    change selection to parent
    6 Posts 0 Posters 462 Views
      On 14/05/2013 at 01:32, xxxxxxxx wrote:
      hi
      is there a way to watch for selecting an objekt an if this object is child of my Plugin_Objekt change the selection to the parent object ?
        On 14/05/2013 at 04:28, xxxxxxxx wrote:
        the easiest way would be in python to write a separate message plugin for that.
        for each EVMSG_CHANGE evaluate and modify the active documents object selection
        to your needs.
        but i do not think that this is good idea, as it would make it impossible to select and
        delete the child. either hide the child completely in the object manager or use a
        link resource element  to embed your child in the description of your parent object.
          On 14/05/2013 at 07:56, xxxxxxxx wrote:
          hey - thanks for your reply
          hide the object in the object manager don`t prevent to select the child in the viewport
          what do you meen with link resource element ? xref ?
          thanks
            On 14/05/2013 at 11:09, xxxxxxxx wrote:
            i meant the LinkBoxGui resource element.
            _<_img src="http://chicagoc4d.com/c4dpythonsdk/\_images/linkbox.png" height="30" width="193" border="0" /_>_
              On 15/05/2013 at 01:56, xxxxxxxx wrote:
              hey littledevil,
              thanks for the explanation
              i don`t get a clou how protect with the link my child objekts - thanks !
                On 15/05/2013 at 09:59, xxxxxxxx wrote:
                I think you misunderstood me. The LinkBoxGui is not meant to implement the selection behaviour
                you described. I suggested it as an alternative approach to providing input data by parenting
                object nodes.
                Overriding user selections is one the worst things you could do in terms of gui design IMHO.
                If you do want implement the desired behaviour nevertheless you will have to write a little
                MessageData plugin for that and do what I have described in my first posting. Theoretically
                you could just use one of the NodeData methods which are being called often, like for
                example GetDEnabling(), but I guess that would be REALLY sloppy.
