    ShowPopupDialog
    10 Posts 0 Posters 867 Views
      On 28/11/2013 at 11:01, xxxxxxxx wrote:
      Hey,
      I try to create a PopUp Menu like the default from cinema - with more menus around the mouse position
      i get a single menu item but can`t get a second menu item. has one a short example ?
        On 28/11/2013 at 13:42, xxxxxxxx wrote:
        post your code, there is an extensive example in the sdk under gui.ShowPopUpDialog()
          On 28/11/2013 at 13:53, xxxxxxxx wrote:
          i get a popup with one menu
          menu = c4d.BaseContainer()
          functionsmenu = c4d.BaseContainer()
          functionsmenu.SetString(1, 'men');
          functionsmenu2 = c4d.BaseContainer()
          functionsmenu2.SetString(1, 'men 2');
          menu.SetContainer(IDM_FUNCTIONSMENU, functionsmenu)
          menu.SetContainer(IDM_GROUPMENU, functionsmenu2)
          result = gui.ShowPopupDialog(cd=None, bc=menu, x=c4d.MOUSEPOS, y=c4d.MOUSEPOS, flags=c4d.POPUP_CENTERVERT|c4d.POPUP_EXECUTECOMMANDS)
            On 28/11/2013 at 15:01, xxxxxxxx wrote:
            The documentation shows to use BaseContainer.InsData(), not any of the setter methods.
            Best,
            -Niklas
              On 28/11/2013 at 15:55, xxxxxxxx wrote:
              the example show it with SetStrings
              [URL-REMOVED]#c4d.gui.ShowPopupDialog
              my problem is not to add a submenu - my problem is i like to add more than the one menu at the time - like the cinema default popup menu
                On 29/11/2013 at 04:10, xxxxxxxx wrote:
                your code is technically correct, on which c4d version are you ? for me the code does run just fine
                in r14/15 . are you sure that your container ids are properly set / unique ?
                  On 29/11/2013 at 04:25, xxxxxxxx wrote:
                  i use R15 -
                  right is the menu i get - it work - but is not what i want 🙂
                  _<_img src="http://hantmade.com/wp-content/uploads/c4d_plugincafe.png" height="443" width="453" border="0" /_>_
                    On 29/11/2013 at 05:35, xxxxxxxx wrote:
                    hm,
                    I am not quite sure what you mean with 'what I want'. here is a small and recursive example
                    building a menu tree.
                    import random
                    from c4d import gui
                        cid, menu =  getMenueContainer(c4d.FIRST_POPUP_ID, 0, 3, 8)
                        result = gui.ShowPopupDialog(None, menu, c4d.MOUSEPOS, c4d.MOUSEPOS,
                    def getMenueContainer(cid, curdepth, maxdepth, maxitems, root = c4d.BaseContainer()) :
                        if curdepth <= maxdepth:
                            children = []
                            for i in xrange(random.randint(1, maxitems)) :
                                item = c4d.BaseContainer()
                                item.SetString(1, 'Item_{0}'.format(i))
                                cid, item = getMenueContainer(cid, curdepth + 1, maxdepth, maxitems, item)
                                cid += 1
                                root.SetContainer(cid, item)
                        return cid, root
                      On 29/11/2013 at 05:38, xxxxxxxx wrote:
                      Hey Littledevil,
                      thanks for that code - sorry for my bad description
                      I don`t mean to get a tree menu i like to get a menu with more than one menus - a round that mouse position - like the default popup menu in cinema (get it with "v")
                        On 29/11/2013 at 05:52, xxxxxxxx wrote:
                        Ah ok. You are talking about the pie menus. Unfortunately they are not exposed in python
                        (and I think they aren't in cpp too). You would have to write your own system and open
                        several borderless GeDialogs simultaneously and then render the 'button content' into these
                        dialogs with a GeUserArea (for example nikklas button thingy class). Has always been on my
                        'would be fun to do' list, but i never managed to get to it, so I am not sure if it is possible.
