    XRAY not working in ObjectPlugin
    8 Posts 0 Posters 679 Views
      On 11/09/2013 at 11:08, xxxxxxxx wrote:
      I'm trying to set the XRay parameter of a sphere created with an ObjectPlugin.
      However, it is not working in R13, R14 or R15?
      Note: Changing the radius in working.
      Here is the code:
      import c4d, os, sys
      from c4d import bitmaps, documents, gui, modules,  plugins, utils
      PXRAY = 1027
      PPREVIEWSIZE = 1028
      class C4DEnvironment(plugins.ObjectData) :
          def Init(self, op) :
              op[PXRAY] = False
              op[PPREVIEWSIZE] = 150
          def GetVirtualObjects(self, node, hierarchyhelp) :
              c4dnull = c4d.BaseObject(c4d.Onull)
              c4dnull[c4d.ID_BASELIST_NAME] = "C4Dome"
              preview = c4d.BaseObject(c4d.Osphere)
              preview.InsertUnder(c4dnull)
              preview[c4d.ID_BASEOBJECT_XRAY] = node[PXRAY]
              preview[c4d.PRIM_SPHERE_RAD] = node[PPREVIEWSIZE]
              return c4dnull
          pluginstr = "XRAY TEST"
          path, file = os.path.split(__file__)
          bmp = bitmaps.BaseBitmap()
          bmp.InitWith(os.path.join(path, "res", "lonlatsweep.tif"))
          okyn = plugins.RegisterObjectPlugin(id          = 102972625,
                                       str         = pluginstr,
                                       g           = C4DEnvironment,
                                       description = "c4de",               #link naar res directory, etc.
                                       icon        = bmp,
                                       info        = c4d.OBJECT_GENERATOR)
          if (okyn) :
              print pluginstr + " initialized."
          else: print "Error initializing " + pluginstr
      And here the res file:
      CONTAINER c4de
      	NAME c4de;
          INCLUDE Obase;
      	GROUP SETTINGS
              BOOL PXRAY {}
              REAL PPREVIEWSIZE { MIN 0; MAX 1000; STEP 1;}
        On 12/09/2013 at 00:14, xxxxxxxx wrote:
        Some further testing showed that it is working in a TagPlugin.
        Could it be that it is not working in a ObjectPlugin due to the fact that the sphere I want to xray is a virtual object?
          On 12/09/2013 at 04:29, xxxxxxxx wrote:
          Hi Pim,
          Yes I think the problem is that the object is a virtual object, I remember
          having a similar problem a very while ago. I'll do some research about it.
          Best,
          Niklas
            On 12/09/2013 at 06:01, xxxxxxxx wrote:
            the node (the gelistnode representing your plugin) has to be flagged ID_BASEOBJECT_XRAY
            to be drawn in the XRAY pass or the ID_BASEOBJECT_XRAY of your cached children won't have
            any effect. Your code should work when you do add
            > node[c4d.ID_BASEOBJECT_XRAY] = node[c4d.PXRAY]
            to your GVO method.
            edit : FYI, you might have to add c4d.OBJECT_POLYGONOBJECT as a plugin flag to your
            plugin registration to get the xray thing to show up in your description and therefore get
            whole thing to work. If you want to hide it then again you have to do that in your plugins
            description.
            INCLUDE Obase;
                HIDE ID_BASEOBJECT_XRAY;
              On 12/09/2013 at 07:21, xxxxxxxx wrote:
              Hi littledevil,
              Sorry, I do not fully understand following lines
              "FYI, you might have to add c4d.OBJECT_POLYGONOBJECT as a plugin flag to your
              description."
              I now have this code:
              node[c4d.ID_BASEOBJECT_XRAY] = node[PXRAY]
              However, the whole GVO object is now XRAY, not just the preview object.
              I also included HIDE ID_BASEOBJECT_XRAY;
              INCLUDE Obase; was already there.
                On 12/09/2013 at 08:03, xxxxxxxx wrote:
                What I meant with the quoted part is that without OBJECT_POLYGONOBJECT the xray checkbox
                in Obase is hidden by c4d by default ( if I do remember correctly ), so I thought the xray pass
                might also be skipped ( which does not seem to be the case from what you have described
                in your latest posting ).
