    CTrack backtracking
    5 Posts 0 Posters 407 Views
      On 15/01/2014 at 17:53, xxxxxxxx wrote:
      So I have a track of an object using:
      object = doc.GetActiveObject()
      for track in object.GetCTracks() :
      	#do something
      What I would like to do is get the user data the track belongs to.
      for example Position Y the track is:
      <c4d.CTrack object called 'Position . Y/Track' with ID 5350 at 0x00000026E9C7D190>
      What I want to get:
      Cube[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Y]
      How do I get from CTrack to c4d.VECTOR_Y?
      Overall what I am trying to do is create a port in an XPresso node for the attribute that is creating that curve.
      Let me know if I am not being clear enough.
        On 16/01/2014 at 00:12, xxxxxxxx wrote:
        Hi Shawn,
        You can simply call CTrack.GetDescriptionID():
            for track in op.GetCTracks() :
                print track, track.GetDescriptionID()
                print op[track.GetDescriptionID()]
          On 16/01/2014 at 09:08, xxxxxxxx wrote:
          Thanks for the reply Yannick,
          using GetDescriptionID() : I get (1001,19,23) which I am guessing is the ID for the attribute that is animated.
          I am not familiar/still new to scripting, How do you use an ID once you have one?
          to create a node im using
          Node.AddPort(c4d.GV_PORT_OUTPUT,[c4d.ID_BASEOBJECT_POSITION])
          I am trying to get from the found track Position.Y to c4d.ID_BASEOBJECT_POSITION_Y .
            On 21/01/2014 at 09:21, xxxxxxxx wrote:
            Using
            track.GetDescriptionID()[1].id
            I was able to get just the id of Position.Y "1001"
            I then found out that this can replace c4d.ID_BASEOBJECT_POSITION like so:
            Node.AddPort(c4d.GV_PORT_OUTPUT,[1001])
            Thanks for getting me on the right track!
              On 21/01/2014 at 11:48, xxxxxxxx wrote:
              I lied,
              A more advanced setup was getting lost with just the ID you do need all 3 numbers. Honestly not sure how it was working with just a single ID.
