    TreeViewFunctions::InputEvent() CTRL+A
    3 Posts 0 Posters 314 Views
      On 29/03/2013 at 07:13, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      I'm trying to catch when the user pressed Ctrl + A on the keyboard. But when the Ctrl qualifier
      is set, BFM_INPUT_ASC is an empty string.
      The following is the output for the following actions:
      • Click
      • Pressing 'a'
      • Click
      • Pressing Ctrl + 'a'
      MaskExportTreeModel::InputEvent
      BFM_INPUT_VALUE: 1
      BFM_INPUT_ASC:
      BFM_INPUT_VALUE: 1
      BFM_INPUT_ASC: a
      BFM_INPUT_VALUE: 1
      BFM_INPUT_ASC:
      BFM_INPUT_VALUE: 1
      BFM_INPUT_ASC:
      CTRL!!
      And this is the corresponding code:
      Bool MyTreeViewFunctions::InputEvent(void* root, void* ud, GeUserArea* area,
                                           const BaseContainer& msg) {
          GePrint(__FUNCTION__);
          GePrint("BFM_INPUT_VALUE: " + LongToString(msg.GetLong(BFM_INPUT_VALUE)));
          GePrint("BFM_INPUT_ASC: " + msg.GetString(BFM_INPUT_ASC));
          if (msg.GetLong(BFM_INPUT_QUALIFIER) & QCTRL) {
              GePrint("CTRL!!");
          return TreeViewFunctions::InputEvent(root, ud, area, msg);
      Pressing Ctrl alone does not trigger an Input event, only when pressing Ctrl + 'some key' triggers
      the method. But the key pressed together with the qualifier is not given. How can I catch the
      Ctrl + 'a' key-press correctly?
      Thanks!
      -Niklas
        On 29/03/2013 at 23:01, xxxxxxxx wrote:
        This should give you the ASCII decimal value for the key:
        LONG chn = msg.GetLong(BFM_INPUT_CHANNEL);
          On 30/03/2013 at 00:32, xxxxxxxx wrote:
          Thank you David, that's it!
