    AtomArray->C4DAtom->BaseObject
    3 Posts 0 Posters 347 Views
      On 17/04/2013 at 20:10, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:      Mac OSX  ;
      This seems to be an absolutely trivial task - but after hours of hunting I am giving up:
      How do I find the first selected object in a document?
      First I thought about using GetFirstObject(), GetNext(), etc. while checking if the object is selected. But I can't find anything that lets me test if a given BaseObject is selected.
      Then I thought I use GetActiveObjects() which puts all selected objects into an AtomArray through which I can step and get the C4DAtoms. But how can I get an actual BaseObject from from a C4DAtom?
      I am probably looking at the wrong end since this must be utterly common....
        On 17/04/2013 at 21:01, xxxxxxxx wrote:
        use GetBit(BIT_ACTIVE) to check if an object is selected. You can simply
        cast an item from C4DAtom (as returned by AtomArray::GetIndex) to BaseObject.
        -Niklas
          On 22/04/2013 at 10:35, xxxxxxxx wrote:
          Hi Niklas
          Ah, yes, I thought it would be obvious. Just not to a rookie like me.
          Thanks a bunch.
          Peter
