    SDK + Xcode + Mavericks?
    4 Posts 0 Posters 369 Views
      On 15/01/2014 at 16:32, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      Platform:    Mac  ;  Mac OSX  ;
      Is there an issue with R12 (32bit) C++ projects with Xcode 4.4.1 and Mavericks?
      All my R12 plugin projects stopped compiling and the only change on my machine was the Mavericks upgrade. R15 projects compile fine.
      Essentially, when I start building an R12 project it will get stuck while "Creating Universal Binary".
      Peter
        On 15/01/2014 at 17:00, xxxxxxxx wrote:
        I just tried to compile the R12 SDK and that does work so it seems to be in my projects.
        Since all my projects are cloned from the SDK I have no idea to start looking. Any input is greatly appreciated.
        Peter
          On 15/01/2014 at 18:01, xxxxxxxx wrote:
          Ok, I ended up creating new projects using the C4DSDK project file. That made it work. Still would like to know what happened there.
            On 16/01/2014 at 00:42, xxxxxxxx wrote:
            <ADDRESS>
            Platform:    Mac  ;
            Mac OSX  ;
            Language(s) :
            C++  ;
            </ADDRESS> Is there an issue with R12 (32bit) C++ projects with Xcode 4.4.1 and Mavericks?
            Peter
            Please note that the BaseSDK (OS X 10.5) used in R12 probably might not be available on Mavericks anymore (it ain't by default unless it is there from an old OS/Xcode installation or if you copied it manually on your system). Also the default compiler (gcc 4.2) used in R12 ain't available anymore in Xcode 4.4.
            Best regards,
            Wilfried
