    Python | Force obj to calc b4 another obj
    17 Posts 0 Posters 1.6k Views
      On 06/05/2013 at 11:27, xxxxxxxx wrote:
      i can only answer partially:
      1. Communication between two nodes can be a difficult task in c4d. Hidden descriptions are one
      way to do it. For more complex data sets you have to use messages directly from node to node
      or with a core message plugin in the middle. Also there is GetListNode.GetNodeData()which is
      not documented for python for whatever reason, which lets you grab the your NodeData plugin
      class implementation instance attached to a GeListNode and therefore would let you access all
      its members.
      2. For the update cycle - It is a quite complicated topic I also do not fully understand and have
      not fully explored yet. There are several methods like BaseObject.Touch() and BaseObject.
      SetDirty()which allow you to force an object to rebuild its cache. This however won't solve your
      problem of priority directly.
      But as all NodeData direct 'execution' methods are threaded it should  be theoretically possible
      for your ObjectData plugin to wait with its output until all data it is based on have been updated
      for the current pass (are not dirty anymore). But that is pure theory as I said, I could always get
      away with tag plugins until now, which do offer a manual priority system (the tag execution order).
        On 06/05/2013 at 12:37, xxxxxxxx wrote:
        Thankyou for that, Ferdinand (did I get your name correct?),
        For GetNodeData(), I can ask for this and it returns what?  a Dict with all the Ivars or method names? Or basically pass the "op"?  So can I call functions on another plugin with this? If so, it would force the order perfectly as it would make it run the function and get the result before moving on which would be perfect.
          On 06/05/2013 at 13:00, xxxxxxxx wrote:
          Hi Chris,
          no this will not change the order of execution. But it allows you to change any data (such as
          the values of instance variables that are not shown in the description of an object). You have to
          get the priorities right. Cinema executes generators sequentially, so if you want the one generator
          to be finished before the other, you have to put the one in a higher position than the other.
          Another way would be to calculate the data in an Execute() pass and retrieve this information
          in GetVirtualObjects(). But I think this would disallow you to use objects as input (children, like
          the HyperNURBS for example uses it's child-object as input). If this is a requirement, it will probably
          not be an option.
          Best,
          -Niklas
            On 06/05/2013 at 13:09, xxxxxxxx wrote:
            yes my name is Ferdinand. GetNodeData() returns the NodeData implentation attached to a
            GeListNode. If you have an ObjectData plugin which implements something like that :
            ObjectDataData(plugins.ObjectData) :
            	def __init__(self) :
            		self.someFancyList = []
            	def GetVirtualObjects(self, node, hh) :
            it will return an instance of ObjectDataData attached to that GeListNode so that you acccess
            ObjectDataData.someFancyList attached to that GeListNode. For native c4d objects (that are
            not implemented as a plugin) it will return None. You can try it from the console, simply drag a
            plugin node into it and put a .GetNodedata() behind it.
              On 06/05/2013 at 13:14, xxxxxxxx wrote:
              Ferdinand, I don't have a Python Object Plugin to hand, but using GetNodeData() on a non-Python
              plugin object doesn't work (it returns None). I didn't test it for Python object plugins, but I assume it
              only works for those (would be pretty much senseless if it would always return None).
              Anyway, good catch that this method is actually available, didn't see it until now.
              Best,
              -Niklas
                On 06/05/2013 at 13:19, xxxxxxxx wrote:
                You have to get the priorities right. Cinema executes generators sequentially ...
                are you sure about that ? c4d obviously passes the objects sequentially, or in other
                words works its way down the object manager, but as i already wrote above, as
                BaseObject.GVO(), BaseTag.Execute() and so on are all threaded, should it not be
                possible to 'wait' for other objects to be updated ?
                edit: is does work, i am using it. not sure why it is not documented. as i am exclusively
                python right now, except from our polylight cpp excursion, i haven't bothered testing it
                cross language yet, but you are right it does not work (which is not really surprising IMHO).
