    Child Layers in layer manager?
    7 Posts 0 Posters 708 Views
      On 09/04/2013 at 09:52, xxxxxxxx wrote:
      Could someone help me get to the child layers in the layers manager? I'm getting stuck with why the hierarchy is not the same or I'm just being silly? If any one could help that would be great.
      Heres a pic:
      I'd be happy to just print all the layers including the children at this stage 😕
      Thanks guys.
        On 09/04/2013 at 10:00, xxxxxxxx wrote:
        a layerobject is derrived form a gelistnode, so you use just the standard methods to navigate
        within a gelistnode tree (GetChildren, Next() and so on). use basedocument.getlayerobjectroot()
        to get the root 😉
          On 26/04/2013 at 15:37, xxxxxxxx wrote:
          This ought to get you going...
          def GetNextObject(op) :
              Returns the next object in the hierarchy.
              if op==None: return None
              if op.GetDown() : return op.GetDown()
              while not op.GetNext() and op.GetUp() :
                  op = op.GetUp()
              return op.GetNext()
          def GetFirstLayer(doc) :
              Returns the first layer, if
              available, otherwise None
              return doc.GetLayerObjectRoot().GetDown()
          def GetFirstActiveLayer(doc) :
              Returns the first selected layer,
              otherwise None
              #Get the first_layer
              first_layer = GetFirstLayer(doc)
              #If there aren't any layers, return None
              if first_layer is None: return None
              #Loop through all layers until you find one that's active
              cur_layer = first_layer
              while cur_layer:
                  #Return the first active layer
                  if cur_layer.GetBit(c4d.BIT_ACTIVE) :
                      return cur_layer
                  cur_layer = GetNextObject(cur_layer)
              #No active layers, return None
              return None
          def GetLayers(doc) :
              Returns a list containing all layers in the current document
              layers = []
              while cur_layer:
                  layers.append(cur_layer)
              return layers
          def PrintLayers(doc) :
              Prints a list of all layers to the console.
              for layer in GetLayers(doc) :
                  print layer.GetName()
              PrintLayers(doc)
            On 27/04/2013 at 03:41, xxxxxxxx wrote:
            Or apply recursion:
            def iter_hierarchy(obj, callback, depth=0) :
                if callback:
                    callback(obj, depth)
                for child in obj.GetChildren() :
                    iter_hierarchy(child, callback, depth + 1)
            def print_obj(obj, depth) :
                print "    " * depth + obj.GetName()
                layer = doc.GetLayerObjectRoot().GetDown()
                while layer:
                    iter_hierarchy(layer, print_obj)
                    layer = layer.GetNext()
            Untested, but should at least show you how it works.
            Best,
            Niklas
            Sent from my mobile Phone.
            Edit: Corrected one line in the code, works fine now.
              On 29/04/2013 at 03:31, xxxxxxxx wrote:
              Thanks for your replies.
              I actually went down the recursion route like this:
              from c4d import gui
              def getNextLayer(layer) :
                  if layer.GetDown() :
                       return layer.GetDown()
                  while layer.GetUp() and not layer.GetNext() :
                       layer = layer.GetUp()
                  return layer.GetNext()
                  doc = 	c4d.documents.GetActiveDocument()
                  root = 	doc.GetLayerObjectRoot()
                  layer = root.GetDown()
                  # loop through every layer in the layer list
                  while layer:
                      #Do something
                      layer = getNextLayer(layer)
              Thanks again guys.
                On 29/04/2013 at 04:18, xxxxxxxx wrote:
                Nope, that's iteration.
                Best,
                -Niklas
                  On 29/04/2013 at 08:22, xxxxxxxx wrote:
                  Indeed, my mistake Tongue
