    BitmapButton toggle id
    7 Posts 0 Posters 646 Views
      On 26/05/2013 at 07:06, xxxxxxxx wrote:
      can anyone point me to the correct BFM_MESSAGE id to call a toggle BitmapButton click in a
      GeDialog / toggle its state ? I have that code which does work in general (it does disable
      the button, but i want to toggle it as described).
      def Execute(self, doc) :
          fhPolyTools.ID_ISFROZEN = not fhPolyTools.ID_ISFROZEN
          tool = plugins.FindPlugin(doc.GetAction(), c4d.PLUGINTYPE_TOOL)
          if isinstance(tool, plugins.BasePlugin) :
              data = tool.GetNodeData()
              if isinstance(data, fhBaseSelectToolData.fhBaseSelectToolData) :
                  if isinstance(data.Dialog, gui.GeDialog) :
                      print data.Dialog.SendMessage(id   = fhPolyTools.IDC_BASE_FREEZE_BTN,
                                                    msg  = c4d.BaseContainer(c4d.BFM_DISABLE))
      Thank you for your help and happy rendering,
        On 26/05/2013 at 07:37, xxxxxxxx wrote:
        hm,
        that is how i thonk it should work, but it does not 🤢.
                        msg, bc = c4d.BaseContainer(c4d.BFM_VALUECHNG), c4d.BaseContainer(c4d.BFM_ACTION)
                        bc.SetLong(c4d.BFM_ACTION_ID, fhPolyTools.IDC_BASE_FREEZE_BTN)
                        bc.SetBool(c4d.BFM_ACTION_VALUE, fhPolyTools.ID_ISFROZEN)
                        msg.SetContainer(c4d.BFM_ACTION, bc)
                        data.Dialog.SendMessage(id = fhPolyTools.IDC_BASE_FREEZE_BTN, msg = msg)
          On 26/05/2013 at 07:48, xxxxxxxx wrote:
          Never tried it with Python.
          My C++ notes say to use it like this:
          BaseContainer msg(BFM_ACTION);
          msg.SetLong(BFM_ACTION_ID, YOUR_ID);
          msg.SetLong(BFM_ACTION_VALUE, TRUE);
            On 26/05/2013 at 07:56, xxxxxxxx wrote:
            Hi scott,
            thanks for your answer. I tried that too, using SetLong for BFM_ACTION_VALUE and sending the BMF_ACTION container directly, but that did not work either for me.
              On 26/05/2013 at 08:27, xxxxxxxx wrote:
              You're asking about GeDialog. Yet the code you posted is for a Tool Data plugin?
              Are you trying to send a message from a tool plugin to a GeDialog plugin?
              Also.
              BitmapButtons have their own settings to do things like TOGGLE: _  customgui_bitmapbutton.h_
              Enable() is sort of a generic way to grey things out in dialogs.
                On 26/05/2013 at 08:59, xxxxxxxx wrote:
                ToolData plugins have in contrast to ToolDescriptionData plugins a GeDialog attached to it.
                I am accessing the dialog attached to the tool. Check the example code. The code itself is
                from a CommandData plugin.
                I am aware about the nature of bfm_disable. I have posted it just as a demonstration
                that the general approach works and that i can alter the gadget attached to id that way.
                I am only missing the correct id(s).
                  On 26/05/2013 at 11:58, xxxxxxxx wrote:
                  hey,
                  for the record and others who might search on this, i made it just to complicated. I thought
                  BitmapButton is not wrapped for python but it actually is. So you can keep it pretty straight
                  forward.
                      # --- Toggle the freeze state and toggle the freeze button of the active fhBaseToolData
                          if (isinstance(tool, plugins.BasePlugin) and
                              isinstance(tool.GetNodeData(), fhBaseToolData.fhBaseToolData) and
                              isinstance(tool.GetNodeData().Dialog, fhBaseToolDialog.fhBaseToolDialog) and
                              tool.GetNodeData().Dialog.CanFreeze) :
                              btn = tool.GetNodeData().Dialog.FindCustomGui(id       = fhPolyTools.IDC_BASE_FREEZE_BTN,
        pluginid = c4d.CUSTOMGUI_BITMAPBUTTON)
                              if isinstance(btn, c4d.gui.BitmapButtonCustomGui) :
                                  btn.SetToggleState(fhPolyTools.ID_ISFROZEN)
                          c4d.SpecialEventAdd(messageid = fhPolyTools.PID_FHFREEZETOOL)
