    How to implement ConvertFromGv for general objects
    1 Posts 0 Posters 159 Views
      On 30/05/2013 at 05:19, xxxxxxxx wrote:
      Cinema 4D Version:   R13
      Language(s) :     C++  ;  XPRESSO  ;
      I'm trying to make my custom data type and want to convert a general object (ID_GV_VALUE_TYPE_GENERAL_OBJECT) to the my type. I'm following the example of cinema4dsdk sample project, but I'm getting an AccessViolation crash in ConvertFromGv method.
      The example in cinema4dsdk defines a magic structure GvObject and uses it to cast the src parameter of ConvertFromGv method. This is the code:
      struct GvObject
        BaseList2D*    object;
        LONG                type;
      virtual GvError ConvertFromGv(LONG type,const void *const src,LONG cpu_id,CustomDataType *dst)
            iExampleDataType *d = (iExampleDataType* )dst;
            switch (type)
                case 400006000: // ID_GV_VALUE_TYPE_GENERAL_OBJECT
                        GvObject *s = &((GvObject* )src)[cpu_id];
                        if (s->object) d->sdata = s->object->GetName();
                        else d->sdata = "<<no object>>";
      d->ldata = -1;
      return GV_CALC_ERR_NONE;
      It seems that this is not the right structure of the src void pointer.
      Does anybody know what is the structure of the src pointer in case of ID_GV_VALUE_TYPE_GENERAL_OBJECT type (for Cinema4D R13 version)?
      Thank you.
