pred) {
                if (pred->next) {
                    pred->next->pred = this;
                    this->next = pred->next;
                pred->next = this;
                this->pred = pred;
                if (pred->up)
                    this->up = pred->up;
            void InsertBefore(Node* next) {
                if (next->pred) {
                    next->pred->next = this;
                    this->pred = next->pred;
                next->pred = this;
                this->next = next;
                if (pred->up)
                if (this->pred == nullptr && this->up)
                    this->up->down = this;
            void InsertUnder(Node* up) {
                if (up->down) {
                    this->InsertBefore(up->down);
                else {
                    up->down = this;
                    this->up = up;
            //void Remove() {	code removed
        class MyNode : public Node
            typedef Node super;
            String name;
            Bool selected, folded;
            MyNode(const String& name) : super(), name(name), selected(false), folded(true) { }
        GeListNode* GetNextElement(GeListNode* op)
          if (!op)
            return NULL;
            // in case of material inspect shaders otherwise continue in usual mode
            if (op->IsInstanceOf(Mmaterial) && ((BaseList2D* )op)->GetFirstShader())
                return ((BaseList2D* )op)->GetFirstShader();
          else if (op->GetDown())
            return op->GetDown();
            while (!op->GetNext() && op->GetUp())
                op = op->GetUp();
            return op->GetNext();
        void UnselectNodes(BaseDocument *doc)
            if (!doc)
                return;
            BaseList2D *mat = (BaseList2D* )doc->GetFirstMaterial();
            if (!mat)
                return;
            while (mat)
                mat->DelBit(BIT_ACTIVE);
                mat = (BaseList2D* )GetNextElement(mat);
        ///TreeView Functions Table class
        class CustomTree : public TreeViewFunctions
        	virtual void* GetFirst(void* root, void* ud) {
                if (root)
                    return static_cast<MyNode*>(root)->down;
                return nullptr;
            virtual String GetName(void* root, void* ud, void* obj) {
                if (obj)
                    return static_cast<MyNode*>(obj)->name;
                return "???";
        	virtual Bool IsOpened(void *root,void *userdata,void *obj)
        		return  false;
        	virtual void Open(void* root, void* userdata, void* obj, Bool onoff)
        		return;
        	void SetName(void* root, void* userdata, void* obj, const String& str)
        		static_cast<MyNode*>(obj)->name = str;
        		return;
            virtual void* GetDown(void *root,void *userdata,void *obj)
            virtual void*   GetNext(void *root,void *userdata,void *obj)
                return static_cast<MyNode*>(root)->next;
        	virtual void Select(void *root,void *userdata,void *obj,Int32 mode)
        		return;
        	virtual Bool IsSelected(void *root,void *userdata,void *obj)
        		return FALSE;
            virtual Int   GetId(void *root,void *userdata,void *obj)
                return (Int)obj;
            virtual Int32 GetDragType(void *root,void *userdata,void *obj)
                return NOTOK;
        ///Dialog class
        class CustomBrowser : public GeDialog
            CustomBrowser()
                _customTreeGui = NULL;
            ~CustomBrowser()
            // define dialog with some gadget build menus, title and so on
            virtual Bool CreateLayout(void)
                // call class parent function
                Bool res = GeDialog::CreateLayout();
                // set dialog title
                SetTitle("Custom Tree Browser");
        		//attach treeview so the GUI element and define its parameter via treedata BaseContainer
        		BaseContainer treedata;
        		treedata.SetBool(TREEVIEW_ALTERNATE_BG,TRUE);
        		_customTreeGui = (TreeViewCustomGui* )AddCustomGui(1000, CUSTOMGUI_TREEVIEW, String(), BFH_SCALEFIT|BFV_SCALEFIT, 0, 0, treedata);
                if (_customTreeGui)
                    BaseContainer layout;
                    // add column 0 with type LV_TREE so default tree with name
                    layout.SetInt32(0, LV_TREE);
                    // set column layout to the GUI element
                    if (!_customTreeGui->SetLayout(1,layout))
                        return FALSE;
                return res;
            // set tree root and update it
            Bool UpdateTree(Node* root)
                if (!_customTreeGui->SetRoot(root, &_customTree, NULL))
