    New Surfaces Materials?
    56 Posts 0 Posters 43.9k Views
      On 17/04/2013 at 09:33, xxxxxxxx wrote:
      at least in python there are no bitmap shaders and formula shader classes. i used the term
      bitmap shader in reference to the native c4d shader type Xbitmap which simply samples a
      bitmap by converting the UV coordinates into pixel coordinates at that point.
      for creating a tile shader, it is pretty simple. the main problem often is how to do such things
      in a performant way (something i am really bad at), but generally you could do it this way,
      in some sort of pseudo code.
      if (sample.u <= gap.x or sample.u >= 1 - gap.x or
          sample.v <= gap.y or sample.v >= 1 - gap.y) :
          return black
          return white
      so you just hard code it, the result would be white rectangle, with a black border of the size
      gap. all inputs are always 0-1 based. you do not have to implement tiling for your shader
      specifically, enabling tiling in the material tag will simply alter the channeldata (the uvw
      coordinates being passed) to your Output() method.
      if you want to implement tiling within you shader internally you have to hardcode it into
      your method. for the gap example you would have not only to check if sample is within
      gap or 1-gap, but also within gap*0.5 and 1-gap*0.5, when the user sets the scale to
      50%.
      edit : hm, sometimes there pop postings out of nowehere for me, haven't seen nikklas
      posting before, which makes my posting kind of pointless.
        On 17/04/2013 at 10:08, xxxxxxxx wrote:
        Thanks guys,
        But those are not organic looking shapes like the pavement shader is.
        The pavement shader looks more a like a bitmap to me because of how organic looking the shapes are.
        I'm not saying you're wrong about it being formula based.
        But I'm a bit confused because I've seen that there is a way to blend bitmaps and create organic shapes and gaps like how the pavement shader looks.
        But then I also don't know if a bitmap type shader can be tiled like the pavement shader does.
        So I'm left wondering. What's really going on in there?
        Is it really all being done with a formula?
        If it is formula based. Then the next step I need to figure out is how to make them look organic looking like the pavement shader. And how to add colors to it. Instead of simple black and white lines.
        That's a very, very big leap to make. And I just want to be sure that's the correct direction to go in. And I'm not heading towards another dead end.
        I think I heard once that the shaders are under some kind of copyrite protection. And Maxon can't share them.
        But if I could just see the code for that one shader. Just that one single shader. Or something that is similar that uses the same technique that isn't under an NDA. It would go a long way to pointing in the right direction on what I need to do.
        I just need that little boost of information to get me started.
          On 17/04/2013 at 10:20, xxxxxxxx wrote:
          Could you just show an example of the pavement shader? I mean, they're really almost all formula
          based. Even Noise is generated by a formula, and there are ways to generate dirt (see the
          Brick shader for instance), etc. Of course, it could be possible that some shader combines a bitmap
          and a formular (eg. using the bitmap to produce dirt) but no programmer would ever think of
          hardcoding it into the shader since it would be easy to let the user choose a bitmap. Or, which makes
          even more sense, just skip the bitmap part since there is the Layer and Fusion shader allowing you
          to blend different shaders.
          -Niklas
            On 17/04/2013 at 10:30, xxxxxxxx wrote:
            What do mean show an example?
            The Pavement shader comes with C4D. It's one of the built-in shaders found under "Surfaces" in any material.
            When you see it. You might see better what I mean about how much it looks like a bitmap being manipulated. Rather than a formula.
            It just doesn't look like a formula to me. But it very well could be.
            I just don't know for sure.
              On 17/04/2013 at 10:31, xxxxxxxx wrote:
              the pavement shader is not bitmap based, it is just a mash up of existing
              shaders. you can easily build your own pavement shader in c4d. some
              voronoi noise, a layer shader, a colorize shader and you are done.
              this is actually the easiest way to 'write' a custom shader. simply instantiate
              a shader tree within you plugin instance and sample that shader(tree) in the
              Output() method.
              check the BaseShader.Sample() method, it is kind of the counter part to the
              Output() method. at the cost of speed of course. a shader which does that all
              in one method without instantiating other shaders will always be faster.
              but speed is not the critical point for low end plugin development imho.
