    Selected text in Multistring field?
    11 Posts 0 Posters 1.0k Views
      On 14/08/2013 at 05:33, xxxxxxxx wrote:
      have you tried bfm_action ?
        On 14/08/2013 at 06:31, xxxxxxxx wrote:
        Thanks first of all. BFM_ACTION was what I meant! However, none of the actual action states give me the current text selection afai can see. 😕
          On 14/08/2013 at 07:16, xxxxxxxx wrote:
          hm, there are also these ids in bfm_message :
          _<_t_>_
          BFM_EDITFIELD_GETCURSORPOS
          Returns the cursor position in an edit field (LONG[URL-REMOVED]).
          BFM_EDITFIELD_GETBLOCKSTART
          Returns the block start position in an edit field (LONG[URL-REMOVED]).
          <_<_t_>_
          sounds that the range between those could be the selected range, but i have never used them, so i might be wrong.
            On 14/08/2013 at 07:54, xxxxxxxx wrote:
            Yeah I had found these but they only seem to be for LONG edit fields (at least that was my assumption with the LONG statement), but I will try them. Thanks!
              This is a snippet from my free AutoComplete plugin that finds the last word in a text box:
              /////////////// This section gets the last word of text the user types into the texbox /////////////////
               String allWords;                      //This will hold the entire text in the textbox
               String lastWord;                      //This will hold the last word that is typed into a text box
                if (msg.GetId()==BFM_GETCURSORINFO)
                    if(GetString(MY_MULTIBOX, allWords))
                        LONG length = allWords.GetLength();
                        LONG pos = NULL;                                     //The variable that will hold the position of the string
                        Bool lastSpace = allWords.FindLast(" ",&pos, -1);    //Find the last blank space and store it's position in the string
                        if(pos>0)                                            //If there is at least one empty space found
                           lastWord = allWords.SubStr(pos+1, length - pos);  //Grab the last word (sub string)
              Hope that helps,
                On 14/08/2013 at 07:55, xxxxxxxx wrote:
                thanks Scott. Browsing strings is not the issue but I really need the selected text.
                  On 14/08/2013 at 08:05, xxxxxxxx wrote:
                  I understood LONG in that way, that those container ids are of type LONG, providing the caret
                  and block position as an integer value.
                    On 14/08/2013 at 08:12, xxxxxxxx wrote:
                    And I think you are absolutely right. Now that I also see SETCURSORPOS it seems pretty obvious. Thanks, I check if these work!
                      On 14/08/2013 at 15:47, xxxxxxxx wrote:
                      This is the solution I came up with for getting the selected text in a GeDialog() text box:
                      LONG myDialog::Message(const BaseContainer &msg, BaseContainer &result)
                        String text;
                        this->GetString (1001, text);   //Get the text in the text box (1001 is the id for the edit text gizmo)
                        if(GetString(1001, text))       //If the edit text gizmo is not empty
                            //The cStart value is the position in the text where you started dragging(highligthing the text)
                            //The cPos value is the current position the cursor is in
                            //The range of selected text characters = cPos-cStart
                            BaseContainer blockStart(BFM_EDITFIELD_GETBLOCKSTART);
                            GeData bs = SendMessage(1001, blockStart);
                            LONG cStart = bs.GetLong();
                            BaseContainer cursorPos(BFM_EDITFIELD_GETCURSORPOS);
                            GeData cp = SendMessage(1001, cursorPos);
                            LONG cPos = cp.GetLong();
                            LONG numSelected = cPos-cStart;     //The number of selected text characters
                            String selected = "";
                            if(numSelected >= 1)               //If the user selected the text from left to right
                                GePrint("Start: " + LongToString(cStart) + " " + "Pos: " + LongToString(cPos) + " " + "NumSel: " + LongToString(numSelected));
                                for (LONG i=0; i<numSelected; i++)
                                    String s = text.SubStr(cStart+i, 1);
                                    String combine = selected.operator+=(s);    //Adds the current char to the "selected" string variable
                            GePrint(selected);
                        return GeDialog::Message(msg,result);
                      Seems to work pretty well.
                      But I'm always interested in seeing how other people solve things. I learn new things that way.
                      So if you figured out another way to so it. I'd love to see what you came up with.
                        On 28/08/2013 at 01:29, xxxxxxxx wrote:
                        Hi Scott,
                        thanks for your example. Anyway, this only seems to work for a normal text field not a multistring field. In a multistring field the values are always 0.
                        So there is no way to retrieve this in a multistring (multiline) field (question pointed at support)?