                About the current problem - I do not think there is a way around. I have written recently a little
                object plugin replacing null objects. Long story short - I thought I could use the display color to
                return splines with various colors to draw some stuff into the viewport and have not to care so
                much about caching and speed. It turned out I could not (at least I did not find a way), as all GVO
                children always do inherit the display color of the hosting node in the object manager. I did end
                up drawing everything myself in Draw(). I think the same goes for the XRAY option, all children
                will inherit the nodes settings and their own settings will be overwritten.
                And then again, I do not know 100% for sure.
                  On 12/09/2013 at 08:26, xxxxxxxx wrote:
                  Try it like this:
                  import c4d, sys, os
                  from c4d import plugins, utils, bitmaps, gui,documents
                  PLUGIN_ID = 10000008        #be sure to get a unique plugin id from c4dcafe.com
                  class MyObject(plugins.ObjectData) :
                    def __init__(self) :
                        self.SetOptimizeCache(False)
                        self.myMaterial = c4d.BaseMaterial(c4d.Mmaterial)   #A class member reference to a new material
                        op.SetName("My Object")                      #op is the generator object
                        self.InitAttr(op, float, [c4d.P1])           #Init the values you defined in your res file
                        self.InitAttr(op, float, [c4d.P2])           #Init the values you defined in your res file
                    def Build(self,op) :
                        obj = c4d.BaseObject(c4d.Ocube)
                        doc.InsertMaterial(self.myMaterial)           #Insert the new material into the Material Manager
                        ttag = c4d.TextureTag()                       #Create a new texture tag
                        ttag.SetMaterial(self.myMaterial)             #Set the referenced material
                        obj.InsertTag(ttag)                           #Add the texture tag to the object in the OM
                        return obj.GetClone()
                    def GetVirtualObjects(self, op, hierarchyhelp) :
                        p1 = op[c4d.P1]                              #Get the value in this gizmo
                        print p1
                        p2 = op[c4d.P2]                                 #Get the value in this gizmo
                        if p2 == 1: op[c4d.ID_BASEOBJECT_XRAY]=True
                        else: op[c4d.ID_BASEOBJECT_XRAY]=False
                        ret = self.Build(op)                         #Assign a variable to the custom build function so we can use it later
                        ret.InsertUnder(op)                          #Insert the result from it into the OM as child of the generator object
                        return ret                                   #The object was built in the custom "Build" function...So that's what we return with the generator
                    icon = bitmaps.BaseBitmap()
                    icon.InitWith(os.path.join(dir, "res", "icon.png"))
                    plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="MyObject",
                                                g=MyObject,
                                                description="MyObject", icon=icon,
                                                info=c4d.OBJECT_GENERATOR)
                  .h file
                  #ifndef _MyObject_H_
                  #define _MyObject_H_
                  enum
                    P1 = 1000,
                    P2 = 1001,
                  #endif
                  .res file
                  CONTAINER MyObject
                    NAME MyObject;
                    INCLUDE Obase;
                    GROUP ID_OBJECTPROPERTIES
                        GROUP
                          REAL P1 { UNIT METER; MIN 0.0; }
                          BOOL P2 {  }
                  The .str file
                  STRINGTABLE MyObject
                    MyObject        "My Object";
                    P1                 "Value";
                    P2               "x-ray";
                    On 12/09/2013 at 11:36, xxxxxxxx wrote:
                    Thanks Scott,
                    I tried your code, but it XRAYS all virtual objects. and not the want I want.
                    E.g. I simplified the code to generate a cube with a sphere as a child.
                    Then I tried to xray just the sphere and that is not working.
                    XRAY op is xray-ing everything
                    XRAY just the sphere is not working.
                            cube = c4d.BaseObject(c4d.Ocube)
                            sphere = c4d.BaseObject(c4d.Osphere)
                            sphere.InsertUnder(cube)
                            sphere[c4d.PRIM_SPHERE_RAD] = 150
                            if p2 == 1: sphere[c4d.ID_BASEOBJECT_XRAY]=True
                            else: sphere[c4d.ID_BASEOBJECT_XRAY]=False
                            return cube