                On 17/04/2013 at 10:33, xxxxxxxx wrote:
                Oh, it is? Haha, really missed that! It looks pretty much like Voronoi Cells mixed with a Noise. I'm
                100% sure there is not hidden bitmap under the hood.
                Best,
                -Niklas
                  On 17/04/2013 at 10:46, xxxxxxxx wrote:
                  OK. Well helps out a little bit.
                  At least I can remove the bitmap image thing from the equation.
                  But I'm still rather lost how I would go about creating my own version with a different pattern.
                    On 17/04/2013 at 10:51, xxxxxxxx wrote:
                    Well, it depends on what pattern you would like to have. A rectangular pattern would be the easiest
                    (similar to the standart version of the Tile shader). You would need to go the way I described above.
                    You just need some kind of algorithm to determine if you're currently at a gap or not (when keeping
                    things simple). I showed you above how to check if for "horizontal lines".
                    Best,
                    -Niklas
                      On 17/04/2013 at 10:58, xxxxxxxx wrote:
                      could you show an example ouput (photo or simple drawing) of what you are after ?
                        On 17/04/2013 at 11:10, xxxxxxxx wrote:
                        I don't have a specific pattern in mind. I never got close enough to even get that far with it.
                        I just wanted to know how to change the pattern.
                        At this point. I have to go back and look at what you guys have posted again. And try to figure out how turn it into something that works (changes the pattern).
                          On 17/04/2013 at 11:55, xxxxxxxx wrote:
                          To generate things like stone or concrete you're really looking at generating a fractal noise of some kind. That's all these procedural rock/stone shaders are - just a fractal or combination of fractals. If you have Vue, it's node-based material editor is a good example of combining fractals like this.
                          So you have to know how to produce those. There are some in Cinema, take a look at fBm or RidgedMultifractal. Otherwise you'll find lots on the net. You will want to generate a value from 0 to 1 and return a colour or bump value accordingly as others have already said.
                            On 17/04/2013 at 12:49, xxxxxxxx wrote:
                            Thanks Steve,
                            I hope I can get far enough to use that information.
                            Right now I'm still trying to figure out how to make even a very simple basic pattern. Like a simple checkerboard pattern. Or a series of circles.
                              On 17/04/2013 at 14:19, xxxxxxxx wrote:
                              i just wanted to stress book tip posted by yannick -  _Texturing and Modeling: A Procedural  _
                              Approach. this book  contains a pretty down to earth description on how to write a brick
                              wall shader (among dozens of dozens other shader listings). one of the must have books
                              for coding simpletons like me imho 😉
                                On 17/04/2013 at 15:37, xxxxxxxx wrote:
                                Before I can use that kind of information. I first need to learn how to use the code in the C4D SDK.
                                As far as I can make out. The main methods I need to use are the InitRender() method & the Output() method. But I'm not even really sure if I really need the InitRender() method.
                                InitRender() seems to be for sampling. But will I need to do any sampling to create my own patterns?
                                These are the basic things I need is to know how to do with the SDK first. Before trying to do anything fancy:
                                -How to create colored lines using cd->p?
                                -How to create a colored checkerboard pattern using cd->p?
                                -How to create a colored grid of circles using cd->p?
                                I'm having a very hard time understanding how these basic things work in C4D SDK.
                                  On 17/04/2013 at 16:12, xxxxxxxx wrote:
                                  You will need to implement InitRender, for (at least) two reasons. If you need to access any data from the shader interface, do it here and store the results - otherwise you could be accessing the parameters hundreds of times whenever a render occurs. Also, if you have any shader links in your shader you absolutely must call their InitRender functions, and you do that here.
