    GetRad and Nurbs?
    SDK Help
    0
    • H
      On 30/04/2013 at 13:55, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      Hey there,
      i am using GetRad to get the Boundingbox of an object. This works fine until i try to get it from a NurbsObject. Then only 0,0,0 is returned. How do i get the Boundingbox for NurbsObjects?
      thanks in advance,
      Ello
      • H
        On 30/04/2013 at 14:23, xxxxxxxx wrote:
        GetRad() does work fine for me in python (also on NURBS objects). This has to be a cpp specific
        problem or, as things working in python but do not working in cpp are really rare, you are doing
        something wrong. Are you sure your nurbs generator has a properly build cache ? Or in other
        words - GetRad() won't work for most objects if you have not inserted them into a document.
        • H
          On 30/04/2013 at 15:16, xxxxxxxx wrote:
          hm, i am using it like this:
          BaseList2D myObjectLink = bc->GetLink(OBJECTLINK,doc);
          myObject = static_cast<BaseObject*>(myObjectLink->GetClone(COPYFLAGS_0, NULL));
          if (myObject )
          Vector baseSize = myObject ->GetRad();
          GePrint(RealToString(baseSize.x)+","+RealToString(baseSize.y)+","+RealToString(baseSize.z));
          • H
            On 30/04/2013 at 15:46, xxxxxxxx wrote:
            i am not really sure about all that cpp stuff but GetClone() might be the culprit, i think the
            cloned object does not inherit the cache from its parent and as long you do not insert the
            clone into the document there won't be build a new one.
            a solution might be to try to cast the BaseList2D from GetLink directly into a BaseObject,
            so that you can invoke GetRad() on the object in your document, but again i do have almost
            no clue whats going on in cpp and this barely more than brain farting 😉
            • H
              On 02/05/2013 at 08:25, xxxxxxxx wrote:
              The bounding box is returned if I do CurrentStateToObject on the clone before calling GetRad(). The ModelingCommandData result isn't used.
              Presumably this is due to the cache being rebuilt. I wasn't able to find a more elegant way of doing this.
              • H
                On 02/05/2013 at 09:48, xxxxxxxx wrote:
                thank you!
