    texture tag script works but...
    11 Posts 0 Posters 831 Views
      On 31/03/2013 at 07:25, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      Platform:      Mac OSX  ;
      Here's a  script i did to change texture tags location.
      It's definitely not a slick one, but it works, except that...
      It makes the console giving error message each time i select an object when user_data#ID_USERDATA:2 == false.
      I tried different way to fixe it, really, never being able doing it.
      Is somebody could help me with it?
      Thanks a lot,
      Jean
      Here's the links for the C4D scene(the second one in zip format).
      https://www.yousendit.com/download/UVJpb2VNQ1B3NUtFQk1UQw
      https://www.yousendit.com/download/UVJpb2VNQ1AxUURFdzhUQw
      main(doc,op)
      var user_data = doc->FindObject("temp_tag(f)");
      var tag_cntnr;//tag container
      var f_clnr;
      var f_txt_tg = new(array,2);
      var i;
      var i_tag;
      if (user_data#ID_USERDATA:2 == true)
      tag_cntnr = doc->FindObject("f1");
      if(!tag_cntnr) return;
      i_tag = tag_cntnr->GetFirstTag();
      if(!i_tag) return;
      i = 0;
      while(i< 2)
      f_txt_tg = i_tag;
      _ i_tag = i_tag->GetNext();_
      _ i++;_
      _ }_
      f_txt_tg[0]- >Remove();
      f_txt_tg[1]- >Remove();
      f_clnr = doc- >FindObject("f_1(clnr)");
      if(!f_clnr) return;
      f_clnr- >InsertTag(f_txt_tg[1]);
      f_clnr- >InsertTag(f_txt_tg[0]);
      if (user_data#ID_USERDATA:2 == false)
      tag_cntnr = doc- >FindObject("f_1(clnr)");
      i_tag = tag_cntnr- >GetFirstTag();
      if(!i_tag) return;
      _ i = 0;_
      _ while(i< 2)_
      _ {_
      _ f_txt_tg = i_tag;_
      _ _ i_tag = i_tag->GetNext();__
      _ _ i++;__
      _ _ }__
      _ f_txt_tg[0]- >Remove();_
      _ f_txt_tg[1]- >Remove();_
      _ tag_cntnr = doc- >FindObject("f1");_
      _ if(!tag_cntnr) return;_
      _ tag_cntnr- >InsertTag(f_txt_tg[1]);_
      _ tag_cntnr- >InsertTag(f_txt_tg[0]);_
      _ }_
      __
      _ }_
      __
        On 31/03/2013 at 08:01, xxxxxxxx wrote:
        Hello Jean.
        Please use the CODE BB-tags to format your code. Correct indentation makes reading the code far
        more easy, not just for you, but also for the ones that you are asking for help. Please provide
        and example scene: I am not willing to set up a scene that the script will operate on.
        Best regards,
        -Niklas
          On 31/03/2013 at 14:50, xxxxxxxx wrote:
          Sorry,
          I added links for the scene.
          Jean
            On 01/04/2013 at 01:31, xxxxxxxx wrote:
            GeListNode.GetNext() returns null/nil if there are no other tags. please also note that there
            are often more tags on objects than you can visually see. so simply iterating through all tags
            is a very risky approach. the script is executed because c4d finds the modata tag on the cloner
            object and therefore  _i_tag = tag_cntnr- >GetFirstTag(); _is not null _ _ but getnext() will return then
            null.
            edit : also doing such object tree manipulation from a expression is pretty dangerous. also
            this whole copy, delete, insert approach is a bit clunky and object names as identifiers are a
            bad idea. however here is a quick version (in python) how to move all texture tags from one
            object to another.
                obja = doc.SearchObject('f1')
                objb = doc.SearchObject('f_1(clnr)')
                if obja and objb:
                    for tag in obja.GetTags() :
                        if tag.CheckType(c4d.Ttexture) :
                            objb.InsertTag(tag)
              On 01/04/2013 at 08:07, xxxxxxxx wrote:
              Thanks a lot ferdinand.
              I don't know Python, but i'm whiling to give it a try.
              I copied and paste your Python's script into a Python's tag.
              It doesn't execute probably needing some declaration...
              Could just give me a clue so i could at least execute those lines of code you gave me?
              Thanks again.
              Jean
                On 01/04/2013 at 09:41, xxxxxxxx wrote:
                just paste the snippet into main method of a script or expression, something like this:
                    if obja and objb:
                        for tag in reversed(obja.GetTags()) :
                                objb.InsertTag(tag)
                  On 01/04/2013 at 11:15, xxxxxxxx wrote:
                  Thanks ferdinant,
                  It works.
                  Then i just tried to add my "switch" status, so i could move tags from one object to the other and get it back.
                  But it's  not responding  to it...
                  Cannot figure how to nest [if] into [if]...
                  In fact, i have 6 switchs, each one for a set of tags, but tried to make it works with one switch first.
                  Sorry, it's a first try with Python, but i really appreciate your help.
                      if [c4d.ID_USERDATA,2] == 0:
                          if obja and objb:
                                  objb.InsertTag(tag)
                                  if [c4d.ID_USERDATA,2] == 1:
                                      if obja and objb:
                                       for tag in reversed(objb.GetTags()) :
                                              obja.InsertTag(tag)
                  Then i should continue with  [c4d.ID_USERDATA,3]  with object name ('f2') ('f_2(clnr)'), etc...
                  Hope that at least i'm clear with what i'trying to do.
                  Jean
                    On 01/04/2013 at 22:46, xxxxxxxx wrote:
                    hey,
                    the bracket syntax ([SOMEID]) is a shortcut to the __getitem__ and __setitem__ methods
                    which basically just access the basecontainer of an object. so you need an object for which
                    you could invoke those methods.
                    > if myobj[c4d.isawesome]: ...
                    you will need the object holding your user data for that. i think it is worth mentioning in that
                    context that there are some predefined variables for each python script and expression, one
                    of them is op which is pointing / is a reference to the hosting object, which would be for your
                    case a pyhton tag.
                    so if you had your userdata attached to a null object which is also hosting your python tag
                    your code would be something like this. (GetObject() is a BaseTag method returning the
                    hosting BaseObject for a BaseTag).
                    myUDHost = op.GetObject()
                    if myUDHost[c4d.isawesome]:
                    for your general code syntax, you are aware that 50% of your code will never be executed ?
                    nesting if a == False withing an a == True does not make sense a cannot be both true and false.
                    you are most likely just looking for something like this:
                    if conditionA:         // will always be true, unless conditionA is 0, False or None
                    elif not conditionA: // inverted - only true if conditionA is 0, False or None
                    elif conditionA == 3:  // the following lines would never be executed because the previous conditions already covered all cases, so just for the record
                    elif conditionA == 'someText':
                    elif objA == objB:
                    elif objA is objB:
                      On 02/04/2013 at 07:58, xxxxxxxx wrote:
                      Hi ferdinand,
                      V'got some home works...
                      I tried to paste this snippet you gave me into Python Script Manager to execute it with a short cut and it didn't work.
                      Is it possible to execute it from there that way?
                      May be you already told me in your previous reply, but i'm looking for a quick workaround way to use this snippet.
                      Thanks again,
                      Jean
                      _<_t_>_
                          if obja and objb:
                                      objb.InsertTag(tag)
                      _/tr>
                      _d>
                        On 02/04/2013 at 09:02, xxxxxxxx wrote:
                        for a script you have to add:
                        at the bottom of your script.
                          On 02/04/2013 at 11:08, xxxxxxxx wrote:
                          Hi ferdinand,
                          Thanks a lot!
                          Really.
                          Jean
