    Objectdata plugin is not refreshed / updated
    15 Posts 0 Posters 1.6k Views
      On 26/04/2013 at 09:29, xxxxxxxx wrote:
      hm,
      something i haven't thought of is that there is a special flag for your scenario. that your
      plugin is updated under certain conditions and under some not might be caused by your
      current flag. so you might want to try the  _OBJECT_INPUT  _flag, which will kind of
      automate this desired caching behaviour i guess.
      plugins.RegisterObjectPlugin(...
      • Object Plugin Flags
      _<_t_<__<_t_>_<_<_t_>_lgroup> OBJECT_MODIFIER Modifier object. Deforms the surrounding object. (E.g. bend.)
      OBJECT_HIERARCHYMODIFIER Hierarchical modifier. Deforms the surrounding objects together with other instances in a hierarchy chain. Only the top-most instance of the plugin in a chain is called. (E.g. bones.)
      OBJECT_GENERATOR Generator object. Produces a polygonal or spline representation on its own. (E.g. primitive cube.)
      OBJECT_INPUT Used in combination with  OBJECT_GENERATOR. Specifies that the generator uses builds a polygon or spline, using its subobjects as input. (E.g. Sweep NURBS, Boolean.)
      OBJECT_PARTICLEMODIFIER Particle modifier.
      OBJECT_ISSPLINE The object is a spline.
      OBJECT_USECACHECOLOR If this flag is specified, the generator object itself controls the objects' colors (the ones that determine the wireframe/shaded color). Normally these are automatically overwritten by the generator objects settings. E.g. if the instance object is set to green, automatically all of its cache objects get the green color. By setting this flag an instance object could individually color objects.
      OBJECT_CAMERADEPENDENT Camera dependent.
      OBJECT_POINTOBJECT Point Object.
      OBJECT_POLYGONOBJECT Polygon object.
      OBJECT_NO_PLA Objects derived from PointObject[URL-REMOVED] will not use auto-keyframing (e.g. Joints can contain points and PLA auto-keyframing is not useful for them)
      OBJECT_DONTFREECACHE Objects' (generators) caches will not be be deleted - users must maintain caches themselves.
      OBJECT_CALL_ADDEXECUTION Must be set to call ObjectData.Execute()[URL-REMOVED] in the priority pipeline specified by ObjectData.AddToExecution()[URL-REMOVED]._<_t_>_
        On 26/04/2013 at 10:23, xxxxxxxx wrote:
        Ok, I changed it, but no success.
            okyn = plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="SweepObj",
                                        g=SweepObj,
                                        description="SweepObj", icon=icon,
                                        info=c4d.OBJECT_GENERATOR | c4d.OBJECT_INPUT)
          On 26/04/2013 at 11:07, xxxxxxxx wrote:
          Using a link, it works!
          Thanks.
            On 26/04/2013 at 13:24, xxxxxxxx wrote:
            i am not sure why the flag is not working. please note, that it was only a guess, it is
            not guaranteed that the flag is meant to add that special cache rebuilding behaviour.
            alternatively you could follow just the NodeData.Message() approach., if you want to
            maintain the c4d workflow. simply store a reference to the path object in your class
            and each time Message() receives a change msgid, test if self.reference is node.GetDown()
            and flag your node dirty depending on the result.
              On 26/04/2013 at 13:56, xxxxxxxx wrote:
              Thanks for all your help and I understand it was only a guess.
              I have to think and of course try out, your other option, the NodeData.message approach.
              I have read some other posts about other simular issues
              I now better understand and it might be an option, something ScottA posted:
              What about triggering a hidden UserData field in your code to update it instead?
              https://developers.maxon.net/forum/topic/6070/6249_getcontour-refresh-or-uncache-how&PID=26194#26194
                You mean:
                Listen to NodeData.Message( self , node , type , data )
                if self.reference = child object (node.getdown())
                    set dirty plugin node
                Not quite sure about it, but I''ll give it a try.
                  On 26/04/2013 at 14:18, xxxxxxxx wrote:
                  i think you mean == instead = and i am not sure about the rest of the line, but despite that
                  i actually meant the is keyword.
                  def __init__(self) :
                      self.reference = None
                  def Message(self, node, type, data) :
                      if node.getdown() is not self.reference:
                          self.reference = node.GetDown()
                          node.SetDirty(0)
                  practically you could check first if the msg id is the change msg and only then execute the rest.
                  you would also have to check the case where the object is the same, but the bc has changed.
                  for a parametric spline for example which is animated.
                    On 26/04/2013 at 14:48, xxxxxxxx wrote:
                    It is working and more simple then we thought.
