    Dialog in a dialog
    3 Posts 0 Posters 316 Views
      On 25/03/2013 at 07:35, xxxxxxxx wrote:
      I'm tring to open a 2nd (modal) dialog in another dialog.
      It works ok, until I close and re-open the plugin with the dialog.
      Then an incorrect dialog is displayed and later Cinema 4d crashes.
      It seems that i do not restore correctly?
      import os
      from c4d import gui, plugins, bitmaps, utils, documents
      PLUGIN_ID = 1011310 # Test ID
      MY_CITY             = 11001
      MY_BUTTON           = 11004
      class MyDialog2(gui.GeDialog) :  #2nd (modal) dialog
        def CreateLayout(self) :
            self.GroupBegin(id=1011, flags=c4d.BFH_FIT, cols=2)
            self.element = self.AddStaticText(id=1003, flags=c4d.BFH_LEFT, initw=100, name="City")
            self.AddEditText(MY_CITY, c4d.BFH_SCALEFIT, 100, 0)
            self.GroupEnd()
            self.GroupBegin(id=1013, flags=c4d.BFH_SCALEFIT, cols=1)
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Done")
            self.GroupEnd()
        def Command(self, id, msg) :
            if (id == MY_BUTTON) :
                print "city: ", self.GetString (MY_CITY)
                self.Close()
      class MyDialog(gui.GeDialog) : #main dialog
            self.AddButton(MY_BUTTON, c4d.BFV_MASK, initw=100, name="Goto 2nd dialog")
            self.GroupEnd()
                self.dialog2 = MyDialog2()  #init and open 2nd dialog
                self.dialog2.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
      class MyMenuPlugin(plugins.CommandData) :
        dialog = None
        def Execute(self, doc) :
        # create the dialog
           if self.dialog is None:
              self.dialog = MyDialog()
           return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
        def RestoreLayout(self, sec_ref) :
        # manage the dialog
           print "Restore."
           return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
       path, fn = os.path.split(__file__)
       bmp = bitmaps.BaseBitmap()
       bmp.InitWith(os.path.join(path, "res/icons/", "icon.tif"))
       okyn = plugins.RegisterCommandPlugin(PLUGIN_ID, "OSM",0, bmp, "OSM", MyMenuPlugin())
       if (okyn) :
        print "Initialized."
        On 25/03/2013 at 07:40, xxxxxxxx wrote:
        Hi.
        Pass the pluginid to a dialog only for the dialog that belongs to the CommandData itself. It is
        also only necessary when you want to restore the dialog (in CommandData.Restore()) which in
        turn only works for asynchronous dialogs.
        Remove the pluginid=PLUGIN_ID from the Open() call of your second dialog.
        -Niklas
          On 26/03/2013 at 12:07, xxxxxxxx wrote:
          Yes, it works!
          Thank you.
          I'll put it in a tutorial including your remarks.
