    How to implement tooltips like BitmapButton
    6 Posts 0 Posters 604 Views
      On 29/08/2013 at 06:25, xxxxxxxx wrote:
      Cinema 4D Version:   R12-R15
      Language(s) :
      Hi folks,
      I wonder how to implement tooltips as it's done in the BitmapButtonCustomGui. It would be nice if I could do something similiar to display descriptions of selected items in our browser plugin (basically a big user area in which we draw rectangular items).
      Is this even possible without using OS functions?
      Thanks in advance,
      Satara
        On 29/08/2013 at 08:11, xxxxxxxx wrote:
        I think it is not the way its done by c4d, but you could use a dialog (as they already used for almost
        everything). DLG_TYPE_ASYNC_POPUPEDIT will open a dialog without a menu bar and a
        window frame.
          On 29/08/2013 at 08:23, xxxxxxxx wrote:
          BFM_GETCURSORINFO is sent to GeDialog::Message(). I didn't try it myself, but among the
          documentation, you can define a tooltip text at any position for any element at any time.
          > #### BFM_GETCURSORINFO_<_h4_>_
          > You can respond this message if you want to display any helpinformations in the bubblehelp or global statusbar.
            On 30/08/2013 at 00:22, xxxxxxxx wrote:
            Thanks for the fast replies!
            I think using BFM_GETCURSORINFO would be the cleaner way and it seemed to be very promising, but I couldn't make it work 😞
            This is how I have tried it:
            LONG ImageArea::Message(const BaseContainer& msg, BaseContainer& result)
                if (msg.GetId() == BFM_GETCURSORINFO)
                    LONG mx = msg.GetLong(BFM_DRAG_SCREENX);
                    LONG my = msg.GetLong(BFM_DRAG_SCREENY);
                    if (m_highlightedItem != NOTOK)
                        result.SetBool(RESULT_SUPPRESSBUBBLE, FALSE); // already FALSE
                        result.SetString(RESULT_BUBBLEHELP_TITLE, "bubble help title");
                        result.SetString(RESULT_BUBBLEHELP, "-- Here should be the description --");
                        result.SetString(RESULT_HELP1, "Test1");
                        result.SetString(RESULT_HELP2, "Test2");
                        result.SetString(RESULT_HELP3, "Test3");
                        result.SetString(RESULT_HELP4, "Test4");
                return GeUserArea::Message(msg, result);
            Also found this related topic, with the same problem, but no solution: Dialog BubbleHelp?
              On 30/08/2013 at 04:11, xxxxxxxx wrote:
              Same here. But this works
                  virtual Bool Message(const BaseContainer& msg, BaseContainer& result) {
                      switch (msg.GetId()) {
                          case BFM_GETCURSORINFO: {
                              **result.SetId(BFM_GETCURSORINFO);**
                              result.SetLong(RESULT_CURSOR, MOUSE_BUSY);
                              result.SetString(RESULT_BUBBLEHELP_TITLE, "Bubble Help Title");
                              result.SetString(RESULT_BUBBLEHELP, "Cool description stuff here.");
                              result.SetString(RESULT_HELP1, "RESULT_HELP1");
                              result.SetString(RESULT_HELP2, "RESULT_HELP2");
                              result.SetString(RESULT_HELP3, "RESULT_HELP3");
                              result.SetString(RESULT_HELP4, "RESULT_HELP4");
                              break;
                      return super::Message(msg, result);
              This is nowhere documented, but it was an idea and I gave it a shot. And now it works! 🙂
              You have to set the ID of the result container to BFM_GETCURSORINFO.
              Edit: Removed print line, it was a left over of stripping the code.
                On 30/08/2013 at 04:21, xxxxxxxx wrote:
                Woow awesome 😄 Can't believe that it's working 🙂 Thx mate!
