    calling C++ from Python
    6 Posts 0 Posters 720 Views
      On 06/10/2013 at 07:25, xxxxxxxx wrote:
      We want to make cracking our python plugin a bit more difficult, by putting the hash creation in a C++ library.
      Is there a simple but complete tutorial how to call C++ functions from python?
      Pim
        On 06/10/2013 at 07:53, xxxxxxxx wrote:
        not sure if you can read german, but i think one of the best python tutorials come from
        a german IT publishing company called galileo computing.
        http://openbook.galileocomputing.de/python/python_kapitel_26_001.htm
          On 06/10/2013 at 11:04, xxxxxxxx wrote:
          A link to an english tutorial on how to use the ctypes module is here:
          http://python.net/crew/theller/ctypes/tutorial.html
          Remember that dynamic libraries can be replaced easily. It should be relatively
          safe if you perform a proper check, eg. by comparing via an MD5 hash.
          Best,
          -Niklas
            On 07/10/2013 at 23:59, xxxxxxxx wrote:
            Thanks for the links littledevil and Niklas,
            And indeed, checking the dynamic library using a MD5 hash is a good idea.
            The more levels of protection, the better.
              On 09/10/2013 at 00:57, xxxxxxxx wrote:
              sorry, I'm running into errors.
              "AttributeError: function 'Add' not found"
              I guess my C++ is not correct.
              I do believe the lib is oke:
              1>------ Build started: Project: MathFuncsDll, Configuration: Debug x64 ------
              1>     Creating library d:\users\pgrooff\documents\visual studio 2010\Projects\Dynamic library\x64\Debug\MathFuncsDll.lib and object d:\users\pgrooff\documents\visual studio 2010\Projects\Dynamic library\x64\Debug\MathFuncsDll.exp
              1>  MathFuncsDll.vcxproj -> d:\users\pgrooff\documents\visual studio 2010\Projects\Dynamic library\x64\Debug\MathFuncsDll.dll
              ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
              Here the c++ h and cpp file and the python code
              // MathFuncsDll.h
              #ifdef MATHFUNCSDLL_EXPORTS
              #define MATHFUNCSDLL_API __declspec(dllexport)
              #else
              #define MATHFUNCSDLL_API __declspec(dllimport)
              #endif
              namespace MathFuncs
                  // This class is exported from the MathFuncsDll.dll
                  class MyMathFuncs
                      // Returns a + b
                      static MATHFUNCSDLL_API double Add(double a, double b);
                      // Returns a - b
                      static MATHFUNCSDLL_API int Subtract(int a, int b);
                      // Returns a * b
                      static MATHFUNCSDLL_API double Multiply(double a, double b);
                      // Returns a / b
                      // Throws const std::invalid_argument& if b is 0
                      static MATHFUNCSDLL_API double Divide(double a, double b);
              // MathFuncsDll.cpp : Defines the exported functions for the DLL application.
              #include "stdafx.h"
              #include "stdafx.h"
              #include "MathFuncsDll.h"
              #include <stdexcept>
              using namespace std;
              namespace MathFuncs
                  double MyMathFuncs::Add(double a, double b)
                      return a + b;
                  int MyMathFuncs::Subtract(int a, int b)
                      return a - b;
                  double MyMathFuncs::Multiply(double a, double b)
                      return a * b;
                  double MyMathFuncs::Divide(double a, double b)
                      if (b == 0)
                          throw invalid_argument("b cannot be zero!");
                      return a / b;
              import ctypes
                  path = 'D:/Users/pgrooff/Documents/Visual Studio 2010/Projects/Dynamic library/x64/Debug/MathFuncsDll.dll'
                  bibliothek = ctypes.CDLL(path)
                  #bib = ctypes.CDLL('msvcrt')
                  #print bib.printf('2.33aaaa')
                  #print bib.time(None)
                  print bibliothek.Add(c_double(1.5),c_double(1.5))
              Note: Using another lib 'msvcrt' seem to work.
                On 09/10/2013 at 06:13, xxxxxxxx wrote:
                Ok, I made it much more simpler and it works now.
                Just a simple C++ file, no h file.
                #define DLLEXPORT extern "C" __declspec(dllexport)
                DLLEXPORT int add()
                	return 11;
                And the python script code:
                import sys
                import ctypes
                    lib_path = 'D:/Users/pgrooff/Documents/Visual Studio 2010/Projects/SimpleDLL/x64/Release/simpleDLL.dll'
                    mydll = ctypes.CDLL(lib_path)
                    print mydll.add()
