    DATETIME in RES file
    8 Posts 0 Posters 758 Views
      On 06/05/2013 at 12:52, xxxxxxxx wrote:
      I'm using the DATETIME GUI within a res file and it shows ok.
      However, is there a standard way to get/set the DATETIME GUI, like self.SetDateTime / self.GetDateTime?
      At this moment I use the following code to init and read the DATETIME GUI.
      I have the feeling it is not the optimal / best way?
      RES file:
      		DATETIME SOLAR_DATE_TIME {NOW_BUTTON;}
      INIT:
          def Init(self, node) :
              tag = node
              data = tag.GetDataInstance()
              dtr = data[SOLAR_DATE_TIME]
              td=datetime.strptime('01.01.2010 00:00:00',"%d.%m.%Y %H:%M:%S")
              dtd=DateTimeData()
              dtd.SetDateTime(td)
              data.SetData(SOLAR_DATE_TIME,dtd)
      GETTING THE INPUT:
          def Execute(self, tag, doc, op, bt, priority, flags) :
              data = tag.GetDataInstance()                    #get GUI data
              datetime = dtr.GetDateTime ()
              print datetime
      Note: It is a TagPlugin
      Note: I had to add "import time", else strptime gave me an error.
        On 06/05/2013 at 13:18, xxxxxxxx wrote:
        Hi pgroof,
        why do you think this is not optimal? I don't see much space for improvements.
        Best,
        -Niklas
          On 06/05/2013 at 13:47, xxxxxxxx wrote:
          you have to import time, as the DateTime description element is just a front end for
          the time module. it is an second/epoche based format originated in c. there is also the
          DateTime module in python (not to confuse with the DateTime description element)
          which offers a more object oriented approach on time and date management.
          the time module has some drawbacks, but what i really liked about it is, as it is seconds
          based, you can simply do time0 - time1. you can convert between time and datetime and
          there are also more methods than just strptime() in the time module.
          http://docs.python.org/2/library/time.html
          http://docs.python.org/2/library/datetime.html#module-datetime
            On 06/05/2013 at 13:52, xxxxxxxx wrote:
            Am I missing something obvious? Why would you need to import the time module? You are not
            referencing the time module from anywhere in the code you have posted.
              On 06/05/2013 at 14:04, xxxxxxxx wrote:
              he is , but I did mix up datetime and time, following the ops mixup 😉 he is using datetime.
                On 06/05/2013 at 14:08, xxxxxxxx wrote:
                Ah, I really wondered why everyone was talking about the "time" module.. 😄
                But then he had to write "from datetime import datetime".
                  On 06/05/2013 at 14:12, xxxxxxxx wrote:
                  well their methods output is the same both return time.somethingblah_structs. hard to spot 😉
                    On 06/05/2013 at 23:12, xxxxxxxx wrote:
                    Hi pgroof,
                    Best,
                    -Niklas
                    It seems a lot of code. I was hoping there was something as the Link Gui.
                    E.g. self.linkCityObject = self.AddCustomGui(MY_CITYLINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
                    Yes, you are correct. Using "from datetime import datetime" is enough, no need for time.
                    Thanks for all the comments.
                    Regards, Pim
