    Change Icon based on State in CommandData
    16 Posts 0 Posters 2.1k Views
      On 26/09/2013 at 23:56, xxxxxxxx wrote:
      thanks alot for that, but how do I get an instance of my plugin, searching the forums I found
      myPlugin = c4d.BaseList2D(c4d.plugins.BasePlugin(PLUGIN_ID))
      but this gives "this cannot be instantiated" error
      which is also mentioned in python documentation, so is this a dead end?
        On 27/09/2013 at 00:32, xxxxxxxx wrote:
        The BasePlugin can be found via c4d.plugins.FindPlugin(PLUGIN_ID)
        You can use c4d.gui.GetIcon() instead, too.
        -Niklas
          On 27/09/2013 at 01:39, xxxxxxxx wrote:
          I can not really believe that you have found that code fragment somewhere in the c4d python
          documentation, as it does not make any sense on a very basic level. There is only one constructor
          for BaseList2D and that does require you to pass an integer as an argument. You are trying to
          pass a BasePlugin instance, which does not work because the BasePlugin class cannot be
          instantiated, as the interpreter already did tell you and also is not the correct argument type for
          the BaseList2D constructor.
          Also trying to instantiate your plugin does not really make sense in that case, as it is one of the
          plugin types (CommandData, MessageData etc.)  which cannot be instantiated, or more precisely
          are only instantiated once after the start up by c4d. It is also quite important to understand the
          difference of your plugin class derived from BaseData, a BasePlugin and an actual node  repre-
          senting a plugin object.
            On 27/09/2013 at 01:41, xxxxxxxx wrote:
            awesome, thanks for all the help!
              On 27/09/2013 at 01:55, xxxxxxxx wrote:
              Yeah thats not a direct copy, most of the code I simply copy from here and there.
              I don't have any deep understanding of the sdk, but I get along with trial and error, examples and forums 😃
              Thanks for that explanation.
                I am wondering if it's possible to change the icon of CommandData plugin based on a its state.
                It's not possible to dynamically change the icon images for CommandData plugins in the menu.
                That image is set during the registration process when C4D starts up. And cannot be changed dynamically.
                The CommandData plugin does have a checkbox option for it which might look like an icon image. But it's not. It's done with a flag. And doesn't use the bitmap image where the icons are stored.
                It's an internal thing hard coded by Maxon.
                It would be very nice to be able swap our own icon images for the on/off state of these plugins. Instead of being stuck with that checkmark option. Lots of people want to do that.
                But it's not possible until Maxon adds that ability to the API.
                  On 27/09/2013 at 10:17, xxxxxxxx wrote:
                  It is possible. You can easily change the icon of the Cube plugin with this script.
                  > import c4d
                  > def set_icon(pluginid, bmp, overwrite_alpha=True) :
                  > icon = c4d.gui.GetIcon(pluginid)
                  > if not icon:
                  > return c4d.gui.RegisterIcon(pluginid, bmp)
                  > ref = icon['bmp']
                  > w, h = icon['w'], icon['h']
                  > temp = c4d.bitmaps.BaseBitmap()
                  > if temp.Init(w, h, bmp.GetBt()) != c4d.IMAGERESULT_OK:
                  > return False
                  > bmp.ScaleIt(temp, 256, True, True)
                  > a1 = a2 = None
                  > if overwrite_alpha:
                  > a1 = ref.GetInternalChannel()
                  > a2 = temp.GetInternalChannel()
                  > for x in xrange(w) :
                  > rx = x + icon['x']
                  > for y in xrange(h) :
                  > ry = y + icon['y']
                  > ref[rx, ry] = temp[x, y]
                  > if a1:
                  > if a2:
                  > alpha = temp.GetAlphaPixel(a2, x, y)
                  > else:
                  > alpha = 255
                  > ref.SetAlphaPixel(a1, rx, ry, alpha)
                  > return True
                  > def main() :
                  > fn = c4d.storage.LoadDialog()
                  > if not fn: return
                  > bmp = c4d.bitmaps.BaseBitmap()
                  > res = bmp.InitWith(fn)[0]
                  > if res != c4d.IMAGERESULT_OK:
                  > print "Invalid image:", res
                  > return
                  > set_icon(c4d.Ocube, bmp)
                  > c4d.gui.GeUpdateUI()
                  > c4d.EventAdd()
                  > main()
                  It is not possible to change the icon of an individual node, but that is also not a necessity when
                  working with a CommandData plugin.
                  Best,
                  -Niklas
                    On 27/09/2013 at 10:21, xxxxxxxx wrote:
                    Well actually it is Scott, my example above shows how to ;). But it is kind of black magic, as we
                    are meant to treat the BaseBitmap as readonly.
                      On 27/09/2013 at 10:46, xxxxxxxx wrote:
                      I think we're talking about different things.
                      Your code shows how to edit the read only bitmap file found in: resource\icons\interface_icons.tif
                      But a CommandData plugin does not use this file.
