    counterpart of GetPointIndex ?
    9 Posts 0 Posters 731 Views
      On 09/11/2013 at 11:07, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      Hi there,
      i'd like to get the position along a spline for a specific point. looks like i need the counterpart for GetPointIndex. is there a function for this?
        On 10/11/2013 at 03:09, xxxxxxxx wrote:
        Hi ello,
        this question was asked quite recently in the Python forum.
        https://developers.maxon.net/forum/topic/7511/9397_percentage-offsets-of-interpolation-points
        Best,
        -Niklas
          On 11/11/2013 at 03:55, xxxxxxxx wrote:
          thank you 🙂
            On 13/11/2013 at 11:53, xxxxxxxx wrote:
            Hey, i need to get back on this as i am having problems using it. how can i get the spline position?
            LONG *seg;
            LONG *ind;
            Real *offset;
            baseSplineHelp->GetSplinePointSegment(i,offset,ind,seg);
            but, how do i access the offset now? when i try to GePrint it i get an error "cannot convert parameter 1 from 'LReal *' to 'LReal'" for obvious reason, but the question is where is the accessible offset for me?
            aside from this, i guess i am doing it wrong anyway. is there any example on how to get the offset for point x on a spline?
              On 13/11/2013 at 14:36, xxxxxxxx wrote:
              When you see pointers used in SDK functions like this: void GetSplinePointSegment(LONG index, Real* offset, LONG* ind, LONG* segment).
              It means that those parameters are placeholder pointer references to variables that will get filled in with data by the function.
              Like this:
              LONG seg;
              LONG ind;
              Real offset;
              baseSplineHelp->GetSplinePointSegment(i, &offset, &ind, &seg);
              This is a somewhat common technique used throughout in the C4d C++ SDK.
              Where you first create some empty variables....Then you execute a function that has these same variables in it's parameters. Which are pointing to the variables, and then assigning values to them.
              You gotta love this C++ pointer stuff. 😉
                On 13/11/2013 at 23:08, xxxxxxxx wrote:
                ah, thank you! just didn't know that * and & stuff was the same. already use the &
                  On 14/11/2013 at 03:47, xxxxxxxx wrote:
                  ok, still got a message. when i have for example a spline with three points (-100,0,0) / (0,0,0) / (100,0,0) i thought that the offset for the second point would be 0.5, but it is actually 0.333
                  why??
                  AutoAlloc <SplineHelp> splineHelp;
                  if (!splineHelp) return false;
                  splineHelp->InitSpline(spline,Vector(0),0,0,1,1,0);
                  LONG seg;
                  LONG ind;
                  Real offset;
                  splineHelp->GetSplinePointSegment(i, &offset, &ind, &seg);
                  GePrint(RealToString(offset));
                    On 14/11/2013 at 09:17, xxxxxxxx wrote:
                    I've only briefly explored the spline classes myself. So I'm not sure if any of this code will help or not.
