    How to add a tag to an object
    5 Posts 0 Posters 386 Views
      On 01/06/2013 at 21:13, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      How do I add a tag to an object? I have no problems cloning tags, like this.
      BaseTag* tagFound = someObject->GetFirstTag();
      BaseTag* newTag = (BaseTag* )tagFound->GetClone(COPYFLAGS_0, NULL);
      anotherObject->InsertTag(newTag, NULL);
      But how do I
      a) Insert one of the C4D built in tags, like the Constraint tag
      b) Insert one of my own tags.
      For (a) I just do not know. For (b) I get error messages. Mainly because my tags are
      class MySpecialTag : public TagData
      and I get complaints about  MySpecialTag not being a BaseTag*.
      Any ideas?
        On 02/06/2013 at 00:11, xxxxxxxx wrote:
        a)
        BaseTag* tag = BaseTag::Alloc(Tcaconstraint);
        if (tag) obj->InsertTag(tag, NULL);
        You will need to include the modules/ca/res in your search path and include "Tcaconstraint.h" in order to have the enumeration.
        b)
        BaseTag* tag = BaseTag::Alloc(MYPLUGIN_ID);
          On 02/06/2013 at 02:48, xxxxxxxx wrote:
          You can have it even easier:
          BaseTag *tag = obj->MakeTag(Tcaconstraint);
          This will allocate and insert the tag in one single call. Don't forget to check the result for NULL, though.
            On 02/06/2013 at 03:45, xxxxxxxx wrote:
            Well, I think that I have had issues with adding undos using MakeTag().  But if that behavior has changed, by all means use that instead.
              On 02/06/2013 at 03:49, xxxxxxxx wrote:
              Thanks a whole bunch! I will test it out, as soon as I have sorted out a few other issues. And Undo is important, yes.