                                  To get started, here's the complete listing of a simple shader I wrote to mirror-image a bitmap. It's very simple and you won't need the resource to understand it. It just lets the user choose to mirror the bitmap horizontally and/or vertically, and the only other interface element is a link for the bitmap:
                                  // BMFlip
                                  // bmflip.cpp
                                  // includes
                                  #include "c4d.h"
                                  #include "bmflip.h"
                                  #include "xbmflip.h"
                                  #include "c4d_symbols.h"
                                  SHADERINFO BitmapFlip::GetRenderInfo(BaseShader *sh)
                                       return SHADERINFO_BUMP_SUPPORT;
                                  Bool BitmapFlip::Init(GeListNode *node)
                                          // these are class-level variables
                                       shader = NULL;
                                       flipX = FALSE;
                                       flipY = FALSE;
                                  void BitmapFlip::FreeRender(BaseShader *chn)
                                       if(shader)
                                            shader->FreeRender();
                                       shader = NULL;
                                  Bool BitmapFlip::Message(GeListNode *node, LONG type, void *msgdat)
                                       BaseContainer *data;
                                       data = ((BaseShader* )node)->GetDataInstance();
                                       HandleInitialChannel(node, BMFLIPSHADER_TEXTURE, type, msgdat);
                                       HandleShaderMessage(node, (BaseShader* )data->GetLink(BMFLIPSHADER_TEXTURE, node->GetDocument(), Xbase), type, msgdat);
                                  INITRENDERRESULT BitmapFlip::InitRender(BaseShader *chn, const InitRenderStruct& irs)
                                       INITRENDERRESULT result;
                                       data = chn->GetDataInstance();
                                       // get gadget values
                                       flipX = data->GetBool(BMFLIPSHADER_FLIPX);
                                       flipY = data->GetBool(BMFLIPSHADER_FLIPY);
                                       shader = (BaseShader* )data->GetLink(BMFLIPSHADER_TEXTURE, irs.doc, Xbase);
                                       if(shader)
                                            result = shader->InitRender(irs);
                                            return result;
                                       return INITRENDERRESULT_OK;
                                  Vector BitmapFlip::Output(BaseShader *chn, ChannelData *cd)
                                       Vector res, uv;
                                       if(!shader) return Vector(0.0, 0.0, 0.0);          // return black if no bitmap present
                                       uv = cd->p;                         // get the original UV value so we can restore it later
                                       if(flipX)
                                            cd->p.x = 1.0 - cd->p.x;
                                       if(flipY)
                                            cd->p.y = 1.0 - cd->p.y;
                                       res = shader->Sample(cd);           // get the bitmap value at this point
                                       cd->p = uv;                         // restore the UVs
                                       return res;                                                  // return the colour of the bitmap at the mirrored position
                                  // register the plugin
                                  Bool RegisterBMFlip(void)
                                       String name;
                                       name = "Bitmap Transform";
                                       if(RegisterShaderPlugin(ID_BMFLIP, GeGetDefaultFilename(DEFAULTFILENAME_SHADER_EFFECTS) + String("Bitmap Transform"), 0, BitmapFlip::Alloc,"Xbmflip", 0))
                                       else
                                            return FALSE;
                                  Hope that helps!
                                  Steve
                                    On 17/04/2013 at 16:22, xxxxxxxx wrote:
                                    I haven't tried it but I imagine that for a four-square checkerboard Output() would look something like this:
                                    Vector MyShader::Output(BaseShader *chn, ChannelData *cd)
                                         Vector col;
                                         // cd.p.x and cd.p.y range from 0 to 1
                                         if((cd.p.x < 0.5 && cd.p.y < 0.5) || (cd.p.x >= 0.5 && cd.p.y >= 0.5))
                                              col = Vector(0.0);     // return black for top-left and bottom-right squares
                                         else
                                              col = Vector(1.0);     // return white for the other two squares
                                         return col;
                                    No idea if it works! But try it and see.
