    Set Selection to nothing
    5 Posts 0 Posters 536 Views
      On 24/05/2013 at 06:11, xxxxxxxx wrote:
      How can you set the selection to nothing?
      I know there is nothing selected by default, but in my plugin I used BaseDocument.SetSelection( bl [, mode=SELECTION_NEW ]). At a later point I want nothing to be selected, how should I arrange that, because you need a baseobject for bl?
        On 24/05/2013 at 06:46, xxxxxxxx wrote:
        Allready found it.
        c4d.CallCommand(12113) # Deselect All
          On 24/05/2013 at 07:13, xxxxxxxx wrote:
          this is how you would do it yourself.
          for obj in doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN) : obj.ToggleBit(c4d.BIT_ACTIVE)
            On 24/05/2013 at 08:41, xxxxxxxx wrote:
            Try to avoid CallCommand() calls. They will break your undo step apart. As littledevil
            already showed, you can change the selection-state manually. Rather use DelBit() though,
            since ToggleBit() does invert the state, rather then setting it to off/false.
            Best,
            -Nik
              On 24/05/2013 at 08:59, xxxxxxxx wrote:
              Thanks guys!
