    setting keys for gradient
    14 Posts 0 Posters 1.9k Views
      On 17/09/2013 at 14:51, xxxxxxxx wrote:
      Hi Ferdinand,
      Thank you for your response.
      I am still missing something.
      When I pull the IDs, I get the following list:
      <c4d.BaseObject object called 'Shader/Shader' with ID 1018561 at 0x126ac8110>
      <c4d.BaseShader object called 'Gradient/Gradient' with ID 1011100 at 0x126ac85d0>
      <c4d.CTrack object called 'Gradient . Interpolation/Track' with ID 5350 at 0x126ac83d0>
      (1000, 15, 1000481)
      <c4d.CTrack object called 'Gradient . [1] Color . R/Track' with ID 5350 at 0x126ac8130>
      (1000, 19, 23)
      <c4d.CTrack object called 'Gradient . [1] Color . G/Track' with ID 5350 at 0x126ac88b0>
      (1001, 19, 23)
      <c4d.CTrack object called 'Gradient . [1] Color . B/Track' with ID 5350 at 0x126ac8550>
      (1002, 19, 23)
      <c4d.CTrack object called 'Gradient . [1] Intensity/Track' with ID 5350 at 0x126ac85b0>
      (10101, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [1] Position/Track' with ID 5350 at 0x126ac8250>
      (10102, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [1] Bias/Track' with ID 5350 at 0x126ac80b0>
      (10103, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [2] Color . R/Track' with ID 5350 at 0x126ac8430>
      (1000, 19, 23)
      <c4d.CTrack object called 'Gradient . [2] Color . G/Track' with ID 5350 at 0x126ac8910>
      (1001, 19, 23)
      <c4d.CTrack object called 'Gradient . [2] Color . B/Track' with ID 5350 at 0x126ac8290>
      (1002, 19, 23)
      <c4d.CTrack object called 'Gradient . [2] Intensity/Track' with ID 5350 at 0x126ac8510>
      (10201, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [2] Position/Track' with ID 5350 at 0x126ac8c50>
      (10202, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [2] Bias/Track' with ID 5350 at 0x126ac8b30>
      (10203, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [3] Color . R/Track' with ID 5350 at 0x126ac8590>
      (1000, 19, 23)
      <c4d.CTrack object called 'Gradient . [3] Color . G/Track' with ID 5350 at 0x126ac87f0>
      (1001, 19, 23)
      <c4d.CTrack object called 'Gradient . [3] Color . B/Track' with ID 5350 at 0x126ac8c10>
      (1002, 19, 23)
      <c4d.CTrack object called 'Gradient . [3] Intensity/Track' with ID 5350 at 0x126ac8f30>
      (10301, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [3] Position/Track' with ID 5350 at 0x126ac84f0>
      (10302, 19, 1000481)
      <c4d.CTrack object called 'Gradient . [3] Bias/Track' with ID 5350 at 0x126ac8150>
      (10303, 19, 1000481)
      <c4d.CTrack object called 'Gradient/Track' with ID 5350 at 0x126ac8190>
      (1007, 1000481, 1011100)
      <c4d.CTrack object called 'Gradient/Track' with ID 5350 at 0x126ac85f0>
      When I look at these IDs, I am not sure how the three different knots are differentiated for keying: They have the same three r, g, b IDs (1000, 19, 23), (1001, 19, 23), (1002, 19, 23).
      I also am not sure how to build the complete DescID from these descriptions.
      I know that the DescID is a collection of one or more DescLevels, though I think I read that there are a maximum of three. In the following experiment, for instance, I am assuming that there are two DescLevels: one for the main object, and one for the R channel of the colors for the knots.
      CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1000,19,23)), 1.0,10) #R channel
      But how would the system know this DescID pertains to only the first knot and not the second or third? I see in the name that there is this designation "Gradient . [3]"  that shows they are different, but where would this go in the DescID?
      None of my experiments are holding values. (I end up with gold dots beside the gradient field, not a red dot. Or when I try to insert something like DescLevel(c4d.SLA_GRADIENT_GRADIENT.[3]), I of course get errors.)
      I actually don't need to interpolate between graidents, so in one experiment, I assumed the following would set the key, but it doesn't work, either.
      CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT,0)), gradient, 50)
      Thanks again for all your help. Any comments are greatly appreciated.
