    World matrix of camera
    SDK Help
    0
    • H
      On 16/05/2013 at 06:45, xxxxxxxx wrote:
      Cinema 4D Version:   R14+
      Language(s) :
      How can I get the world matrix of the scene camera in a parallel view such as Left?
      BaseObject->GetMg() on the scenecamera returns the rotation portion as an identify matrix.
      Markus
      • H
        On 16/05/2013 at 06:52, xxxxxxxx wrote:
        The matrix does not only contain the rotation and with it the scale, but also the position. You can
        access it via the off attribute.
        Best,
        -Niklas
        • H
          On 17/05/2013 at 03:18, xxxxxxxx wrote:
          Sorry. I don't understand.
          I have a "Left" Camera.
          I do:
          BaseDraw* editor = doc->GetActiveBaseDraw();
                if (!editor)
                    return false;
                cam = editor->GetSceneCamera(doc);
                if (!cam)
                    return false;
                Matrix camRotMat = cam->GetMg();
          I get:
           [1 0 0
            0 1 0
            0 0 1
            0 0 0]
          Which is obviously wrong.
          • H
            On 17/05/2013 at 03:33, xxxxxxxx wrote:
            the matrix is correct. orthogonal cameras are not aligned like perspective cameras. every
            orthogonal has that matrix unless you do specifically rotate them.
            edit : the offset can vary of course ...
            • H
              On 17/05/2013 at 04:35, xxxxxxxx wrote:
              Sorry I totally disagree that the matrix is correct.
              How can I offset the camera to the right if I don't know which axis that is?
              i.e.
              CameraObject->SetOffset(CameraObject->GetOffset() + Vector(100,0,0))
              only moves the camera left in the "Front", "Top" and "Botton: cameras (because the x-axis is to the right)
              Or is there another way of doing this?
              • H
                On 21/05/2013 at 10:40, xxxxxxxx wrote:
                Yep. To get the correct camera matrix use the BaseView instead. There the GetMg() function also gets the global object matrix of the current camera object. But this time it is correct.
