    SUPER:: - must be a class or namespace name..
    7 Posts 0 Posters 693 Views
      On 10/06/2013 at 10:38, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi, some plugins use this:
      return SUPER::BlaBla_foo(x, y, z);
      the hashmap.h uses this:
      Super::ConstIterator::operator++();
      but I can't. I get "name followed by '::' must be a class or namespace name"
      I do use this:
      ObjectAncestor::BlaBla_foo(x, y, z);
      but I wonder how other can use SUPER / Super and to what extent it has any purpose / is better than just using the name of the ancestor.
        On 10/06/2013 at 10:41, xxxxxxxx wrote:
        SUPER is coming from this macro.
        You can use it only if you have INSTANCEOF(Object,ObjectAncestor) in you class.
            	#define INSTANCEOF(X,Y)                  \n    		public:                                \n    			typedef Y SUPER;                     \n    		private:
        Actually it is the same, just using some macro magic.
          On 10/06/2013 at 10:55, xxxxxxxx wrote:
          Thanks a lot!
          I will stick to my usual way of doing things then.
          In C# there is something called "Base" which is intrinsic so to say.
            On 11/06/2013 at 03:16, xxxxxxxx wrote:
            I suggest you to just use
            class MyClass : public BaseClass {
                typedef BaseClass SUPER;
            instead. The INSTANCEOF macro is in my eyes nothing but confusing. I've also
            never need to have it public, so you can usually skip that as well.
              On 11/06/2013 at 04:49, xxxxxxxx wrote:
              Why not use Super instate like hashmap?
              Or even Base like in C# then ?  🙂
                      typedef BaseClass Super;
                      typedef BaseClass Base;
                On 11/06/2013 at 05:11, xxxxxxxx wrote:
                Personally, I use the lower-case "super" (like Python, Java)
                  On 11/06/2013 at 08:26, xxxxxxxx wrote:
                  Yep, that's also my default typedef.