        On 17/09/2013 at 21:58, xxxxxxxx wrote:
        please use [.code] tags to make your postings more readable. I am still not quite sure what is
        not working for you. I wrote a small example for creating an intensity and a color.r track for the
        first gradient knot in the c4d light object.visibility.color gradient. The Code is working for me (I
        do get a red dot). The approach is the one as described above, I simply used the console and
        Agent Ransack to unfold the DescLevels. I did convert some of the integer ids into their enum
        repr to make it more readable. 10100 is the id for the color vector, 10101 for the intensity.
        from c4d import gui
            dlevel_visgrad = c4d.DescLevel(c4d.LIGHT_VISIBILITY_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT, 0)
            did_intensity = c4d.DescID(dlevel_visgrad, c4d.DescLevel(10101, c4d.DTYPE_REAL, c4d.CUSTOMDATATYPE_GRADIENT))
            did_colr = c4d.DescID(dlevel_visgrad, c4d.DescLevel(10100, c4d.DTYPE_COLOR, 0), c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 23))
            ctrack_intens = c4d.CTrack(op, did_intensity)
            ctrack_colr = c4d.CTrack(op, did_colr)
            dic_intens = ctrack_intens.GetCurve().AddKey(doc.GetTime())
            dic_colr = ctrack_colr.GetCurve().AddKey(doc.GetTime())
            dic_intens['key'].SetValue(ctrack_intens.GetCurve(), 0.25)
            dic_colr['key'].SetValue(ctrack_colr.GetCurve(), 0.50)
            op.InsertTrackSorted(ctrack_intens)
            op.InsertTrackSorted(ctrack_colr)
          Hi Ferdinand,
          Thanks for your example. As you can see in the following code, I have a similar structure for the DescID—two DescLevels—but it doesn't work. Nor do I see how to set the different colors on different knots. Seems like there should be three DescLevels, though I have no idea what the second one would be.
          The following testing code does everything except work. LOL
          The file has a light and an effector shader in the object manager.
          Thanks again for your help.
          from c4d.modules import mograph as mo
          def CreateKey(obj,id,value,frame) :
            if not obj.GetDocument() : raise Exception, "object must be in a document"
            track=obj.FindCTrack(id)
            if not track:
                track = c4d.CTrack(obj,id)
                obj.InsertTrackSorted(track)
            curve=track.GetCurve()
            key=curve.AddKey(c4d.BaseTime(frame,doc.GetFps()))
            if type(value)==int or type(value)==float:
                key["key"].SetValue(curve,value)
                key["key"].SetGeData(curve,value)
          def GetNextObject(obj) :
            if obj==None:
                return None
            if obj.GetDown() :
                return obj.GetDown()
            while not obj.GetNext() and obj.GetUp() :
                obj = obj.GetUp()
            return obj.GetNext()
            obj = doc.GetFirstObject()
            if obj==None: return
            descid = obj.GetType()
            while obj:
                if descid == 5102: #If it is a light
                    lightObj = obj
                if descid == 1018561:
                    shaderObj = obj
                obj = GetNextObject(obj)
            r = float(64) / 255.0 #values to be read from database
            g = float(12) / 255.0
            b = float(123) / 255.0
            #key the light: This produces a gold dot in r15, a red dot in r13
            CreateKey(lightObj, c4d.DescID(c4d.DescLevel(c4d.LIGHT_COLOR,c4d.DTYPE_COLOR,0), c4d.DescLevel(c4d.VECTOR_X,c4d.DTYPE_REAL,0)), r, 0)
            CreateKey(lightObj, c4d.DescID(c4d.DescLevel(c4d.LIGHT_COLOR,c4d.DTYPE_COLOR,0), c4d.DescLevel(c4d.VECTOR_Y,c4d.DTYPE_REAL,0)), g, 0)
            CreateKey(lightObj, c4d.DescID(c4d.DescLevel(c4d.LIGHT_COLOR,c4d.DTYPE_COLOR,0), c4d.DescLevel(c4d.VECTOR_Z,c4d.DTYPE_REAL,0)), b, 0)
            gradient = shaderObj[c4d.SLA_GRADIENT_GRADIENT] #take the object as it is already constructed for testing
            shader = shaderObj.GetFirstShader()
            print shaderObj
            print shader
            #print out the IDs for reference
            for track in shader.GetCTracks() :
                print track
                print track.GetDescriptionID()
            #key the shader effector: This produces a gold circle in both r13 and r15. It also doesn't differentiate which knot it is setting the color for
            CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1000,19,23)), 0.0,10)
            CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1001,19,23)), 0.0,10)
            CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1002,19,23)), 0.0,10)
            #This is an example of trying to differentiate which knot to set
            #CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT.[1], c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1000,19,23)), 1.0,10)
            #CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT.[1], c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1001,19,23)), 0.0,10)
            #CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT.[1], c4d.CUSTOMDATATYPE_GRADIENT,0), c4d.DescLevel(1002,19,23)), 0.0,10)
            #example for keying the whole gradient, without its subchannels. It produces a gold dot in both r13 and r15
            #CreateKey(shader, c4d.DescID(c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT,0)), gradient, 50)
            On 17/09/2013 at 22:16, xxxxxxxx wrote:
            Hi Ferdinand,
            I ran your sample code, which, interestingly, produced a gold dot in r15 and a red one in r13. I wonder if I've been struggling because of a bug. . .
