    Log Generator
    7 Posts 0 Posters 638 Views
      On 18/08/2013 at 16:39, xxxxxxxx wrote:
      Hi
      I Look for an Way to Log Errors and save them
      Also is there a Way to Generate a System Description with Details of the Computer and Version of c4d
      I like to get a Way to get Most detailed error Reports
        On 18/08/2013 at 22:09, xxxxxxxx wrote:
        Take a look at the logging module, it is part of the Python STL.
        -Niklas
          On 19/08/2013 at 01:30, xxxxxxxx wrote:
          In the c4d module you can find various methods to retrieve OS and c4d related informations, you
          can also retrieve your gpu specs from the WPREF container. The python stl module platform can
          be used to retrieve OS and CPU related informations. Some of these informations can also be
          found in the environment dict.
          http://docs.python.org/2/library/platform.html
          I am not sure what is meant with errors in this context. I guess you are speaking of runtime
          errors / exceptions. There is no method to automatically redirect exceptions in Python (at least
          I do not know one), so you will have to stick with the try/except syntax to track them. From the
          except branches in your code you could feed then a logger class to generate a log string. You
          could also build an generic exception class wrapping other exceptions, which would pass the
          the exception string to your logger.
          http://docs.python.org/2/tutorial/errors.html
            On 21/08/2013 at 15:18, xxxxxxxx wrote:
            thanks
            with errors i mean the errors messages with come up in the console
              On 28/12/2013 at 11:47, xxxxxxxx wrote:
              to bring it up again -
              the logging work great
              is there a way to get the content of the console ?
                On 29/12/2013 at 07:42, xxxxxxxx wrote:
                You could overwrite sys.stdout with your own file-like object that redirects the write() calls to the original
                stdout and your own file. You should prefer to use your own printing mechanism however to not break
                other plugins or scripts in case your implementation is buggy.
                > import logging
                > import cStringIO as cstio
                > logfile = cstio.StringIO()
                > logger = logging.Logger("conner's logger")
                > logger.addHandler(logging.StreamHandler(logfile))
                > logger.addHandler(logging.StreamHandler(sys.stdout))
                > def get_log(self) :
                >     logfile.seek(0)
                >     data = logfile.read()
                >     logfile.seek(0, 2)
                >     return data
                Simply put everything into the logger instead of using the print keyword.
                Best,
                -Niklas
                  On 29/12/2013 at 07:55, xxxxxxxx wrote:
                  hey Niklas,
                  thanks for your detailed answer.
                  your logging example is great. my problem is i don`t get the errors like this
                    File "'stage.pyp'", line 1848, in all
                  AttributeError: parameter access failed
