    Compiling for Mac - outsource it?
    20 Posts 0 Posters 2.3k Views
      On 03/06/2013 at 11:30, xxxxxxxx wrote:
      It also might be worth pointing out that, AFAICS, clang is a much stricter compiler than VS when it comes to adhering to C++ standards. So that code which builds fine on a PC might not on a Mac. If you get someone else to compile your Mac plugin, then they might also have to correct your code so that Xcode will compile it. Which means that they need some degree of Xcode and C++ expertise and that (not unreasonably) they would expect some payment for the work done.
      Steve
        Yes this is true.
        By the way do some one know the way to force Visual Studio C++ to report more warnings that are errors for Clang ?
          On 03/06/2013 at 13:07, xxxxxxxx wrote:
          So that code which builds fine on a PC might not on a Mac.Yes this is true.By the way do some one know the way to force Visual Studio C++ to report more warnings that are errors for Clang ?
          You might try using the Intel compiler (which integrates into MSVC); while not supporting the full C++11 standard and not giving as good error or warning messages as clang, it does support more C++11 features than MSVC, is also quite strict.
          MSVC currently delivers the weakest C++11 support of this 3 compilers, has some nasty bugs in lamdbas (when passing params) and returns not very useful error messages when having template problems.
          Best regards,
          Wilfried
            Macs support a lot of partitions (contrary to Windows)
            This I did not understand, apart from that, a very interesting post, Wilfried! Now I learnt this! It will take some time before I switch to Mac, though..😄
              This I did not understand [..]
              (I was replying on the statement that you need several Macs to support different XCode & OS X versions).
              On Windows you've four basic partition slots. You can either use them as primary partition (which is necessary to boot Windows) or you can mix primary and extened partitions (but you can't use those to boot Windows); e.g one as primary, 3 as extended partitions.
              Now try to install XP, Server 2008, Vista, Win7 & Win8 on a drive (you might need that for compatiblity tests...) - you can't as you're running out of primary partitions.
              On the Mac (assuming the hw is supported by the OS) you don't have this limitation.
              Best regards,
              Wilfried
                You only have this limitation if you use Master Boot Record ( MBR ).
                With GUID Partition Table ( GPT ) you do not have this limitation too.
                As far as I know Win XP do not support GPT.
                But for Win XP one could also use VirtualBox for example.
                  Here:
                  http://www.terabyteunlimited.com/bootit-bare-metal.htm
                  "Create over 200 primary partitions on EMBR disks"
                  Yes, I have had machines where I have had 2, or maximum 3 operating systems installed. But after I started to use VMware, I do not need it. I have VMware "machines" of all Windows versions, Win 3.11, Win 95, Win 2000, Win XP, Vista, as well as some of the the server versions. I need those sometimes when testing applications  for  my customers. In VMware I have several "snapshots", so that I can test various versions of various browsers on various operating systems. And so on. I always have clean operating systems ready for testing.
                  The more interesting question is why one would want to, and especially why one would need to have more than 4 primary partitions on Windows, nowadays. I now run Windows 7 64 bit, and have never had a better OS ever. I will not look back, and have no need to either, apart from the aforementioned tasks when testing software. I then fire up VMware, and am good to go.
                    [...] The more interesting question is why one would want to, and especially why one would need to have more than 4 primary partitions on Windows, nowadays. I now run Windows 7 64 bit, and have never had a better OS ever. I will not look back, and have no need to either, apart from the aforementioned tasks when testing software. I then fire up VMware, and am good to go.
                    As much as I like using Windows in a VM when working on OS X (being able to fix project files or other stuff on both systems without rebooting is a big time saver), but for some compatiblity tests VMs aren't sufficient - think of gfx card drivers, audio drivers (which changed massively between XP & Vista and had a lot of fixes in Win7 that you don't find in Vista), ...
                    VMs are fine as long as their overhead, compatiblity problems of the emulation (GL...), lower network performance or inaccuracy of the timer doesn't matter. If it does, you need real hardware.
                    Best regards,
                    Wilfried
                      On 04/06/2013 at 15:33, xxxxxxxx wrote:
                      Yes, that is right. And some software even refuse to run on VMs. If you really need physical machines,  you probably want 1) a separate PC, 2) will not have the 4 partition limit on Windows because you can use Terabyte or a similar utility, supporting EMBR. I have used Terabyte BootIt a long time, not because I needed more than 4 partitions, but because of other nice features it has.
                        Thanks for the tip. Any experience how it deals with damaged MBRs (e.g. one you get when installing Vista when having Linux with grub installed) or when dealing with multiple OS installations (Linux & win) and their partitioning programs (e.g. parted); which repair capabilities does it have?
                        From my experience with other 3rd party boot/partioning tools that often has been the archilles heel (resulting in no partitions working at all in the end).
                        Best regards,
                        Wilfried
                          On 05/06/2013 at 03:29, xxxxxxxx wrote:
                          Hi Wilfried, for damaged MBRs, I used a piece of freeware, I do nor remember the name, it was a rather obvious name, "fix MBR" or something in that direction. I can find it, of you wish, I haven't used it in 2-3 years now.
                          About TeraByte, I was recommended it by someone who works a lot with partitions, multiple OS on a machine and such. It costs money, which it is well wort, and it comes with a huge documentation, almost a book on its own, a real study.. I have used a only fraction of its features.
                          But if you run multiple OS, you want a boot prompt in any case, to select the OS to boot into. And that is mostly how I have used it. It has tons of features though, wish I had time to understand more of it.
                          If you do it in the right order, that is add OSs in the right order, I think you can install many different operating systems, yes. For practical use in 2013, I guess XP is the oldest Windows OS you may want. And Linux - I have only tested it in VMware, so I just do not know. Actually, these things is a profession on its own. In a job I had some years ago, we had on guy dealing only with this 🙂
                          Installing, testing, "Ghosting" test machines etc.