                                      On 17/04/2013 at 16:47, xxxxxxxx wrote:
                                      ^Yes. It does work.
                                      Thanks Steve.
                                      But I'm a bit puzzled why it works.
                                      You aren't using a loop to get the positions of p.
                                      I would have thought that I would have needed to use a loop in this case. To check the position (then set the color) of p.
                                      That's how I normally get the colors of a bitmap for example. looping through each line of pixels.
                                      But what you did.
                                      Setting certain sections of the shader to black or white without using a loop. Seems strange to me. And something I'll need to understand. Because I think I'll need to use a similar technique to create other things. Like circles and more complex shapes.
                                        On 18/04/2013 at 01:00, xxxxxxxx wrote:
                                        Glad to know it works. You don't need a loop because Cinema calls Output() for each point to be rendered, setting cd->p accordingly. So you don't iterate through all the points in the UV data, you just calculate the colour to return at the point passed to Output().
                                          On 18/04/2013 at 07:38, xxxxxxxx wrote:
                                          OK. Thanks a lot for the help Steve.
                                          I have enough information now to start looking at formulas and trying to putting something together.
                                          But I'm a long way from controlling gaps and shapes.
                                          Once again. I must make this final plea the the Maxon team (or anyone willing).
                                          Could you please provide us with one example of a procedural shader like the pavement shader?
                                          It doesn't matter what the pattern is, or what the colors are.
                                          Something that shows us how to change the gaps, shapes, and colors of the pattern so we can use it as a guide making our own shaders.
                                          If I end up figuring it out myself. I'll share what I come up with.
                                            // A simple turbulence shader
                                            Vector ExampleShader::Output(BaseShader *chn, ChannelData *cd)
                                            Vector p;
                                            if (cd->vd)
                                                p = cd->vd->p;
                                            else
                                                p = cd->p;
                                            return Vector(Turbulence(p, 3.0, TRUE));
                                            // Using the turbulence value to output either red or green
                                            Vector p;
                                            if (cd->vd)
                                                p = cd->vd->p;
                                            else
                                                p = cd->p;
                                            Real threshold = 0.5; // Introduce a threshold to decide on the output color
                                            if (Turbulence(p, 3.0, TRUE) > threshold)
                                                return Vector(1.0, 0.0, 0.0);
                                            else
                                                return Vector(0.0, 1.0, 0.0);
                                            // Or: Displacing the turbulence with a noise
                                            Vector p;
                                            if (cd->vd)
                                                p = cd->vd->p;
                                            else
                                                p = cd->p;
                                            Real displace_scale = 0.5;        // Introduce a scale for the displacing noise
                                            Real displace_intensity = 0.75;   // Introduce a value to control the intensity of the displacement effect
                                            return Vector(Turbulence(p + Noise(p * displace_scale) * displace_intensity, 3.0, TRUE));
                                            // Or: a simple 2D checkerboard (without MIP mapping, rather ugly)
                                            Vector p = cd->p;
                                            p *= 0.2; // Introduce a scale to control the size of the squares
                                            p.x -= (LONG)Floor(p.x);
                                            p.y -= (LONG)Floor(p.y);
                                            if ((p.x > 0.5) != (p.y > 0.5))
                                                return Vector(1.0);
                                            else
                                                return Vector(0.0);
                                            Of course, all the control values I have introduced in the Output() function would normally be retrieved from the shader's BaseContainer in InitRender() and then stored in private class members.
                                            You see, writing a shader is very easy. But it can also get very complex, depending on the pattern you want.
                                            Algorithms for common patterns can be easily found on the web. For example, here are some old Renderman shaders from the 80s 🙂
                                            You can open the .sl files in a text editor.
                                            http://www.cs.rit.edu/~mrp9521/cg/renderman.html
                                            http://www.renderman.org/RMR/Shaders/BMRTShaders/
                                            Frank
