    CreateLayout in ObjectPlugin without res file
    6 Posts 0 Posters 505 Views
      On 06/08/2013 at 07:08, xxxxxxxx wrote:
      Hi. Probably silly question, but I cannot figure out how to create layout without res file:
      Am I missing something? Thank you.
      from c4d import gui, plugins, utils
      import os, random
      PLUGIN_ID = 3333333
      PLUGIN_NAME = "pluginname"
      PLUGIN_DESCRIPTION = "Opluginname"
      class MYPLUGIN(c4d.plugins.ObjectData) :
          def CreateLayout(self) :
              self.SetTitle("My Dialog")
              self.GroupBegin(id=100010, flags=0, cols=1, rows=1)
              self.AddGroupSpace(4, 4)
              self.AddGroupBorderSpace(4, 4, 4, 4)
              self.AddStaticText(id=100011, flags=0, name="Hello World!")
              self.GroupEnd()
          fn = os.path.join(dir, "res", "Icon.tif")
          bmp.InitWith(fn)
          result = plugins.RegisterObjectPlugin(
              id=PLUGIN_ID, str=PLUGIN_NAME, g=MYPLUGIN, description="", info=c4d.OBJECT_GENERATOR, icon=bmp
        On 06/08/2013 at 07:24, xxxxxxxx wrote:
        Hi Tomas,
        There's no CreateLayout() for data plugins. You can only use .res files description.
        Do not confound descriptions and dialogs. CreateLayout() is only defined for dialogs.
          On 06/08/2013 at 07:25, xxxxxxxx wrote:
          I see. I thought so:)
          Thanks for clearing this out for me. Appreciate that.
            On 06/08/2013 at 08:53, xxxxxxxx wrote:
            On the other hand, if I build buy GUI in res file, can I make some elements greyed out, depending on what settings/buttons are pressed by user?
              On 06/08/2013 at 08:59, xxxxxxxx wrote:
              Yes, you can override NodeData.GetDEnabling() and depending on the passed id return True to enable or False to disable the description parameter.
              Here's how it's implemented in Py-DoubleCircle example:
              def GetDEnabling(self, node, id, t_data, flags, itemdesc) :
                      data = node.GetDataInstance()
                      if data is None: return
                      inter = data.GetLong(c4d.SPLINEOBJECT_INTERPOLATION)
                      if id[0].id==c4d.SPLINEOBJECT_SUB:
                          return inter==c4d.SPLINEOBJECT_INTERPOLATION_NATURAL or inter==c4d.SPLINEOBJECT_INTERPOLATION_UNIFORM
                      elif id[0].id==c4d.SPLINEOBJECT_ANGLE:
                          return inter==c4d.SPLINEOBJECT_INTERPOLATION_ADAPTIVE or inter==c4d.SPLINEOBJECT_INTERPOLATION_SUBDIV
                      elif id[0].id==c4d.SPLINEOBJECT_MAXIMUMLENGTH:
                          return inter==c4d.SPLINEOBJECT_INTERPOLATION_SUBDIV
                On 06/08/2013 at 09:02, xxxxxxxx wrote:
                Oh ok, that makes a lot of sense. Will investigate your code. Thanks for your input.
