    Object Use Color Property
    8 Posts 0 Posters 1.0k Views
      On 23/03/2013 at 10:16, xxxxxxxx wrote:
      I have script that changes the objects display color. First turning on the Use Color option with this code:
      obj = doc.GetActiveObject()
      bc = obj.GetData()
      bc.SetLong(c4d.ID_BASEOBJECT_USECOLOR, 2)
      obj.SetData(bc)
      It even prints the correct value when I print GetLong, but the object doesn't change?
        On 23/03/2013 at 12:22, xxxxxxxx wrote:
        We're supposed to use the Get&Set Parameters method as much as possible. And only use BaseContainers as a very last resort.
        In Python. That means using a bracketed syntax like this:
          obj[c4d.ID_BASEOBJECT_USECOLOR]=2     #Equivalent to SetParameter() in C++
          On 23/03/2013 at 12:56, xxxxxxxx wrote:
          Thanks Scott! I was racking my brain over that simple problem. Still seems like the base container should have worked though.
            On 24/03/2013 at 09:22, xxxxxxxx wrote:
            BaseContainers don't work for everything. For example, you can't get the attributes of a light that way - you have to use Get/SetParameter.
              On 24/03/2013 at 11:21, xxxxxxxx wrote:
              Thanks spedler, I guess I'm not really sure why someone would use a BaseContainer then?
                On 24/03/2013 at 11:39, xxxxxxxx wrote:
                Most parameters are accessible and modifiable via the BaseContainer, but not all. Using the container
                directly offers certain advantages in speed (especially when using the fixed-type setters and getters)
                and usage (eg. merging containers).
                -Niklas
                  On 24/03/2013 at 14:13, xxxxxxxx wrote:
                  The things we grab using Get&Set Parameters are set up to work that way by Maxon.
                  So it's considered a convenience.
                  Plus it's also considered a safer way to work. Since you're using code they set up for us to use.
                  The containers are there in case you want to be a mad scientist. !Smile[URL-REMOVED]
                  They let us create something brand new on our own that Maxon hasn't set up for us already.
                    On 24/03/2013 at 16:54, xxxxxxxx wrote:
                    Thanks for clarifying this confusing topic guys! Ill stick to the get/set. It really is much easier to work with.
