    Sliders don't change my object anymore
    1 Posts 0 Posters 147 Views
      On 05/06/2013 at 15:24, xxxxxxxx wrote:
      Hey,
      I have placed my functions to create objects in another file.
      They get called when a button is pressed. In the same Command-method the objects need to be changed, depending on some sliders.
      It all worked fine, untill I replaced my functions. The other files loads properly, the function as well, the objects get created. However, when I change the sliders, the objects won't change.
      First it gave an Error that global "L_Foot" isn't defined. Then I defined them again in my main file, and the error was gone, but still the objects won't change.
      Here's a snippet of my code:
      def Command(self, id, msg) :     #Commands
            if (id == 10002) :           #Button Create Character
                GENDER = self.GetLong(10001)
                print GENDER
                AddLeftFoot(doc)
                AddRightFoot(doc)
                AddLeftToes(doc)
                AddRightToes(doc)
                AddLeftLeg(doc)
                AddRightLeg(doc)
                AddLeftThigh(doc)
                AddRightThigh(doc)
                AddHip(doc)
                AddBody(doc)
                AddLeftArm(doc)
                AddRightArm(doc)
                AddLeftUpperArm(doc)
                AddRightUpperArm(doc)
                AddLeftLowerArm(doc)
                AddRightLowerArm(doc)
                AddLeftWrist(doc)
                AddRightWrist(doc)
                c4d.CallCommand(17105) # Gouraud Shading (Lines)
                c4d.CallCommand(12148) # Frame Geometry
            #Sliders#
      ### Left_Foot SLiderCode
            L_Foot = c4d.PolygonObject(8, 6)
            if id in (FOOT_X_SLIDER, FOOT_Y_SLIDER, FOOT_Z_SLIDER, FOOT_AXIS_X_SLIDER, LEG_X_SLIDER, LEG_Z_SLIDER) :
                FOOT_X = self.GetReal(FOOT_X_SLIDER)
                FOOT_Y = self.GetReal(FOOT_Y_SLIDER)
                FOOT_Z = self.GetReal(FOOT_Z_SLIDER)
                FOOT_AXIS_X = self.GetReal(FOOT_AXIS_X_SLIDER)
                LEG_X = self.GetReal(LEG_X_SLIDER)
                LEG_Z = self.GetReal(LEG_Z_SLIDER)
                L_Foot.SetPoint(0, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (ZERO), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(1, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (FOOT_Y), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(2, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (ZERO), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(3, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (FOOT_Y), (-LEG_Z/2.0 -(FOOT_Z -LEG_Z) +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(4, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (ZERO), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(5, c4d.Vector((FOOT_AXIS_X +FOOT_X/2.0), (FOOT_Y), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(6, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (ZERO), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0)))
                L_Foot.SetPoint(7, c4d.Vector((FOOT_AXIS_X -FOOT_X/2.0), (FOOT_Y), (LEG_Z/2.0 +(FOOT_X -LEG_X)/2.0)))
                L_Foot.Message(c4d.MSG_UPDATE)
      Any ideas how to fix it???
      Thanx in advance for any or no answers 🙂
