    Setting doodle options
    4 Posts 0 Posters 408 Views
      On 14/10/2013 at 02:27, xxxxxxxx wrote:
      I want to set the Load Bitmap option of a Doodle Object.
      I can do that by using a CallButton, but then the user has to select a bitmap.
      I want to do it automatically, so set the bitmap using python.
      Looking at the Doodle Object, it seems a hidden Tag is connected to the object, storing all the information(?).
      <c4d.BaseTag object called 'Doodle Image/Doodle Image' with ID 1022211 ...>
      So it would seem to me that the bitmap information is also stored somewhere in the tag.
      But where?
      Below script gave me some information.
      I searched H and RES files to get more information, but so far I do not get the bitmap information.
      Any thoughts?
          doodleobj = doc.SearchObject("Doodle Object")
          bc = doodleobj.GetDataInstance()
          link = bc.GetLink(1002)
          print link
          if (link) :
              print link
              print "name:", link[c4d.ID_BASELIST_NAME]
              print "link:", link[c4d.DOODLEOBJECT_IMAGE]
              print link.GetType()
        On 14/10/2013 at 22:36, xxxxxxxx wrote:
        This is unfortunately not possible. The bitmap is stored in an internal
        member of the tag. Bitmaps can not be stored in containers.
        Best,
        -Niklas
          On 15/10/2013 at 03:04, xxxxxxxx wrote:
          Ok, thanks.
            On 24/10/2013 at 01:38, xxxxxxxx wrote:
            Well, in theory, you could implement a CustomDataType that holds a Basebitmap. That way, you could put it into a BaseContainer. But I'd say: too much work for too little benefit.
