    Notification on object delete or rename
    6 Posts 0 Posters 638 Views
      On 23/05/2013 at 04:18, xxxxxxxx wrote:
      Cinema 4D Version:   14
      Is there a way to get notified when a object(camera) is deleted or renamed?
      Ralf
        On 23/05/2013 at 04:54, xxxxxxxx wrote:
        from a coremessage method listen for EVMSG_CHANGE and then check the reference/pointer
        on your object if its none, its gone 🙂 if it is still a GeListNode you can check the name.
          On 23/05/2013 at 06:03, xxxxxxxx wrote:
          I have registered a MessageData-Plugin and get EVMSG_CHANGE in the coremessage function. I am storing a BaseObject * m_object somewhere in my plugin. How should I check my pointer m_object if it is none? I mean m_object doesn't get NULL'ed automatically when the user deletes my object.
          The EVMGS_CHANGE doesn't give me information about which object has changed or deleted, right?
          Can you help me?
            On 23/05/2013 at 06:23, xxxxxxxx wrote:
            Store a BaseLink to the object instead of a direct pointer. It will allow you to check if the object
            does still exist or not.
            -Nik
              On 23/05/2013 at 09:31, xxxxxxxx wrote:
              Ok. This works.
              But I still have to find out which one was deleted and which one was renamed all by myself instead C4D is doing this for me, right?
              I would expect that the SDK is doing this for me.
              Ralf
                On 23/05/2013 at 10:00, xxxxxxxx wrote:
                Well, do you want to checl for a specific object, if it was deleted or renamed, or the whole hierarchy?
                -Niklas