                    return FALSE;
                // update tree GUI
                _customTreeGui->Refresh();
            // initialize dialog
            Bool InitValues(void)
                // call parent function
                if (!GeDialog::InitValues())
                    return FALSE;
        		// build tree datastructure
        		Node* root = new Node("ROOT");
        		Node* firstChild = new Node("First Entry");
        		firstChild->InsertUnder(root);
        		Node* secondChild = new Node("Second Entry");
        		secondChild->InsertUnder(firstChild);
        		Node* thirdChild = new Node("Third Entry");
        		thirdChild->InsertUnder(secondChild);
                // build tree and set root
                if (!UpdateTree(root))
                    return FALSE;
            // react toglobal notifications
            Bool CoreMessage(Int32 id, const BaseContainer& msg)
                //if (id == EVMSG_CHANGE)
                    // get active document
                //    BaseDocument * doc = GetActiveDocument();
                //    if (!doc)
                //        return FALSE;
                    // build tree and set root		How to get root?
                //    if (!UpdateTree(doc))
                //        return FALSE;
                return GeDialog::CoreMessage(id, msg);
        private:
            CustomTree                  _customTree;
            TreeViewCustomGui       *_customTreeGui;
          On 19/01/2014 at 06:28, xxxxxxxx wrote:
          Hi Robert, your inbox is full.
          I like to see your code very much.
          Regards, Pim
            On 19/01/2014 at 10:52, xxxxxxxx wrote:
            I'd like to see an example too Robert.
            Because while I can also wrote the gizmo. It crashes when I try to add things to it due to using a custom Node.
            And I still don't understand why we need to write a completely new Node for this?
            If we don't want to use a  baselist2D object. Can't we just substitute another type of object in the various TreeViewFunctions class methods?
            Seeing a working example might help me answer those questions.
              On 19/01/2014 at 15:47, xxxxxxxx wrote:
              I think this example should set things clear now.
              Best,
              -Niklas
                On 19/01/2014 at 17:04, xxxxxxxx wrote:
                Thanks Niklas,
                Only you're using a bunch of C++11 stuff.
                And when I convert it to work in R13. The selections don't work. And the new items are never created as children.
                I'm still trying to figure out why they don't work.
                  On 20/01/2014 at 02:51, xxxxxxxx wrote:
                  Great, thanks Niklas.
                  For me with R15 and VS Express 2010 it is working great.
                  Adding new nodes, drag&drop, rename, delete, everything works!
                  It looks very advanced C++ programming, so I will learn a lot from it.
                  Thanks, Pim
                    @Scott: I want to download information from the Internet and present it in a treeview.
                    So, the information is not cinema 4d info, thus I need to define my own nodes and present it in the treeview.
                    Does the code Niklas provided answer your question though Pim?
                    Because as far as I can see. Even if you create a tree node system from scratch. Which I still don't think you have to do. You still have the problem of how to display text based information in the tree.
                    There's void *parameters in the tree's methods that I think are there to use for things like this. But I keep running into type errors.
                    A good example is the help system in C4D.
                    It's using a tree to display names of pages. And jumps you to them when clicked on in the tree gizmo.
                    How do we do that?
                    That's the kind of example I think Robert was going to show.
                    Are still will to share that code Robert?
                      Of course you could use the BaseList2D class, but it is not optimized for this purpose. It would come with
                      a huge overhead and you would make your life hard yourself if you want to display any data more than
                      just a name and folding and selection states.
                      How do we do that?
                      It's a Treeview Gui and an HTML Gui. When one item in the tree is clicked, the HTML Gui changes its
                      contents. What is the problem you have here?
