    memory leaks with standard spline??
    14 Posts 0 Posters 1.4k Views
      On 30/04/2013 at 12:19, xxxxxxxx wrote:
      Hi Ello,
      I can not confirm this using R14.
      No such leaks here.
      regards,
      Remo
        On 30/04/2013 at 12:28, xxxxxxxx wrote:
        hm, that is really strange. for testing i removed every plugin and tried the thing again. same result. there are memory leaks.
          On 30/04/2013 at 13:19, xxxxxxxx wrote:
          Hi ello,
          what Cinema 4D Version exactly do you use? 14.041?
          -Niklas
            On 30/04/2013 at 13:21, xxxxxxxx wrote:
            no, its still 14.034 . the updater didnt pop up so far
            edit, btw checking for updates does search endlessly.
              On 30/04/2013 at 15:25, xxxxxxxx wrote:
              I can not reproduce this either. I've checked R14.034 x64 on Windows 7. Are you sure this
              is not due to your plugin?
                On 30/04/2013 at 15:29, xxxxxxxx wrote:
                i have now updated and still have this behaviour.. i have removed all plugins and still the same... very strange. i just draw a freehand spline, move some points here and there. close without saving and get plenty of memory leaking
                if i dont move the spline points, there are no leaks. as soon as points where moved, the leaks appear
                  On 30/04/2013 at 16:37, xxxxxxxx wrote:
                  Where did you put your c4d_debug.txt file?
                  I think I remember getting those kinds of memory leak errors in R12. When I was putting the c4d_debug.txt file in the main Maxon folder.
                  These days I usually put that file in my plugin's folder.
                    On 01/05/2013 at 00:00, xxxxxxxx wrote:
                    really? but when i put it there, the console doesn't pop up
                      This only works if you Debug C4D using visual Studio so C4D will search in you plugin folder.
                      If you start C4D normally then it will search in main folder.
                      Any way this should not affect memory leaks.
                        On 01/05/2013 at 06:42, xxxxxxxx wrote:
                        Btw, one can also use the -debug command line parameter.
                          On 11/05/2013 at 14:34, xxxxxxxx wrote:
                          hi, what are your strategies to find what causes memory leaks? even if i comment everything out there still appear memory leaks. and i have no idea what causes them...
                            On 12/05/2013 at 01:00, xxxxxxxx wrote:
                            If you commented out everything , it might not be the fault of your plugin. Do you also get the memory
                            leaks when your plugin is simply not installed?
                            Best,
                            -Niklas
                              On 12/05/2013 at 01:32, xxxxxxxx wrote:
                              thats the point. as i mentioned at the beginning of the thread. even if the pluginfolder is empty it happens. but it seems that this doesnt happen to many..
                              now i am wondering how i can find out more about the sources of memory leaks.. is there the possibility to get information which things has been forgotten to free, etc