              On 17/09/2013 at 22:34, xxxxxxxx wrote:
              The DescID for the vector has to be a three level DescID. I am on R14, to lazy to switch to R15.
              About the red and golden dots : Do you have the timeline open / pressed play ? If not, it might
              be an update problem.
              Here is the same snippet a bit cleaner than the first one, it might show better why you do
              need three DescLevels to access the red channel in a vector inside a custom datataype.
              from c4d import gui
                  # the DescLevels we need
                  dlvl_grad = c4d.DescLevel(c4d.LIGHT_VISIBILITY_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT, 0)
                  dlvl_vecx = c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 0) # x is the red channel
                  dlvl_color = c4d.DescLevel(10100, c4d.DTYPE_COLOR, c4d.CUSTOMDATATYPE_GRADIENT)
                  dlvl_inten = c4d.DescLevel(10101, c4d.DTYPE_REAL, c4d.CUSTOMDATATYPE_GRADIENT)
                  # the two DescIDs to build the CTracks
                  did_col_r = c4d.DescID(dlvl_grad, dlvl_color, dlvl_vecx)
                  did_inten = c4d.DescID(dlvl_grad, dlvl_inten)
                  # the rest should be obvious
                  ctrack_col_r = c4d.CTrack(op, did_col_r)
                  ctrack_intens = c4d.CTrack(op, did_inten)
                  dic_col_r = ctrack_col_r.GetCurve().AddKey(doc.GetTime())
                  dic_col_r['key'].SetValue(ctrack_col_r.GetCurve(), 0.75)
                  op.InsertTrackSorted(ctrack_col_r)
                  # I do not know the proper message to invoke a gui_update for setting ctracks programmatically.
                  # You have either to open the Timeline manager or start the document playback to update the
                  # values, so that they are shown correctly in the AM.
                  op.Message(c4d.MSG_CHANGE)
                  op.Message(c4d.MSG_DESCRIPTION_CHECKUPDATE)
                On 17/09/2013 at 23:06, xxxxxxxx wrote:
                Hi Ferdinand,
                Thank you for your next clear example.
                I thought I'd need three DescLevels, at least.
                I see a distinction new to me: the third element of the last two DescLevel (c4d.CUSTOMDATATYPE_GRADIENT)—the origin—refers to a previous DescLevel datatype. I see it, but not sure what this means and how you knew to do this. I can not seem to find any definition of what the origin means in the DescLevel structure. Looks like it might be the link from one DescLevel to the next?
                I also don't yet see how this structure accommodates a gradient with three knots. In the Timeline, there is a folder that holds the three r, g, b tracks for each knot, another "level" in the organizing structure. There must be some mechanism for separating these tracks via the DescID and DescLevel classes.
                And thank you for the reference to the file examiner software, which is also new to me. I am on a mac, but I found  equivalent software and will use it to look at the files.
                Also, I did try several ways to update the display to see the values in r15, but none worked.  Even if I try to key the gradient by command-clicking in r15, I also get a gold dot, so something is off. I will send a note to Maxon about this. Given the number of attempts I've made to get the correct incantation for the DescIDs, I may have already solved the issue without knowing it due to a bug.
                I will study your example and re-read everything.
                Once again, thank you for your generous help.
                Robert
                  On 18/09/2013 at 01:09, xxxxxxxx wrote:
                  Nah, normally you do pass zero for t_creator. I did pass CUSTOMDATATYPE_GRADIENT,
                  because the DescLevel printed to the console was doing it that way, but the code does also
                  work with a 0.
                  (1000, 15, 1000481)
                  1000481 is CUSTOMDATATYPE_GRADIENT, 15 is the DTYPE_REAL and the 1000ish number is some
                  id in  the data type.
                  The format is of course dynamic, there is not a fixed set of ids because you could have dozens
                  of knots. You can see the structure in your own console listing :
                  Each knot has its own id range from n + 0 to n + 100. The general structure remains the same, so
                  that 10n00 is always the color and 10n01 is always the intensity. The r,g,b values get a folder
                  because they are parented to that c4d.Vector DescLevel (the 2nd DescLevel in the triple). If
                  you do know the c4d api a bit better you can tell alone from looking at (1000, 19, 23) that
                  that DescLevel is not sufficient to identify an element, as all the plugin IDs are at least 7
                  digits long, while sub ids (which only do have a meaning in combination with their enclosing
                  plugin id) are usually 4-5 digits long.