                      The CommandData plugin uses a flag in the GetState() method to toggle a check mark on/off
                          if(menustate) return CMD_ENABLED|CMD_VALUE;  //Enable the menu checkmark
                        else return CMD_ENABLED;                     //Turn off the menu checkmark
                      AFAIK. It's not possible toggle between two images instead of this checkmark.
                      There's nothing in the SDK that allows us to do this.
                      Many people have tried. No one has succeeded.
                        On 27/09/2013 at 11:48, xxxxxxxx wrote:
                        Not sure what you mean, for me it is just working fine. It actually does not matter if the
                        bitmap is located in the main icon file or somewhere else. Took a command data plugin
                        of mine and did a quick test.
                        import c4d, random
                        from c4d import bitmaps, gui
                        CMD_DATA_ID = 1030901
                            data = gui.GetIcon(CMD_DATA_ID)
                            bmp = data['bmp']
                            sx, sy = data['x'], data['y']
                            w, h = data['w'], data['h']
                            for px in xrange(sx, sx + w) :
                                for py in xrange(sy, sy + h) :
                                    bmp.SetPixel(px,py,255,0,0)
                            gui.GeUpdateUI()
                          On 27/09/2013 at 12:11, xxxxxxxx wrote:
                          Scott, the GetState() method has nothing to do with the icon of the command. As littledevil
                          already pointed out, it doesn't matter whether you modify an icon which originates from
                          Cinema's own icon-table bitmap. You are only modifying the copy in the RAM, not the one
                          on the HD.
                          Download the full plugin
                          > _<_t_>_
                          > 1
                          > 2
                          > 3
                          > 4
                          > 5
                          > 6
                          > 7
                          > 8
                          > 9
                          > 10
                          > 11
                          > 12
                          > 13
                          > 14
                          > 15
                          > 16
                          > 17
                          > 18
                          > 19
                          > 20
                          > 21
                          > 22
                          > 23
                          > 24
                          > 25
                          > 26
                          > 27
                          > 28
                          > 29
                          > 30
                          > 31
                          > 32
                          > 33
                          > 34
                          > 35
                          > 36
                          > 37
                          > 38
                          > 39
                          > 40
                          > 41
                          > 42
                          > 43
                          > 44
                          > 45
                          > 46
                          > 47
                          > 48
                          > 49
                          > 50
                          > 51
                          > 52
                          > 53
                          > 54
                          > 55
                          > 56
                          > 57
                          > 58
                          > 59
                          > 60
                          > 61
                          > 62
                          > 63
                          > 64
                          > 65
                          > 66
                          > 67
                          > 68
                          > 69
                          > 70
                          > 71
                          > 72
                          > 73
                          > import os
                          > import c4d
                          > def get_res_bitmap(filename) :
                          > result = bmp.InitWith(os.path.join(os.path.dirname(__file__), 'res', filename))
                          > if not result or result[0] != c4d.IMAGERESULT_OK:
                          > return None
                          > return bmp
                          > if not icon and bmp:
                          > elif icon and not bmp:
                          > return c4d.gui.UnregisterIcon(pluginid, bmp)
                          > elif not icon:
                          > return
                          > ref = icon['bmp']
                          > return False
                          > a1 = a2 = None
                          > if overwrite_alpha:
                          > rx = x + icon['x']
                          > ry = y + icon['y']
                          > if a1:
                          > if a2:
                          > else:
                          > alpha = 255
                          > return True
                          > class MyCommand(c4d.plugins.CommandData) :
                          > pluginid = 1000010 # TEST ID ONLY
                          > state = False
                          > bmp_a = get_res_bitmap('state-a.png')
                          > bmp_b = get_res_bitmap('state-b.png')
                          > def Register(self) :
                          > c4d.plugins.RegisterCommandPlugin(self.pluginid, "Icon Toggler", 0,
                          > None, "Execute to switch the icon of the command.", self)
                          > self.UpdateIcon()
                          > def UpdateIcon(self) :
                          > if not self.state:
                          > bmp = self.bmp_a
                          > else:
                          > bmp = self.bmp_b
                          > set_icon(self.pluginid, bmp)
                          > def Execute(self, doc) :
                          > self.state = not self.state
                          > self.UpdateIcon()
                          > return True
                          > if __name__ == "__main__":
                          > MyCommand().Register()
                          > <_<_t_>_
                          Best,
                          -Niklas
                            On 27/09/2013 at 13:01, xxxxxxxx wrote:
                            Thanks for the code Nik.
                            It doesn't solve the problem I was talking about.
                            But storing the icon in RAM is an interesting way to get around the problem.
                              I am not sure what problem you are talking about, could you pinpoint it for me please?
                              Best,
                              -Niklas
                                On 27/09/2013 at 14:44, xxxxxxxx wrote:
                                Well. It was a long time ago. And now I'm wondering if I'm remembering something else we were trying to do and having problems.
                                I can't remember if we couldn't update the CommandData icons in the menu. Or if it was the icons for a plugin that were docked in the UI. Or something like that.
                                The original poster commented about reading this problem on CGTalk. I'm guessing he was probably reading our old posts.
                                We were trying to swap images that were stored on the HD using COFFEE. But could not figure it out.
