    Curious about Browser->IsDir()
    7 Posts 0 Posters 708 Views
      On 28/04/2013 at 21:10, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      Hi Folks,
      I'm just curious about what the difference is between the following code snippets. The first one works, but the second one doesn't:
      // Folder is an AutoAlloc BrowseFiles...
      if(Folder->IsDir())
          GePrint("This way works...!");
      if(Folder->IsDir() == TRUE)
          GePrint("This way doesn't work...");
      What's the technical/C++ difference here and why does one way work but the other not? I'm just curious because having Folder->IsDir() == FALSE works fine, but having TRUE does not..
      WP.
        On 29/04/2013 at 06:56, xxxxxxxx wrote:
        Well Bool in C4D SDK is actually an Integer (int)  while FALSE if 0 and TRUE is 1.
        The problem is that Bool can also be 5 or any other Integer value.
        If IsDir() return some other value as 1 for true then if(IsDir()) will work but if(IsDir()==TRUE) will not work because if(5 == 1) is false.
        Some times C4D SDK uses NOTOK = (-1)  as a Bool value too.
          On 29/04/2013 at 13:28, xxxxxxxx wrote:
          While it is true that Bool is an integer, it should be returning strict TRUE/FALSE values.  The docs say that it returns TRUE if this is a directory.  So, the second conditional should be working or it's a bug in the SDK (or your code).
            On 29/04/2013 at 13:53, xxxxxxxx wrote:
            not sure how it is in cpp, but in python and c# the lazy ass implicit notation behaves different
            than the explicit notation.
            def foo(v) :
                if v: print 'imp', True
                else: print 'imp', False
                if v == True: print 'exp', True
                else: print 'exp', False
            print 0
            foo(0)
            print -1
            foo(-1)
            \>>0
            \>>imp False
            \>>exp False
            \>>-1
            \>>imp True
            \>>exp False
              On 29/04/2013 at 14:19, xxxxxxxx wrote:
              @littledevil: The same in example in C++ will print the same results.
              http://ideone.com/JgkQcJ
              Best,
              -Niklas
                On 29/04/2013 at 14:48, xxxxxxxx wrote:
                <ADDRESS>
                Language(s) :
                C++  ;
                </ADDRESS> Hi Folks,
                if(Folder->IsDir())
                WP.
                It's a Windows specific bug (on the Mac it's fine) - the return value on Windows is the Win32 FILE_ATTRIBUTE_DIRECTORY constant (instead of TRUE). I'll file a bug for it. For the time being please use the code block of your first scope as workaround instead of comparing it with "TRUE".
                Best regards,
                Wilfried
                  On 29/04/2013 at 19:01, xxxxxxxx wrote:
                  Thanks again everyone.
                  WP.
