    Redraw UserArea while Dragging
    7 Posts 0 Posters 635 Views
      On 02/04/2013 at 16:11, xxxxxxxx wrote:
      Hello everybody,
      i want my userarea to redraw while mousedragging, but I dont get it. Ive already managed to get into a dragging loop with updating mouse position. Ive found this ... >If one is designing a real element, for example a slider, one might also want to send regular messages to the parent dialog. These are sent with SendParentMessage() and appear as calls to Command() in the dialog, just as with any regular element:
           // Create an action message,   // with the user area's id:   var action = new(BaseContainer, BFM_ACTION);   action->SetData(BFM_ACTION_ID, GetId());      while(TRUE)   {     // Poll the mouse as above and draw the slider.        // Send a message to the parent dialog, so that     // it knows that the user is dragging the slider:     action->SetData(BFM_ACTION_INDRAG, TRUE);     SendParentMessage(action);   }      // Notify the dialog that the dragging is finished:   action->SetData(BFM_ACTION_INDRAG, FALSE);   SendParentMessage(action);
      ... but Im not able to translate to python.
      Can anyone help?
      My attempt:
      state = c4d.BaseContainer()
      while self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, state) :
            if state.GetLong(c4d.BFM_INPUT_VALUE)==0: break
            mouse_x=state.GetLong(c4d.BFM_INPUT_X)
            mouse_y=state.GetLong(c4d.BFM_INPUT_Y)
            # Do Stuff
            action = c4d.BaseContainer(c4d.BFM_ACTION)
            action.SetLong(c4d.BFM_ACTION_ID, self.GetId())
            action.SetLong(c4d.BFM_ACTION_INDRAG, True)
            self.SendParentMessage(action)
            self.Redraw()
      action.SetLong(c4d.BFM_ACTION_INDRAG, False)
      Greetings
      rown
        On 03/04/2013 at 16:31, xxxxxxxx wrote:
        I did it ...
        from c4d import bitmaps, gui, plugins, utils
        import collections, os
        PLUGIN_ID = 10000056 #TestID only!!!!!!!!!!!!
        class Area(gui.GeUserArea) :
          def DrawMsg(self, x1, y1, x2, y2, msg) :
              state=c4d.BaseContainer()
                self.Draw(x,y)
          def Draw(self, x, y) :
              self.DrawSetPen(c4d.Vector(127.0/255))
              self.DrawSetTextCol(c4d.Vector(255.0/255),c4d.Vector(0.0/255))
              self.DrawRectangle(0,0,500,500)
              self.DrawText("TEST", x, y-20, flags=c4d.DRAWTEXT_STD_ALIGN)
          def InputEvent(self, msg) :
              self.Redraw()
        class MyDialog(gui.GeDialog) :
          def __init__(self, area) :
              self.area = area
          def CreateLayout(self) :
              self.SetTitle("Table")
              self.AddUserArea(1000, c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT)
              self.AttachUserArea(self.area, 1000)
              self.GroupEnd()
          def Command(self, id, msg) :
              print id
        class Test(plugins.CommandData) :
          area = Area()
          dialog = None
          def Execute(self, doc) :
              if self.dialog is None: self.dialog = MyDialog(self.area)
              return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=500, defaulth=500)
          def RestoreLayout(self, sec_ref) :
              return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
           bmp = bitmaps.BaseBitmap()
           dir, f = os.path.split(__file__)
           fn = os.path.join(dir, "res", "icon.tif")
           bmp.InitWith(fn)
           plugins.RegisterCommandPlugin(id=PLUGIN_ID,
                                        str="Test01",
                                        info=0,
                                        help="Test01",
                                        dat=Test(),
                                        icon=bmp)
        Since I added Command() in GeDialog it works. But it doesnt work well. If I remove 'print id' from Command() it doesnt work. And if I use 'GeUserArea.OffScreenOn([ x , y , w , h ])' it doesnt work.
          On 03/04/2013 at 18:59, xxxxxxxx wrote:
          I don't think we're allowed to use the overridden Draw() method with the user area.
