    DescriptionToolData-InitDefaultSettings
    3 Posts 0 Posters 303 Views
      On 20/11/2013 at 21:50, xxxxxxxx wrote:
      Cinema 4D Version:   15
      In DescriptionToolData, when gets DescriptionToolData::InitDefaultSettings actually called?
      The SDK info seems to imply that I use it to set my gadgets to their defaults. But at least in my code it never seems to go there.
      At the moment I am using DescriptionToolData::InitTool to set the defaults but since that happens every time my tool gets called it's not ideal.
      Am I missing something?
      Peter
        On 20/11/2013 at 23:45, xxxxxxxx wrote:
        Hi Peter,
        DescriptionToolData::InitDefaultSettings() is called once, at its first execution, to set the default value of its settings.
        Are you sure you use the right prototype?
        It's void DescriptionToolData::InitDefaultSettings(BaseDocument* doc, BaseContainer& data)
        See its simple implementation in the R15 SDK example SculptDrawPolyTool ( sculpting\drawpoly.cpp ). I put a breakpoint in it and it's called as expected by CINEMA.
          On 22/11/2013 at 12:31, xxxxxxxx wrote:
          Thanks for the tip.
          I didn't realize I also need this line in my function:
          DescriptionToolData::InitDefaultSettings(doc, data);
          Now it works. Although I don't exactly know why....
          Peter
