    Including description elements
    5 Posts 0 Posters 491 Views
      On 07/06/2013 at 02:40, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      I have problems including descriptions when using inheritance.
      This is the root class
      CONTAINER Trootclass
      	GROUP GROUP_ROOTCLASS
      		BUTTON BUTTON_ROOTCLASS {}
      And this is the descendant
      CONTAINER Tdescendant
      	 **INCLUDE Trootclass;**
      	GROUP GROUP_DESCENDANT_CLASS
      		BUTTON BUTTON_DESCENDANT {}
      When using the blue alternative, I do not see the root class button at all.
      When using the red alternative, I  see the root class button, yes. But it behaves strange, I cannot select the GROUP_ROOTCLASS at all in the Attributes Manager in C4D, something is not working here..
      How do I use the INCLUDE directive correctly, or furthermore - what have I done wrong?
        On 07/06/2013 at 03:39, xxxxxxxx wrote:
        Have you tried including Tbase to the Trootclass?  I think that it would be required (even if you aren't using the base groups).
          On 07/06/2013 at 04:39, xxxxxxxx wrote:
          Yes it is there, I omitted it here in the forum to not clutter my code.
          But I made a mistake in my initial post, it is the Descendant's controls  that do not show up when I use the "blue" approach. The root controls are there all right.
          But have I misunderstood? I am supposed to see both the root's controls and the descendant's controls? Right?
            On 07/06/2013 at 04:56, xxxxxxxx wrote:
            Ok, I found the culprit.
            I had the enum for IDs starting on the same value, for both the root and the descendant, in their header files. So changing this fixed it.
              It isn't required. 🙂
              But if you do not register the description along with a plugin,
              you have to register it with RegisterDescription().
