    question on mograph splinewrap deformer
    1 Posts 0 Posters 151 Views
      On 07/11/2013 at 02:31, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      Hi there,
      i am currently facing a real strange behaviour. i am creating a mograph splinewrap deformer inside my plugin. generally everything looks fine but the deformation is behaving different (bottom in image). as soon as i make the plugin object editable and toggle the deformer off and on it looks like it should (top in image)
      i am hoping that there is a solution. maybe it is that there is something wrong with my initialisation (maybe someone has the code for initializing all parameters of that deformer as the default)? i am not setting all parameters but the following:
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_SPLINE),GeData(deformerSpline), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_RAIL_SPLINE),GeData(deformerRailSpline), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_AXIS),GeData(MGSPLINEWRAPDEFORMER_AXIS_ZP), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_STRENGTH),GeData(1), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_FROM),GeData(0), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_TO),GeData(1), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_RAIL_TARGET),GeData(true), DESCFLAGS_SET_0);
            splineDeformer->SetParameter(DescID(MGSPLINEWRAPDEFORMER_SIZESTRN),GeData(1), DESCFLAGS_SET_0);
      any help fixing this behaviour is really appreciated.