                      -Niklas
                        On 20/01/2014 at 10:38, xxxxxxxx wrote:
                        I know how to handle the HTML GUI part.
                        It's making the tree display data other than a BaseObject() or a BaseMaterial() that I can't figure out how to do.
                        For example. This code displays BaseObjects:
                            virtual void *GetFirst(void *root,void *userdata)
                              //Casting from BaseDocument() to root works fine here
                              BaseDocument *doc = (BaseDocument* )root;
                              //Grabs the first object in the OM and fills the node data with a BaseObject type of data
                              return GetActiveDocument()->GetFirstObject();
                          virtual String GetName(void *root, void *userdata, void *obj)
                              //The text in our tree branches comes from the string values in BaseObject
                              return ((BaseObject* )obj)->GetName();
                        Now what if we don't want to display a BaseObject() or BaseMaterial() in our tree?
                        What if for example. We want to use the objects stored in a BaseContainer? Or an array? Or maybe the file names of the HTML pages stored in a folder like the C4D help tree gui works?
                        This does not work:
                              //Casting from BaseContainer() to root does not work like BaseDocument() does
                              BaseContainer *bc = (BaseContainer* )root;  //<---Ouch! void type error!!
                              return  bc->GetLong(1)  //<---Trying to return the first object in the container???
                        From what I'm guessing.
                        The tree gizmo is a linked list that takes a bunch of items that are stored somewhere (the document, an array, a container, etc...).
                        Using the SDK tree gizmo we can easily use the objects stored in a BaseDocument() to populate the tree. Because somehow...Somewhere. The node for the tree is set up to handle these type of data.
                        But how do we use data from an array, or a BaseContainer, or a folder containing a bunch of HTML files like the C4D help tree gizmo works?
                        Making a custom node only shows how to set up the way a tree looks and behaves. But it doesn't address how to use it with data stored someplace other than BaseDocument or BaseList2D.
                        I had thought that we could maybe use the void *params. to do that. But maybe not?
                          On 20/01/2014 at 11:27, xxxxxxxx wrote:
                          That is the very reason to use your own Node class, Scott. First, you build the tree, then you display it
                          in the TreeViewCustomGui. The TreeViewCustomGui is nowhere fixed to be used with objects from a
                          document, it is just a coincidence (intentionally of course) that it is easy to use with them.
                          Regarding your pseudo-example code, GetFirst(), just as many of the other methods in the
                          TreeViewFunctions class, returns a void* pointer. It is up to you to be sure about the actual type of
                          the memory address to return, all it wants is a memory address. From this memory address, it will
                          ask you for more data (GetNext(), GetName(), IsSelected() all get that void pointer passed as an argument).
                          In your example, you will probably want to do something like this instead?
                              if (doc)
                                  return doc->GetFirstObject();
                              return nullptr;
                          // ... GetNext(), GetPred(), GetDown(), GetUp() ...
                              BaseObject* op = static_cast<BaseObject*>(obj);
                              BaseContainer* bc = op->GetDataInstance();
                              if (bc)
                                  return bc->GetString(1);
                              return "<???>";
                          Best,
                          -Niklas
                            On 20/01/2014 at 12:36, xxxxxxxx wrote:
                            Ok Thanks.
                            That answers the question I had whether or not we must create a new Node or not.
                            But I still don't know how to write the code that declares what data type the node can hold and use.
                            So that I can display a list of filenames in the tree rather than object names?
                            You've got three classes involved in your tree gizmo
                            -class BaseNode
                            -class Node : public BaseNode
                            -class TreeModel : public TreeViewFunctions
                            I assume we don't declare the data type in the TreeModel class.
                            So where (how) do we declare the data type we want to display in our tree. If I wanted to display the names of HTML files I have in a folder on my HD?
                            *Edit-- Oh wait..I think I can do that in the AddNode() function. And use Filename() there to set the node's text instead of "NewNode".