                [OK] fhArraySampleObject.GetNodeData()
                <__main__.fhArraySampleObjectData object at 0x000000000FA193F0>
                [OK] hook = fhVertexmapShade.GetNodeData()
                [OK] dir(hook)
                ['Draw', 'Execute', 'FakeMaterial', 'GetDEnabling', 'Init', 'InitAttr', 'IsInit', 'IsInstanceOf', 'IsRenderDirty', 'Message', 'Sampler', 'ShaderContainerCache', '__class__', '__delattr__', '__dict__', '__doc__', '__format__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__', 'initHost', 'isDirty']
                [OK] print hook.IsRenderDirty
                False
                edit2: first one is an ObjectData, second one is a TagData. i did extend the example a bit,
                mainly for the op.
                  On 06/05/2013 at 13:43, xxxxxxxx wrote:
                  This is all pure gold.  Thank you both.  I appreciate both of your assistance greatly.  I'll reply with any succsesses.
                    I'm also thinking about this. I'm not 100% sure about this, but it would be the only explanation
                    to the behavior I have experienced so far.
                    Even if it would be possible for you to wait until another object has been updated (assuming
                    it is being updated from another thread), you would block the thread of your object. 🙂
                    And to extend your example a bit more 🙂
                    [OK] print Cube.GetNodeData()
                    None
                    Best,
                    -Niklas
                      On 06/05/2013 at 17:17, xxxxxxxx wrote:
                      I AM BLOWN AWAY
                      Works flawlessly.  Instead of storing my variable as a hidden description, I wrote a "getter" method on my other plugins.  On my main plugin when I needed the data I asked for the NodeData and called that function that did the calculation on the other plugin on demand and all of the frame lag and glitching is completely gone.  Works FLAWLESSLY.
                      I am blown away it works so well.  I'm also excited as I've had other "glitchy" bugs all related to passing values through Descriptions.  And when I switch them to "getter" methods through NodeData, I'm confident it will solve those as well.
                      Again, thank you both for this help.  Priceless.
                        On 06/05/2013 at 17:46, xxxxxxxx wrote:
                        ^Can you please post an example how you are getting your other plugin?
                        To grab tag plugins I use something like this: tag = obj.GetTag(TAG_PLUGIN_ID);
                        I don't make ObjectData plugins very often. So I'm wondering if grabbing an ObjectData plugin is done differently than getting a tag plugin from within another plugin?
                          On 06/05/2013 at 17:58, xxxxxxxx wrote:
                          Sure.  This isn't from my plug but a simple example of what I just did:
                          My Camera Waypoints are their own object and they are created by my main plugin.  As they are created they are populated into an incl/exl list on the main plugin.  Each Waypoint has a target position in space based on their Z direction * a depth parameter.  I was calculating this global position for depth on the Waypoint and setting a hidden description with this value which I would read on the main plugin.  However since the 2 objects are in different threads, this was often calculated AFTER the main plugin causing lag and glitching.  SO, on the main plugin instead of getting the waypoint as an object from the list and doing a :
                          tpos = cam[c4d.TARGETPOS]
                          I moved my code on the waypoint into a functioncalled "getTPos()" that gathers all the info needed there and returned the value from the method itself.  SO, on my main plugin I did:
                          camdata = cam.GetNodeData()
                          tpos = camdata.getTPos()
                          Which forced the waypoint to collect all the data that moment before my main plug carried on further.  Insuring the data would always be calculated when asked.  Before when it was calculated on it's own in it's own thread and placed in a description it was usually behind or on occasion ahead which create a glitch or lag.
                            On 06/05/2013 at 18:03, xxxxxxxx wrote:
                            Looking at your question again, Scott, you may have been asking how to reference your other plugin as opposed to the GetNodeData part.  Mine are always in a exl list so I just loop through that getting data on each.  Although I suppose you can just do the usual way of referencing other objects but for type you use your plugin ID.  Not sure if that's what you mean.
                              On 06/05/2013 at 18:33, xxxxxxxx wrote:
                              Yeah.
                              I meant getting an ObjectData plugin from inside a different plugin. So I could then get at all of the ObjectData's members.
                              It's handy to be able to have two plugins talk to each other internally like that.
                              I've done this with tag and Gedialog plugins. But not ObjectData plugins yet.
                              I thought that's what you were dong. But I guess not.
                              Thanks anyway.