                  I cannot help you with your R15 problem, as I do not have R15 installed. I can only say that
                  DescLevels are a rather bumpy road in python (at least for me). In R14 DTYPE_BUTTON and
                  DTYPE_FILENAME went rogue which could lead to freezes and crashes in extreme cases. Sadly
                  these fundamental problems have not been fixed.
                  Happy rendering,
                    On 18/09/2013 at 04:26, xxxxxxxx wrote:
                    Thank you. I have the basic code working, even in r15.
                    The most helpful piece was explaining the second DescLevel and how it parents the last ones. I suppose we would see this pattern often.
                    Again, thanks for your generosity.
                    Here is the working code, should someone reference it.
                      if not track:
                      if obj==None:
                          return None
                      if obj.GetDown() :
                          obj = obj.GetUp()
                      while obj:
                              lightObj = obj
                              shaderObj = obj
                      print shaderObj
                      print shader
                          print track
                      dlvl_grad = c4d.DescLevel(c4d.SLA_GRADIENT_GRADIENT, c4d.CUSTOMDATATYPE_GRADIENT, 0)
                      dlvl_color_k1 = c4d.DescLevel(10100, c4d.DTYPE_COLOR, c4d.CUSTOMDATATYPE_GRADIENT)
                      dlvl_color_k2 = c4d.DescLevel(10200, c4d.DTYPE_COLOR, c4d.CUSTOMDATATYPE_GRADIENT)
                      dlvl_color_k3 = c4d.DescLevel(10300, c4d.DTYPE_COLOR, c4d.CUSTOMDATATYPE_GRADIENT)
                      dlvl_vec_r = c4d.DescLevel(c4d.VECTOR_X, c4d.DTYPE_REAL, 0) # x is the red channel
                      dlvl_vec_g = c4d.DescLevel(c4d.VECTOR_Y, c4d.DTYPE_REAL, 0) # y is the green channel
                      dlvl_vec_b = c4d.DescLevel(c4d.VECTOR_Z, c4d.DTYPE_REAL, 0) # z is the blue channel
                      did_r_k1 = c4d.DescID(dlvl_grad, dlvl_color_k1, dlvl_vec_r)
                      did_g_k1 = c4d.DescID(dlvl_grad, dlvl_color_k1, dlvl_vec_g)
                      did_b_k1 = c4d.DescID(dlvl_grad, dlvl_color_k1, dlvl_vec_b)
                      did_r_k2 = c4d.DescID(dlvl_grad, dlvl_color_k2, dlvl_vec_r)
                      did_g_k2 = c4d.DescID(dlvl_grad, dlvl_color_k2, dlvl_vec_g)
                      did_b_k2 = c4d.DescID(dlvl_grad, dlvl_color_k2, dlvl_vec_b)
                      did_r_k3 = c4d.DescID(dlvl_grad, dlvl_color_k3, dlvl_vec_r)
                      did_g_k3 = c4d.DescID(dlvl_grad, dlvl_color_k3, dlvl_vec_g)
                      did_b_k3 = c4d.DescID(dlvl_grad, dlvl_color_k3, dlvl_vec_b)
                      #key the shader effector GRADIENT
                      #First gradient and knots 1, 2, and 3 at first keyframe
                      CreateKey(shader, did_r_k1, 1.0,10)
                      CreateKey(shader, did_g_k1, 0.0,10)
                      CreateKey(shader, did_b_k1, 0.0,10)
                      CreateKey(shader, did_r_k2, 1.0,10)
                      CreateKey(shader, did_g_k2, 1.0,10)
                      CreateKey(shader, did_b_k2, 0.0,10)
                      CreateKey(shader, did_r_k3, 1.0,10)
                      CreateKey(shader, did_g_k3, 0.0,10)
                      CreateKey(shader, did_b_k3, 1.0,10)
                      #second gradient and knots 1, 2, and 3 at second keyframe
                      CreateKey(shader, did_r_k1, 0.5,20)
                      CreateKey(shader, did_g_k1, 1.0,20)
                      CreateKey(shader, did_b_k1, 0.5,20)
                      CreateKey(shader, did_r_k2, 0.2,20)
                      CreateKey(shader, did_g_k2, 1.0,20)
                      CreateKey(shader, did_b_k2, 0.2,20)
                      CreateKey(shader, did_r_k3, 1.0,20)
                      CreateKey(shader, did_g_k3, 0.7,20)
                      CreateKey(shader, did_b_k3, 1.0,20)
                      On 18/09/2013 at 11:14, xxxxxxxx wrote:
                        On 18/09/2013 at 11:15, xxxxxxxx wrote:
                        I see some of the code didn't copy over. Here is the complete code:
                          if not track:
                          if obj==None:
                              return None
                          if obj.GetDown() :
                              obj = obj.GetUp()
                          while obj:
                                  lightObj = obj
                                  shaderObj = obj
                          print shaderObj
                          print shader
                              print track
