    Resolution information
    4 Posts 0 Posters 385 Views
      On 02/01/2014 at 13:07, xxxxxxxx wrote:
      Cinema 4D Version:   R15
      When I load a texture direct in a material channel, c4d show the resolution info.
      How can I get this information?
      And what if I have textures in a layer shader.
      How to get the resolution for all images in the layer shader?
        On 02/01/2014 at 13:15, xxxxxxxx wrote:
        I found an old post from Matthias.
        Is this the way to go?
        _<_t_>_![Direct Link To This Post[URL-REMOVED]](https://developers.maxon.net/forum/topic/3949/3428_texturebitmapwhere-to-find-it&PID=14056#14056) Posted: 30 Jun 2008 at 5:56pm
        Unfortunatly the resolution or the link to the bitmap is not stored in a container. You have to check the bitmap manually, going by the path provided.
        <_<_t_>_
          On 02/01/2014 at 17:28, xxxxxxxx wrote:
          I think he meant that you have to get the information from the image file manually.
          Like this:
              Filename fn = GeGetC4DPath(C4D_PATH_DESKTOP) + "myimage.jpg";
            AutoAlloc<BaseBitmap> bmp;
            if (IMAGERESULT_OK != bmp->Init(fn)) return FALSE;
            LONG bw = bmp->GetBw();      //The image width
            LONG bh = bmp->GetBh();      //The image height
            GePrint(LongToString(bw));
            GePrint(LongToString(bh));
            MultipassBitmap *mbmp = NULL;
            mbmp = MultipassBitmap::Alloc(bw, bh, COLORMODE_RGBf);
            if (!mbmp) return FALSE;
            GeData d = mbmp->GetParameter(MPBTYPE_DPI);  //Gets the dpi info
            LONG dpi = d.GetLong();
            GePrint(LongToString(dpi));
            MultipassBitmap::Free(mbmp);
            On 03/01/2014 at 03:45, xxxxxxxx wrote:
            Yes, that is what I thought.
            I use GetColorMode.
            	orgImage->Init(fname, -1, nullptr);
            	Int32 colorMode = orgImage->GetColorMode();	//The image colormode
            	Int32 bw = orgImage->GetBw();				//The image width
                Int32 bh = orgImage->GetBh();				//The image height
            Here also a translation from the Int32 colormode to a String with the colormode description
            Perhaps someone might find it useful (it saves typing in).
            String modeToString(Int32 colorMode)
            	switch (colorMode)
            		case COLORMODE_ILLEGAL:
            			return "Illegal";
            		case COLORMODE_ALPHA:
            			return "Only 8-bit alpha channel.";
            		case COLORMODE_GRAY:
            			return "8-bit grayscale channel.";
            		case COLORMODE_AGRAY:
            			return "8-bit grayscale channel with 8-bit alpha.";
            		case COLORMODE_RGB:
            			return "8-bit RGB channels.";
            		case COLORMODE_ARGB:
            			return "8-bit RGB channels with 8-bit alpha.";
            		case COLORMODE_CMYK:
            			return "8-bit CMYK channel.";
            		case COLORMODE_ACMYK:
            			return "8-bit CMYK channel with 8-bit alpha.";
            		case COLORMODE_MASK:
            			return "8-bit grayscale map as mask.";
            		case COLORMODE_AMASK:
            			return "8-bit grayscale map as mask with 8-bit alpha.";
            		case COLORMODE_ILLEGALw:
            			return "Illegal.";
            		case COLORMODE_GRAYw:
            			return "16-bit grayscale channel.";
            		case COLORMODE_AGRAYw:
            			return "16-bit grayscale channel with 16-bit alpha.";
            		case COLORMODE_RGBw:
            			return "16-bit RGB channels.";
            		case COLORMODE_ARGBw:
            			return "16-bit RGB channels with 16-bit alpha.";
            		case COLORMODE_MASKw:
            			return "16-bit grayscale map as mask.";
            		case COLORMODE_ILLEGALf:
            			return "Illegal.";
            		case COLORMODE_GRAYf:
            			return "Floating point grayscale channel.";
            		case COLORMODE_AGRAYf:
            			return "Floating point grayscale channel with floating point alpha.";
            		case COLORMODE_RGBf:
            			return "Floating point RGB channels.";
            		case COLORMODE_ARGBf:
            			return "Floating point RGB channels with floating point alpha.";
            		case COLORMODE_MASKf:
            			return "Floating point grayscale map as mask.";
            		default:
            			return "Unknown Colormode: " + String::IntToString(colorMode);
            }// end String modeToString(Int32 colorMode)
