    New Bevel Tool and SendModellingCommand
    5 Posts 0 Posters 635 Views
      On 17/09/2013 at 19:36, xxxxxxxx wrote:
      Cinema 4D Version:   15
      I am trying to update Chamfer Maker for R15. Since Chamfer Maker uses SendModellingCommand internally to do the actual bevels I was thinking I just need to update the BaseContainer settings to work with the new equivalent symbols that correspond to the settings for the new bevel tool.
      However I am finding that toolbevel.h still has the old symbols such as MDATA_BEVEL_OFFSET2 et al.
      In my short Python sample script though I see that when dragging the paramaters into the script editor from the new bevel tool that for example the Radius parameter is no longer called MDATA_BEVEL_OFFSET2 but MDATA_BEVEL_RADIUS and so on.
      Basically, I am looking to make the following snippet work with the new bevel tool:
      (the code uses the __LEGACY_API define)
              BaseContainer bc;
              bc.SetReal(MDATA_BEVEL_OFFSET2, data->GetReal(AMa_CHMMKR_RAD_a));
              bc.SetReal(MDATA_BEVEL_VARIANCE2, data->GetReal(AMa_CHMMKR_VARIANCE));
              bc.SetLong(MDATA_BEVEL_SUBDIVISION, data->GetLong(AMa_CHMMKR_SUBDIVISION));
              bc.SetBool(MDATA_BEVEL_CREATENGONS, data->GetBool(AMa_CHMMKR_CREATENGONS));
              bc.SetLong(MDATA_BEVEL_MODE, C4D_Bevel_Mode);
              bc.SetData(MDATA_BEVEL_PATH, ( data->GetData(AMa_CHMMKR_PATH)));
              bc.SetReal(MDATA_BEVEL_OFFSET1, data->GetReal(AMa_CHMMKR_EXTRUSION));
              bc.SetReal(MDATA_BEVEL_VARIANCE1, data->GetReal(AMa_CHMMKR_EXTRU_VARI));
              ModelingCommandData cd;
              cd.doc = op->GetDocument();
              cd.bc = &bc;
              cd.op = obj;
              cd.mode = MODELINGCOMMANDMODE_EDGESELECTION;
              cd.arr = NULL;
              chk = SendModelingCommand(ID_MODELING_BEVEL_TOOL, cd);
              if ( !chk) {
                  return FALSE;
      Thank you!
        On 17/09/2013 at 22:52, xxxxxxxx wrote:
        Hello you can find the new parameter definitions for new bevel in:
        cinemaFolder/resource/modules/modeling/res/xbeveltool.h
        pay attention also the command ID is changed you can find the correct id in command manager ID_MODELING_BEVEL_TOOL is no more valid.
        other than that the new bevel is a complete new system so some parameters are no more available and some other are new so i am sure you have to redesign part of your plugin.
        Franz
          On 17/09/2013 at 22:56, xxxxxxxx wrote:
          You can also find them here if it helps.
          http://c4dconnect.com/Description/Node?containerName=xbeveltool
            On 18/09/2013 at 03:31, xxxxxxxx wrote:
            Franz, thank you very much.
            For some reason my search for "bevel" didn't turn up the xbeveltool.h header file when I searched the _api folder.
            Thanks, kbar. That c4dconnect site is really cool. I shall bookmark it right away.
              On 21/09/2013 at 06:10, xxxxxxxx wrote:
              Hi
              I work  at AMA tools too.
              Seems Maxon moved to SetAction(431000015) // or new xBevelTool
              Upd.
              I was wrong, all work
