    Render Preview Image of Shader
    7 Posts 0 Posters 542 Views
      On 30/03/2013 at 04:08, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      I'm trying to render a preview-image of a BaseShader, but I get crashes in sdl.cdl. I guess it's because
      I don't pass a VolumeData to the ChannelData? I can't get it right. Strange thing is, that the call-stack
      only shows one call to my plugin which is the BaseContainer destructor.. And I don't even use a
      BaseContainer in this code.
      Code:
          sla.cdl!5f9f1ac6()
          [Unten angegebene Rahmen sind möglicherweise nicht korrekt und/oder fehlen, keine Symbole geladen für sla.cdl]
          xtensions.cdl!5f73a5e7()
          CINEMA 4D.exe!01718250()
          CINEMA 4D.exe!016a2b74()
          CINEMA 4D.exe!01bcd2d2()
          CINEMA 4D.exe!01bd0012()
          CINEMA 4D.exe!01509238()
          CINEMA 4D.exe!0145a4de()
          CINEMA 4D.exe!0161132c()
          CINEMA 4D.exe!016186e1()
          CINEMA 4D.exe!01716a94()
          CINEMA 4D.exe!016a17bb()
          CINEMA 4D.exe!016a2595()
          CINEMA 4D.exe!017024ef()
          CINEMA 4D.exe!01711f53()
          CINEMA 4D.exe!01626739()
          CINEMA 4D.exe!016975ce()
          CINEMA 4D.exe!01b71a3c()
          CINEMA 4D.exe!0161130f()
          CINEMA 4D.exe!01716b74()
          CINEMA 4D.exe!01701696()
          CINEMA 4D.exe!0170e612()
          CINEMA 4D.exe!01716f63()
          CINEMA 4D.exe!0172088e()
          CINEMA 4D.exe!0171a86d()
          CINEMA 4D.exe!0171cd91()
          CINEMA 4D.exe!0174e19c()
          user32.dll!75368e63()
          user32.dll!75368e9f()
          msctf.dll!74dc5123()
          msctf.dll!74dc439e()
          msctf.dll!74dc3ad3()
          user32.dll!7537491f()
          user32.dll!75374902()
          user32.dll!753729d5()
          user32.dll!753729b8()
          user32.dll!75368112()
          CINEMA 4D.exe!01b58efc()
          CINEMA 4D.exe!0161a415()
          CINEMA 4D.exe!01619581()
          CINEMA 4D.exe!0169fbe9()
          CINEMA 4D.exe!01643962()
          CINEMA 4D.exe!01696d7a()
          KernelBase.dll!75195338()
      >   myplugin.cdl!BaseContainer::~BaseContainer()  Zeile 41   C++
          0039c634()
          CINEMA 4D.exe!01bd59cd()
          CINEMA 4D.exe!01ba3054()
          CINEMA 4D.exe!01b1bd67()
          CINEMA 4D.exe!00e60ef9()
          CINEMA 4D.exe!01bc7dbf()
          CINEMA 4D.exe!01707671()
          CINEMA 4D.exe!0147ad67()
      Code:
      Bool RenderShader(BaseShader* shader, BaseBitmap* bmp, Real scale=1.0) {
          InitRenderStruct irs;
          if (shader->InitRender(irs) != INITRENDERRESULT_OK) return FALSE;
      LONG w = bmp->GetBw();
          LONG h = bmp->GetBh();
          ChannelData cd;
      for (LONG x=0; x < w; x++) {
            for (LONG y=0; y < h; y++) {
      cd.p.x = x * scale;
              cd.p.y = y * scale;
              cd.p.z = 0.0;
      Vector pixel = shader->Sample(&cd);
              LONG r = pixel.x * 255;
              LONG g = pixel.y * 255;
              LONG b = pixel.z * 255;
              bmp->SetPixel(x, y, r, g, b);
      shader->FreeRender();
      Any tips much appreciated. Thanks in advance!
      -Niklas
        On 30/03/2013 at 05:27, xxxxxxxx wrote:
        The only bad thing I notice is that you are not checking any pointers for NULL.
        An empty VolumeData pointer in the ChannelData should not a problem.
          On 30/03/2013 at 05:50, xxxxxxxx wrote:
          Hi Jack,
          I ensure to pass valid pointers before calling the function anyway so I
          decided to not include these checks in the function.
          Hm.. I'll try again in another environment, since you say it actually
          looks to be correct.
          -Niklas
            On 30/03/2013 at 06:13, xxxxxxxx wrote:
            I've tried to do it in Python first:
            from __future__ import division
            from c4d.modules import render
            def RenderShader(shader, bmp, scale=1.0) :
                irs = render.InitRenderStruct(doc)
                if shader.InitRender(irs) != c4d.INITRENDERRESULT_OK:
                    return False
                cd = render.ChannelData()
                w, h = bmp.GetSize()
                for x in xrange(w) :
                    for y in xrange(h) :
                        cd.p.x = x * scale
                        cd.p.y = y * scale
                        c = shader.Sample(cd)
                        r = int(c.x * 255)
                        g = int(c.y * 255)
                        b = int(c.z * 255)
                        bmp.SetPixel(x, y, r, g, b)
                shader.FreeRender()
                bmp.Init(128, 128, 24)
                mat = doc.GetActiveMaterial()
                sha = mat.GetFirstShader()
                if not RenderShader(sha, bmp, 1.0) :
                    print "Rendering shader was not successful."
                c4d.bitmaps.ShowBitmap(bmp)
            But all I get is a mono-coloured image (black or grey, depending on the shader in the active
            material).
              On 30/03/2013 at 11:06, xxxxxxxx wrote:
              This works!! 🙂
                  ChannelData cd;
                  cd.p = Vector(0, 0, 0);
                  cd.n = Vector(0, 0, 1);
                  cd.d = Vector(0, 0, 0);
                  cd.t = 0.0;
                  cd.texflag = 0;
                  cd.vd = NULL;
                  cd.off = 0.0;
                  cd.scale = 0.0;
                          cd.p.x = (Real) x * scale;
                          cd.p.y = (Real) y * scale;
                          LONG r = MIN(255, pixel.x * 255);
                          LONG g = MIN(255, pixel.y * 255);
                          LONG b = MIN(255, pixel.z * 255);
              I just initialized every value of the ChannelData.
              -Niklas
                On 30/03/2013 at 11:11, xxxxxxxx wrote:
                Works for most shaders.. But eg. the tile shader is black only.. 😕
                  On 30/03/2013 at 11:24, xxxxxxxx wrote:
                  hm,
                  i haven't red everything, but this might help. it is a class to sample a baseshader into
                  vertexmap data.
                  http://codepad.org/qD96O7rR