          This is a different way to write your code:
          PLUGIN_ID = 10000010 #TestID only!!!!!!!!!!!!
                self.DrawSetPen(c4d.Vector(.2))                                  #Set the Background Color
                self.DrawRectangle(x1, y1, x2, y2)                               #Draws the UA rectangle area
                self.DrawSetPen(c4d.Vector(1,0,0))                               #Sets the color to red
                self.DrawRectangle(80,80,100,100)                                #Draws a little rectangle in the UA
                self.DrawSetTextCol(c4d.Vector(1,1,1), c4d.Vector(0,0,0))        #Sets the foreground & background color of the text
                self.DrawText("Hello", 0, 0, flags=c4d.DRAWTEXT_STD_ALIGN)         #Draws the text at the coords 0x,0y
                while self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, msg) :    #While the left mouse button is held down
                  if msg.GetLong(c4d.BFM_INPUT_VALUE)==0: break
                  mx=msg.GetLong(c4d.BFM_INPUT_X)                         #Get the mouse coords.
                  my=msg.GetLong(c4d.BFM_INPUT_Y)
                  self.SendParentMessage(action)                          #Sends a message to the parent dialog that the mouse is dragging in the UA
                  self.Redraw()                                           #Redraw while the left mouse button is held down
                self.SendParentMessage(action)                            #Sends a message to the parent dialog that the mouse has stopped dragging in the UA
                self.area = area
                self.SetTitle("My UserArea")
                self.GroupEnd()
                print id                     #Prints the ID of the UA
            area = Area()
            dialog = None
             bmp.InitWith(fn)
                                          str="Test01",
                                          info=0,
                                          help="Test01",
                                          dat=Test(),
                                          icon=bmp)
            On 03/04/2013 at 23:21, xxxxxxxx wrote:
            Scott, from what I see in your code, you are not moving the drawn content depending on the drag
            offset? I may be wrong and didn't find it, though. Anyway, there is no "Draw()" method in the
            GeUserArea class as far as I can tell.
            Best,
            -Niklas
              On 04/04/2013 at 07:56, xxxxxxxx wrote:
              His code does not have anything that moves the drawn content either.
              I simply re-wrote his code in a more stable manner.
              But if that's a problem. Here's an example that lets the user drag the text around in the UA with the left mouse button:
                xValue = 0
                yValue = 0
                    self.DrawText("Hello", self.xValue, self.yValue, flags=c4d.DRAWTEXT_STD_ALIGN)    #Draws the text at the current mouse coords
                      mouseX=msg.GetLong(c4d.BFM_INPUT_X)                     #Get the global mouse coords.
                      mouseY=msg.GetLong(c4d.BFM_INPUT_Y)
                      localPos = self.Global2Local()                          #Convert the mouse positions from global to local
                      mouseX += localPos['x']                                 #The mouse's local coords.
                      mouseY += localPos['y']
                      self.xValue = mouseX                                    #Class variables are set to same as mouse coords. so the DrawMsg() can use them
                      self.yValue = mouseY
                    self.area = area
                    self.GroupEnd()
                area = Area()
                dialog = None
                 bmp.InitWith(fn)
                                              str="Test01",
                                              info=0,
                                              help="Test01",
                                              dat=Test(),
                                              icon=bmp)
                On 04/04/2013 at 08:53, xxxxxxxx wrote:
                Hey Scott,
                it wasnt a problem. I thank you very much. It helps alot!
                  mx = 0
                  my = 0
                      self.OffScreenOn(x1, y1, x2, y2)
                      self.DrawText("Hello", self.mx, self.my, flags=c4d.DRAWTEXT_STD_ALIGN)         #Draws the text at the coords 0x,0y
                      print "Input"
                        self.mx=msg.GetLong(c4d.BFM_INPUT_X)                         #Get the mouse coords.
                        self.my=msg.GetLong(c4d.BFM_INPUT_Y)
                      self.area = area
                      self.GroupEnd()
                Greetings
                rown
                  On 04/04/2013 at 08:54, xxxxxxxx wrote:
                  It actually does:
                       **           x=state.GetLong(c4d.BFM_INPUT_X)
                              self.Draw(x,y)**