                    All I did was remove the following lines:
                            self.SetOptimizeCache(True)
                    The downside is that Render Active View is not working anymore!
                    More testing to do.
                    import os
                    import math
                    import sys
                    from c4d import plugins, utils, bitmaps, gui
                    PLUGIN_ID = 10252501
                    class SweepObj(plugins.ObjectData) :
                        def GetVirtualObjects(self, op, hierarchyhelp) :
                            # Disabled the following lines because cache flag was set
                            # So the cache build is done before this method is called
                            #dirty = op.CheckCache(hierarchyhelp) or op.IsDirty(c4d.DIRTY_DATA)
                            #if dirty is False: return op.GetCache(hierarchyhelp)
                            #Get the child / parent object (to use as the sweep spline)
                            #Use GetClone so we aren't working on the object itself
                            source = op.GetDown()
                            if (source is None) : return None
                            source = op.GetDown().GetClone()
                            #Create a Circle Primitive to act as the sweep profile
                            circle = c4d.BaseObject(c4d.Osplinecircle)
                            #Set the radius
                            circle[c4d.PRIM_CIRCLE_RADIUS] = 10.0
                            #Create a new SweepNURBS
                            sweep = c4d.BaseObject(c4d.Osweep)
                            #Insert the source sweep spline under the SweepNURBS
                            source.InsertUnder(sweep)
                            #Insert the circle profile spline under the SweepNURBS
                            circle.InsertUnder(sweep)
                            sweep.Message (c4d.MSG_UPDATE)    #update sweep in viewport
                            #Return the SweepNURBS
                            return sweep
                        pluginstr = "SweepObj TEST v01"
                        icon = bitmaps.BaseBitmap()
                        icon.InitWith(os.path.join(dir, "res", "sweepobj.tif"))
                                                    g=SweepObj,
                        if (okyn) :
                            print pluginstr + " initialized."
                        else: print "Error initializing " + pluginstr
                      On 26/04/2013 at 14:55, xxxxxxxx wrote:
                      because you have disabled caching with that 😉 if another node is polling your node the node
                      will always recalculate its output instead of returning its cache when the underlying data
                      has not changed.
                        On 26/04/2013 at 15:06, xxxxxxxx wrote:
                        Yes, the manual tells us:
                        The method GetVirtualObjects() is called on each frame and if you don't want to calculate the object on each frame again and again you can still return the cache object with the following code:
                        I tried your option, but without any testing.
                        That did not solve it. Is 0 the correct flag value  to set?
                        How and when is SetDirty used by Cinema 4d?
                            node.SetDirty(0)
                          On 26/04/2013 at 15:57, xxxxxxxx wrote:
                          i didn't actually test my posted code and assumed that a node is notified each time
                          one of its children changes, however that is not the case (at least not always,
                          messages tend to be confusing ). long story short here is a working version, i have
                          actually tested this time 😉 it returns a Null when the object has no child and then
                          alternating a sphere or cube each time the cache is rebuild.
                          the cache is rebuild when either the direct child changes or the direct child is dirty.
                          import c4d, os, sys
                          from c4d import bitmaps, documents, gui, modules,  plugins
                          class fhOdataTestData(plugins.ObjectData) :
                                  self.toggle    = False
                              def GetVirtualObjects(self, node, hierarchyhelp) :
                                  if node.GetDown() != self.reference:
                                      node.SetDirty(c4d.DIRTY_DATA)
                                  elif node.GetDown() and node.GetDown().IsDirty(c4d.DIRTY_DATA) :
                                  if not (node.CheckCache(hierarchyhelp) or node.IsDirty(c4d.DIRTY_DATA)) :
                                      return node.GetCache(hierarchyhelp)
                                  if self.reference:
                                      if self.toggle:
                                          res = c4d.BaseObject(c4d.Ocube)
                                          res = c4d.BaseObject(c4d.Osphere)
                                      self.toggle = not self.toggle
                                      return res
                                      return None
                              path, file = os.path.split(__file__)
                              bmp = bitmaps.BaseBitmap()
                              bmp.InitWith(os.path.join(path, "res", "fhOdataTest.tif"))
                              plugins.RegisterObjectPlugin(id          = 1029736,
                                                           str         = "odatatest",
                                                           g           = fhOdataTestData,
                                                           description = "odatatest",
                                                           icon        = bmp,
                                                           info        = c4d.OBJECT_GENERATOR)
                            On 27/04/2013 at 02:22, xxxxxxxx wrote:
                            Briljant, thank you very much!
                            It works as hoped.
