    failing to access CTracks
    5 Posts 0 Posters 528 Views
      On 29/03/2013 at 06:16, xxxxxxxx wrote:
      Cinema 4D Version:   14.034
      I am writing an exporter in C++ and cannot get any CTracks from my animated objects.
      Here is the simple code:
      BaseObject* op = doc->GetFirstObject();
      CTrack* track = op->GetFirstCTrack();
      while (track)
        GePrint( "found track: " + track->GetName() );
        track = track->GetNext();
      GetFirstCTrack() never returns a CTrack object.
      I am new to the C++ SDK but I have managed to export static transformations, polygons, uvs etc.
      Is there a plugin or function inside of Cinema 4D to get detailed SDK data structure information for debugging purposes?
      Thanks for any help.
        On 29/03/2013 at 07:58, xxxxxxxx wrote:
        It looks like you might not be going deep enough.
        Keys reside on curves, which reside in tracks.
        So to get at a key value you need to go through the track->curve->key tree branching system.
        Example:
        //This code Get's the key values on all the tracks of an object
          BaseObject* obj = doc->GetActiveObject();      //Get the active object
          if(!obj) return False;
          BaseTime time = doc->GetTime();               //Assigns the basetime class to a variable
          Real fps = doc->GetFps();                     //Gets the frames per second value
          Real currentFrame = time.GetFrame(fps);       //The current frame the slider is on
          CTrack *trk = obj->GetFirstCTrack();          //Get the first track
          while(trk)
              CCurve *curve = trk->GetCurve(CCURVE_CURVE, FALSE); //Get the curve on the first track
              Real i;
              for(i=0; i<curve->GetKeyCount(); i++)
                  CKey *keys = curve->GetKey(i);                   //Get all of the keys
              Real keyframe = keys->GetTime().GetFrame(fps);   //Assing the frame the keys are on to this variable
              float keyvalues = keys->GetValue();              // Get the values of each key
              GePrint("Frame= "+ RealToString(keyframe) + "  " + "   " + "Values= " + RealToString(keyvalues));
              trk = trk->GetNext();
          On 29/03/2013 at 08:50, xxxxxxxx wrote:
          Thanks for the code ScottA,
          I didn't even get to CCurve and CKey yet because my problem is getting anything but NULL from:
          CTrack \*trk = obj->GetFirstCTrack();
            On 30/03/2013 at 17:35, xxxxxxxx wrote:
            Trying the same in python gives me the expected CTrack names and subsequent data, so I know I actually have animated data...
              obj = doc.GetFirstObject()
              while obj != None:
                  print "tracks found for '" + obj.GetName() + ":"
                  track = obj.GetFirstCTrack()
                  while track != None:
                      print track.GetName()
                      curve = track.GetCurve()
                      idx=0
                      while idx < curve.GetKeyCount() :
                          key = curve.GetKey(idx)
                          time = key.GetTime()
                          print str( time.GetFrame(doc.GetFps()) ) + ": " + str(key.GetValue())
                          idx+=1
                      track = track.GetNext()
                  obj = obj.GetNext()
              On 01/04/2013 at 04:35, xxxxxxxx wrote:
              Found the error on my part:
              I created a clone of my document:
              doc->Polygonize();
              which defaults to not cloning any animations.
              doc->Polygonize( true );
              Does the trick.