                    This is the code from a tag plugin I wrote that moves an object along a spline :
                    //This tag plugin works similar to the Align-to-Spline tag in C4D
                    //Except my tag gets put on a spline object. And the object traveling along it gets dropped into the tag's linkfield
                    EXECUTIONRESULT MyTag::Execute(BaseTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, LONG priority, EXECUTIONFLAGS flags)
                      BaseContainer *tagdata = tag->GetDataInstance();   //Get the data in the tag and assign it to a variable
                      BaseObject *obj = tag->GetObject();                //Get the object the tag is on
                      if (!obj) return EXECUTIONRESULT_USERBREAK;
                      //Only work if the object the tag is on is a spline type (all types of splines)
                      if(!obj->GetInfo()&OBJECT_ISSPLINE) return EXECUTIONRESULT_USERBREAK;
                      //I used a linkfield gizmo to store the object that will move along the spline
                      BaseObject *target = tagdata->GetObjectLink(MY_LINK,doc);
                      if(target) //If the linkfield is not empty
                          //Gets the position of the object in the link field
                          Vector position = target->GetRelPos();
                          //Convert the object the tag is on to a spline type
                          SplineObject *myspline = ToSpline(obj);
                          SplineLengthData *sld = SplineLengthData::Alloc();
                          sld->Init(myspline, 0, NULL);
                          if (!sld) return EXECUTIONRESULT_USERBREAK;
                          SplineHelp *sh = SplineHelp::Alloc();
                          if (!sh) return EXECUTIONRESULT_USERBREAK;
                          sh->InitSpline(myspline, 0.0, FALSE, TRUE, FALSE, FALSE);
                          LONG segment = 0;                                      //NOTE:If the spline is a Primitive...only segment 0 works
                          Real PosOnSpline = tag->GetData().GetReal(MYNUMERIC);  //The position the object is along the spline's segment
                          Vector splinepos = sh->GetPosition(PosOnSpline, segment, TRUE);
                          sh->FreeSpline();
                          target->SetRelPos(Vector(splinepos.x,splinepos.y,splinepos.z));  //Moves the object along the spline
                          target->Message(MSG_UPDATE);
                      return EXECUTIONRESULT_OK;
                    These are a few examples that I've created in my notes about how to use some of the various spline functions in the SDK:
                    //This code gets the global position of a spline's point + an offset value
                      BaseObject *obj = doc->GetActiveObject();
                      if (!obj) return FALSE;
                      sld->Init(myspline,0,NULL);
                      if (!sld) return FALSE;
                      if (!sh) return FALSE;
                      Real offsetValue = 10.5;
                      Real offset = sh->GetOffsetFromUnit(offsetValue, 0);
                      //Real offset = sh->GetOffsetFromReal(offsetValue, 0);
                      //Get the global position of the first spline point + the offset
                      Vector p0 = sh->GetPosition(offset,0,TRUE,TRUE);
                      //Vector p0 = sh->GetPosition(sld->UniformToNatural(offset), 0, TRUE, TRUE);
                      GePrint(RealToString(p0.x));
                    //This code gets the offset, and segment values for the points in a selected spline object
                    //It calculates the distance the "offset" variable is from the first spline point
                    //NOTE: The offset values never change no matter where the points are placed(results are local..not global)
                    //      Example: offset = 0.5; is always the middle of the spline. No matter how the spline looks
                      BaseObject *obj = doc->GetActiveObject();             //The active object should be a spline object
                      SplineObject *myspline = ToSpline(obj);               //Convert the type to a spline type so we can work on it
                      //Create the SplineHelp class for the spline so we can use it's methods
                      Real offset = 0.5;   //The position along the spline. The range is: 0.0 - 1.0
                      //The values for these 2 variables are filled in by the GlobalToLocal() function
                      Real off;      //This value will match the value set with the "offset" variable above
                      LONG segment;
                      sh->GlobalToLocal(offset, &off, &segment, FALSE);
                      GePrint("offset: " + RealToString(off) + " " + "segment: " + LongToString(segment));
                    //This code gets the index, offset, and segment values for the points in a selected spline object
                    //The code calculates results based upon how many points in the spline. In relation to how long the spline length is
                    //It calculates the offset distance each point is from the first spline point
                      LONG count = myspline->GetPointCount();
                      for(LONG i=0; i<count; i++)
                          LONG index = i;       //Check each of the spline's index points
                          //The values for these 3 variables are filled in by the GetSplinePointSegment() function
                          LONG ind;
                          Real offset;
                          LONG segment;
                          sh->GetSplinePointSegment(index, &offset, &ind, &segment);
                          GePrint("index: " + LongToString(ind) + " " + "offset: " + RealToString(offset) + " " + "segment: " + LongToString(segment));
                    Maybe the code in these examples will help you.
                      On 14/11/2013 at 12:12, xxxxxxxx wrote:
                      thank you very much for those. much appreciated. still, i am not able to get the desired results. 0.333 is not what i think should be returned in my test-case. hopefully someone has an idea. in the end i want to get the position of points around a spline point at a certain distance (e.g. 0.01 left and right from the spline point)...
